West Penn Hardwoods (Ad 2)
Results 1 to 10 of 10
  1. #1
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    269
    Visit Freq
    5.77 visits/week
    Threads
    Classifieds
    Too much sanding?
    White Oak. Sanded 150, then 180, then 220 and then 340 before staining.
    Stained and found 2-3 spots that I missed, there were pretty obvious scratch marks. So after it dried, I sanded the finish off and started sanding again, this time at 220, then 340.
    Re-stained, and it seems to be taking forever to dry. Stained about lunch time Saturday. Sunday evening it is still a bit tacky. It is in the heated shop at about 73 degrees.
    Stained some other boards [at the same time as the top] that I only sanded to 220 and they are nice and dry. Thoughts? Too much sanding or could the previous stain that I sanded off somehow be affecting it?
    Either way,I think it looks nice!
    Do you think the poly will have problems adhering to the surface?
    Attached Images Attached Images
  2. #2
    User Wyatt Co.'s Avatar
    Nickname
    Join Date
    Aug 2017
    Location
    Calypso, NC
    Posts
    404
    Visit Freq
    6.27 visits/week
    Threads
    Classifieds
    Re: Too much sanding?
    It does look nice I must say. I'll also say that it's not necessarily too much sanding but way too fine a grit. It just isn't necessary. We like to feel that ubber smooth surface before finishing but 180 grit before finishing is all it takes. The smoothness comes from the finish itself.
    Besides, too much sanding leaves a horrible uneven surface even though it feels good to the touch.
    [edit], The poly is a chemical bond. You'll be fine. The humidity is keeping your stain from drying. Just give it more time.
    Happiness is a direction not a destination. ~Athena Orchard
  3. The following user says Thank You to Wyatt Co. for this useful post:
  4. #3
    Staff Advisor
    DQ
    Joe Scharle's Avatar
    Nickname
    Joe (75)
    Join Date
    Sep 2005
    Location
    New Bern, NC
    Posts
    5,471
    Visit Freq
    5.54 visits/week
    Threads
    684
    Classifieds
    No expert here, but I always stop at 220. I knock finishes down with 320 between coats.
    Always be yourself because the people that matter don't mind, and the ones who mind, don't matter.
  5. The following user says Thank You to Joe Scharle for this useful post:
  6. #4
    Board of Directors
    Vice President
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    4,990
    Visit Freq
    2.92 visits/week
    Threads
    270
    Classifieds
    David,
    Did you use something to fill the pores?
    If so, then I agree that the stain may simply need more time to dry.
    People are amazed as a shaving rises from the throat of a plane as if itís a spell plucked from a sorcererís hand Ė Paul Sellers
  7. The following user says Thank You to Hmerkle for this useful post:
  8. #5
    Nickname
    Join Date
    Jul 2016
    Location
    Four Oaks, NC
    Posts
    269
    Visit Freq
    5.77 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Hmerkle View Post
    David,
    No, I didn't fill the pores. Just sanded, stained, saw that it wasn't sanded good enough in 1-2 spots [had some cross grain scratches], so I sanded the stain off and started over. .
    I checked it this morning and it seemed pretty dry. I put it closer to the mini-split and set the blade so that it didn't swing and was pointed towards it. I think it will be ready for some assembly/poly this evening.
    Thanks!
  9. #6
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,368
    Visit Freq
    6.92 visits/week
    Threads
    574
    Classifieds
    Yes, you've sanded too much and that wasn't necessary either. Here's my hypothesis to consider. Even though a pigment stain is on the surface it still needs to penetrate a bit and oversanding effectively burnishes the surface making it less permeable. So the stain and the petroleum solvents sit on the surface and are slow to dry.
    Be patient, it'll dry in time.
  10. The following 2 users say Thank You to Jeff :
  11. #7
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,072
    Visit Freq
    6.62 visits/week
    Threads
    76
    Classifieds
    I think when you re-sanded you may not have gotten off all the old stain. Oil-based stain can be slow to dry when it can't fully penetrate the wood. Much like putting it on a finished surface.or putting it on too heavy. As for sanding, I have found that the finer grit you sand, the lighter the stain result. I have sanded white oak to 400 and gotten stain to take, but only in the softest part of the wood. Haven't had any problems with the top coats adhering or curing after the stain did dry, though.
    It does look nice.
    Practicing at practical woodworking
  12. The following user says Thank You to Gofor for this useful post:
  13. #8
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    11,688
    Visit Freq
    7.00 visits/week
    Threads
    677
    Classifieds
    By using a card scraper you avoid all those problems. Sand between coats of varnish scrape the raw wood. A scraper cuts the surface of the wood leaving a clean, smooth substrate for the varnish to adhere. Sandpaper scratches and fuzzes the surface.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  14. The following 3 users say Thank You to Mike Davis :
  15. #9
    DQ
    petebucy4638's Avatar
    Nickname
    Pete
    Join Date
    Dec 2009
    Location
    Denver, NC
    Posts
    428
    Visit Freq
    2.23 visits/week
    Threads
    Classifieds
    I gave some white oak flooring that was left over from a new home a few years back. He very precisely laminated it into a nice workbench top. Then the sanded it, finishing up with an 800 grit abrasive. What he did not realize was that once he started using a sandpaper finer than 220 grit that he was essentially burnishing the wood. When he tried to stain it, it barely took any stain and it was blotchy. After sanding it again with 220 grit, it took the stain well and produced a nice finish.
    Pete
    Quote Originally Posted by DSWalker View Post
    Pete - KD4CQZ
  16. The following user says Thank You to petebucy4638 for this useful post:
  17. #10
    Nickname
    neil
    Join Date
    Jan 2012
    Location
    Weaverville, NC
    Posts
    41
    Visit Freq
    1.04 visits/week
    Threads
    Classifieds
    I always sand to the "EYE". In other words, I focus on the grain when I sand and remove the scratches before I move to the next grit. Focus on the grain, the scratch or the "haze" and your sanding will go much better in the future. Sanding to "TOUCH" is really not enough.
    Neil
  18. The following user says Thank You to ncfromnc for this useful post:
Similar Threads
  1. Zen and the Art of Sanding
    By Bas in forum General Woodworking
    Last Post: 12-20-2016, 03:57 PM
  2. Sanding
    By Ptofimpact in forum General Woodworking
    Last Post: 07-06-2014, 12:32 PM
  3. Wet sanding vs dry sanding?
    By MikeH in forum Woodturning
    Last Post: 06-09-2012, 10:49 PM
  4. Sanding
    By PeteM in forum Finishing
    Last Post: 10-14-2009, 01:12 PM
  5. Sanding
    By cskipper in forum Scrollsaw Work
    Last Post: 09-20-2009, 10:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
