Klingspor's Woodworking Shop (Locations) Ad #1
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
  1. #1
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    441
    Visit Freq
    4.88 visits/week
    Threads
    Classifieds
    New way to quickly dry green bowls
    I chanced to watch a yall-tube turning video by a novice turner and found this idea. I tried it Friday afternoon on a 10" maple bowl which I took from fresh cut tree to the lathe within an hour. I roughed it and left only a 5/8" wall thickness.
    This method reduced the % moisture meter readings from 38 heartwood / 45 sapwood down to 6 heartwood / 15 sapwood after 24 hours. Distortion was within turnable limits and no cracks appeared.
    Since I'm way behind on roughing and drying for Christmas gifts, I plan to use this idea for a load of cherry I picked up last spring. Those bowls will be 12" to 16" and I plan to leave the walls thicker than recommended.
    I don't necessarily agree with his turning or finishing tools and methods. If you want go right to the drying method, start watching the video at 15:00 and continue until about 20:00. Give it a try with your next green utility bowl. I think you will find the results pretty interesting.
    https://www.youtube.com/watch?v=-6quzSzrMs8
  2. The following 8 users say Thank You to gritz :
  3. #2
    DQ
    jerrye's Avatar
    Nickname
    Jerry (56)
    Join Date
    Nov 2006
    Location
    Clearwater, FL
    Posts
    1,350
    Visit Freq
    6.73 visits/week
    Threads
    Classifieds
    Re: New way to quickly dry green bowls
    Is it just me, or does he sound a lot like the actor William Sanderson? I can easily hear this man saying, "Hi. I'm Larry. This is my brother Darrell, this is my other brother Darrell."
    "Trials burn away the impurities in one's character & life that good times never do." Jeff Ford
  4. #3
    DQ
    Stuart Kent's Avatar
    Nickname
    Stuart
    Join Date
    Sep 2012
    Location
    Winterville, NC
    Posts
    398
    Visit Freq
    2.54 visits/week
    Threads
    Classifieds
    very curious to know how many times he's done it and what the rate of success is...
    Stuart Kent
    Founding Director of the North Carolina Furniture School
    Robust, Rikon, Oneida, Harvey, & Easy Wood Tools Dealer
    503 Second St, Ayden, NC 28513
    252-916-8226
    http://ncfurnitureschool.com/
    https://twitter.com/@tweetncfs
    https://www.facebook.com/northcarolinafurnitureschool
  5. #4
    DQ
    Nickname
    Roy
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    817
    Visit Freq
    6.69 visits/week
    Threads
    50
    Classifieds
    Did he put some sealer on the outside of the bowl before he put the fan on the inside?
    Roy G
  6. #5
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    441
    Visit Freq
    4.88 visits/week
    Threads
    Classifieds
    He does use a sanding sealer on the outside of the piece. That's the only "traditional" thing he does.
    I just found it interesting because the piece stays in the chuck. and can be finish turned in 24 hours. I will have a couple of finished examples in a few days.
  7. #6
    DQ
    beloitdavisja's Avatar
    Nickname
    James Davis
    Join Date
    May 2016
    Location
    Charlotte, NC
    Posts
    107
    Visit Freq
    7.27 visits/week
    Threads
    Classifieds
    I'll have to give this a try. Thanks for the link.
    "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
  8. #7
    Nickname
    Bryan
    Join Date
    Mar 2017
    Location
    Matthews, NC
    Posts
    133
    Visit Freq
    2.85 visits/week
    Threads
    Classifieds
    Quote Originally Posted by jerrye View Post
    True story: I work on the same building as he does. I'm always amazed at the people who have never heard of Newheart!
  9. #8
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    441
    Visit Freq
    4.88 visits/week
    Threads
    Classifieds
    Stuart,
    I browsed his videos and found another example. While his shapes and finishes are still just giveaway quality, you do have to give him credit for thinking outside the bowl...
  10. The following 2 users say Thank You to gritz :
  11. #9
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,699
    Visit Freq
    4.58 visits/week
    Threads
    Classifieds
    It looks like hes finishing his bowls with a very heavy wall thickness, I doubt its really dry much past the surface hes measuring.
  12. #10
    Returning Member William Roscoe's Avatar
    Nickname
    William
    Join Date
    Apr 2007
    Location
    Bear Creek, NC
    Posts
    182
    Visit Freq
    0.04 visits/week
    Threads
    41
    Classifieds
    wonder if it might be even better to let it dry with the fan for 2 days?? Or even 3. I'd like it to be below 10% at least
    "Experience is that marvelous thing that enables you to recognize a mistake when you make it again" Franklin P Jones
  13. #11
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,386
    Visit Freq
    6.92 visits/week
    Threads
    574
    Classifieds
    I'm not a "turner" but I often see green wood turning of a rough bowl and then it's stored away in shavings for months, etc for slow drying before the final turning/shaping.
    I'm curious though. What do you folks consider to be adequate drying before the final turning (%MC) so that the bowl doesn't crack and blow apart? Is this guy rushing the process and will his bowls will be doomed in another year?
  14. #12
    Board of Directors
    Vice President
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    4,990
    Visit Freq
    3.00 visits/week
    Threads
    270
    Classifieds
    Quote Originally Posted by gritz View Post
    Stuart,
    I can't wait to see what level of success you have when you try it.
    It would also be interesting to see if Chris G is correct (the core of the bowl is still high moisture content.)
    Also, I am thinking (just thinking) I had some wet (not green) ambrosia maple and turned a hollow vessel in a class at Woodcraft. I questioned the teacher and he said just try it!
    He said, turn it to a finished shape, sand and finish. Years later, no cracks, little out of round!
    So based on that, if we can get the surface (to some unknown depth) down to an acceptable moisture content without the blank checking or cracking, then finish turn, maybe this works...
    Again proof is in the pudding, let's see what success Robert (Gritz)has.
    People are amazed as a shaving rises from the throat of a plane as if itís a spell plucked from a sorcererís hand Ė Paul Sellers
  15. #13
    DQ
    gritz's Avatar
    Nickname
    Robert
    Join Date
    Jan 2009
    Location
    Jasper, GA
    Posts
    441
    Visit Freq
    4.88 visits/week
    Threads
    Classifieds
    The second bowl is roughed and sitting under the fan now. It is 9 1/2" in diameter and I left the walls a little thicker, but plan to check it at 24 hours. At that point I will decide whether to leave the fan on for a longer time period.
    Here is a photo of the first bowl. I finish turned it today, but only because I was busy all day Monday and Tuesday. The fan was on for 24 hours, then it sat in the chuck on the lathe in the basement. Today the highest reading was 8% in one small section of the sapwood where I just barely shaved off the bark. The walls are 3/16" and the finish is walnut oil and wax.
    If we use the soda straw conceptualization of wood fibers, I clearly see what transpired during drying and why the sapwood had a higher moisture reading. That is where the unexposed fibers were longest on this piece. The short fibers in the heartwood gave up their moisture load pretty quickly through evaporation and capillary action. The fibers in the sapwood portions were longer and would obviously hold moisture for a longer period in any drying scenario...given equal everything else. It did dry out sufficiently for final turning with the total elapsed time of 5 days.
    To answer the question about surface drying...I have to say perhaps. Perhaps, because the piece went out of round during the turning and finishing process by less than 1/8".
    I am convinced this method has value and I plan to pursue it further while tweaking the variables. One variable I plan to try is using a denatured alcohol soak with enough air drying to allow me to seal the outside before beginning the fan drying process. I am sure the result will vary with different wood species.
    Attached Images Attached Images
  16. The following 3 users say Thank You to gritz :
  17. #14
    User cyclopentadiene's Avatar
    Nickname
    Join Date
    May 2006
    Location
    Greensboro, NC
    Posts
    621
    Visit Freq
    4.38 visits/week
    Threads
    116
    Classifieds
    If you are new to turning, I understand the desire to have a bowl dried relatively quickly so you can actually have a finished product soon. I was the same way when I first started turning. I then realized I could rough turn a green bowl and have it stored in a bag of shavings in 20-30 minutes. I completed several hundred in a short time period. After these were all dry, I selected the most unique ones and finished about 100 bowls.
    After you give one to all of your friends and family and have a dozen or so special ones sitting around the house, what do you do with them? I placed a few in a gallery and sold a dozen or so but sales are really slow as the market is saturated and I hate providing 30-50% to a gallery that does very little.
    I have about 200 dried bowl blanks of different species sitting in the rafters of my shop that are leftovers after I was booed with completing them and had bowls everywhere.
  18. #15
    DQ
    Nickname
    Stuart
    Join Date
    Sep 2012
    Location
    Winterville, NC
    Posts
    398
    Visit Freq
    2.54 visits/week
    Threads
    Classifieds
    Stuart,
    indeed!
    Stuart Kent
    252-916-8226
Similar Threads
  1. Cooling off quickly
    By cpw in forum DIY- Home improvement
    Last Post: 06-15-2010, 02:25 AM
  2. jointer blades getting nicked very quickly
    By kooshball in forum Power Tools and Their Use
    Last Post: 05-12-2010, 09:10 AM
  3. Turning Green Wood Bowls ?
    By Splinter in forum Woodturning
    Last Post: 06-04-2009, 09:59 AM
  4. Green Bowls
    By ghayes02 in forum Woodturning
    Last Post: 12-11-2008, 07:57 PM
  5. I didn't wear green for Patty's Day, But I got something green
    By michaelgarner in forum Power Tools and Their Use
    Last Post: 03-20-2007, 10:42 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
