West Penn Hardwoods (Ad 1)
Results 1 to 15 of 15
  1. #1
    DQ
    petebucy4638's Avatar
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    Sawstop blade alignment
    I am well on my way to getting my new Sawstop Pro, 3HP, 52" cabinet saw setup. The fence aligned perfectly with the miter slots. I was amazed. But the blade is out of alignment with the miter slots by .018" Out of all of the table saws that I have owned over many years, that is the farthest out of alignment that I have come across. When I set up my Grizzly 1023 seven years ago, it came from the factory with a blade to miter slot alignment that was off only .0005". The fence had to be adjusted but the blade alignment to the miter slot was perfect. There is no way that anyone at the Sawstop factor made any effort to align the blade with the miter slot. Considering the cost of this saw, that is a very discouraging situation!
    As for blade run-out - this reading was taken using a Forester II blade. The tolerances for that blade were plus or minus .001". The blade run-out for the the stock Sawstop blade and a Freud industrial blade and a Ridge blade were around plus or minus .003" to .005". All except the Forester II blades were new and had never made the first cut.
    Most people who buy as table saw put it together and turn it on. They don't have the experience to measure blade to miter slot alignment and if they did, very few have the tools that they need. So now I get to spend a couple of hours aligning my saw because Sawstop quality control didn't do their job.
    Pete
    Attached Images Attached Images
    Pete - KD4CQZ
  2. #2
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,829
    Visit Freq
    4.27 visits/week
    Threads
    70
    Classifieds
    Re: Sawstop blade alignment
    Kinda makes you wonder what else they didnt do.....
  3. #3
    DQ
    tarheelz's Avatar
    Nickname
    Dave (45)
    Join Date
    Sep 2012
    Location
    Durham, NC
    Posts
    918
    Visit Freq
    5.15 visits/week
    Threads
    61
    Classifieds
    Pete,
    This sounds crazy but before making any adjustment, just for giggles, take the blade off the arbor and then re-seat it and tighten it down. You'll probably still be out of alignment but I can tell you that when I first set-up my Sawstop, I was out of alignment too. When I took the blade off and looked at it, I could see that some sort of gunk (sap?) was on the blade. (I stole a blade I had lying around.) Once I gooped that off and re-seated it, the blade was much closer. A little tweaking and I was there.
  4. #4
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,484
    Visit Freq
    6.96 visits/week
    Threads
    734
    Classifieds
    I have aligned 7 or 8 Saw Stops and ony one was dead on from the factory. The worst one was out by 0.015. All the others were between 0.003 and 0.011..
    the good old news is they are very easy to adjust and hold the setting several years.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  5. #5
    DQ
    redknife's Avatar
    Nickname
    Join Date
    May 2013
    Location
    Mocksville, NC
    Posts
    989
    Visit Freq
    6.77 visits/week
    Threads
    82
    Classifieds
    Sorry to hear you had to put extra work in to the factory alignment, Pete. Aggravating.
  6. #6
    DQ
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    I tested it with four different blades, three of which were new. The most accurate blade was the Forester WWII. It had some pitch buildup on it, but I cleaned it where the dial indicator contacted the blade. I used a separate dial indicator to test the run-out on each blade.
    Pete
    Pete - KD4CQZ
  7. The following user says Thank You to petebucy4638 for this useful post:
  8. #7
    DQ
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    It only took two hours to set the align the table so that the blade is now nearly perfectly aligned with the miter slots. I have to admit that Sawstop has the most elegant and accurate method of aligning the saws top with the blade. With most cabinet saws that I have worked on, you have to loosen the bolts that attach the top to the frame and nudge the top with a dead-blow hammer. Sawstop has included alignment machine screws that let you adjust the top with incredible precision. Of course, when you start to tighten the top down again, you have to continue to make adjustments, but if you are willing to invest the time you end up with a very precise alignment between the blade and the top.
    Sawstop loses points for not aligning the saw at the factory, but picks up points for providing such an accurate and easy to use alignment system. Of course, points in Sawstops favor for supplying what is without a doubt the best manual that I have ever seen, ever, anywhere!!! All I have left to do is to realign the fence to the miter slots and I'm ready to start cutting some wood.
    Overall, Sawstop is a well designed and well-built tool. Which is why the misalignment issue stood out as such an absurd anomaly in an other wise very good assembly and setup process.
    Pete
    Pete - KD4CQZ
  9. #8
    DQ
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    After the misalignment problem I gave the entire saw a thorough going over. I couldn't find anything else wrong, and I checked in some detail.
    I purchased a Grizzly contractors saw that showed an open ground to the frame when tested before we put it into use. When I opened the switch cover, someone at the factory had bonded the frame to the ground. The ground strap was short and they didn't replace it. It was a simple fix and Grizzly was informed.
    I don't know, maybe the guy on the Sawstop assembly line was overwhelmed that day and didn't take the time to align the blade and the table. Anyhow, it fixed now and I know my saw better than I would have had I not had to make this correction.
    Pete
    Quote Originally Posted by chris_goris View Post
    Pete - KD4CQZ
  10. #9
    DQ
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Mike Davis View Post
    I was impressed with the adjustment process.
    Pete
    Pete - KD4CQZ
  11. #10
    DQ
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    Quote Originally Posted by redknife View Post
    I think that what bothers me the most is that Sawstop does not include the alignment process as part of the assembly process that every new saw owner should perform. Granted, the manual explains very clearly how to align the blade to the miter slots. Knowing that the factory does not make a great effort to do this for the buyer, it would be prudent for Sawstop tell the buyer that he has to perform the alignment himself.
    This is a minor speed-bump on an otherwise very smooth road.
    Pete
    Pete - KD4CQZ
  12. #11
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,829
    Visit Freq
    4.27 visits/week
    Threads
    70
    Classifieds
    Quote Originally Posted by petebucy4638 View Post
    Pete
    I am surprised at that as well. What does the manual tell you to do if the safety mechanism has been fired?. Does it tell you to check all of that again?. I would think you should since all of that energy has to go somewhere besides into the cartridge.
  13. #12
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,484
    Visit Freq
    6.96 visits/week
    Threads
    734
    Classifieds
    The only problem you will have with firing is if you have too heavy a dado set, they don’t mention this in the manual.
    A heavy dado set can bend the shaft. A $500 repair.
    WWFD
  14. #13
    DQ
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    474
    Visit Freq
    1.23 visits/week
    Threads
    Classifieds
    I had not read about that when I was researching Sawstop saws. The manual does tell you not to use blades over a certain thickness because they would take longer to stop and they tell you not to use blades that are too thin because they may not be structurally up to the stresses imposed when the brake fires. I don't remember reading anything about dado blade weight. Do you know what the cut-off weight is for a dado blade?
    Pete
    Pete - KD4CQZ
  15. #14
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,484
    Visit Freq
    6.96 visits/week
    Threads
    734
    Classifieds
    No, I just know the solid body blades add up to too much, you have to use the ones that are cut away like two wings.
    WWFD
  16. #15
    DQ
    tarheelz's Avatar
    Nickname
    Dave (45)
    Join Date
    Sep 2012
    Location
    Durham, NC
    Posts
    918
    Visit Freq
    5.15 visits/week
    Threads
    61
    Classifieds
    This is now in the manual. (I bought an Oshlun fully body set for my SawStop before realizing I couldn't use it. Fortunately, Wayne from Mocksville swapped me his Freud wing chipper set.)
  17. The following 2 users say Thank You to tarheelz :
Similar Threads
  1. Jointer alignment
    By TDeal in forum General Woodworking
    Last Post: 01-07-2012, 07:21 AM
  2. Table Saw blade alignment
    By rotel in forum Power Tools and Their Use
    Last Post: 01-31-2011, 10:24 AM
  3. alignment solution
    By jmauldin in forum "How To" Forum
    Last Post: 04-25-2008, 09:31 PM
  4. Bandsaw Blade Alignment Fun
    By WoodWrangler in forum General Woodworking
    Last Post: 04-24-2007, 03:02 PM
  5. Alignment Fun ?
    Last Post: 10-15-2006, 03:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
