Festool (Ad #2)
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 41
  1. #1
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    879
    Visit Freq
    5.81 visits/week
    Threads
    114
    Classifieds
    Drop Leaf Table Build
    Build for a previous thread.
    I will post pics and attach makers drawings in PDF should someone wish to do a similar project.
    Start with the lumber, Cherry with a little bit of Soft Maple
    Next is a drawing of the leg, we need four.
    I have attached parametric drawings of the exploded assembly, as well as leg pictured above in PDF
    The legs will be made by laminating 4/4 stock, three pieces to give us the desired thickness.
    The boards are ripped on the table saw
    The sides which will accept glue are jointed clean to allow a quality glue line
    Then follows the glue-up of each leg, using Tightbond Original. The boards are carefully orientated to allow the grain flow in the same direction, so we don't get tear-out when planing and also to try and hide the glue lines by selecting matching grain patterns.
    More later, will be a slow build shop time is a luxury at the moment.
    TABLE LEG.pdfexploded assembly.pdf
    Attached Images Attached Images
  2. The following 11 users say Thank You to Willemjm :
  3. #2
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    879
    Visit Freq
    5.81 visits/week
    Threads
    114
    Classifieds
    Re: Drop Leaf Table Build
    And the leg drawing
    Attached Files Attached Files
  4. #3
    DQ
    Nickname
    Bromley (30)
    Join Date
    Jun 2017
    Location
    Raleigh, NC
    Posts
    192
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Love seeing work in process, I will definitely be following this along.
  5. #4
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    879
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Look forward to seeing more!
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  6. #5
    Board of Directors
    Development Director
    DQ
    Jeremy Scuteri's Avatar
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,744
    Visit Freq
    6.38 visits/week
    Threads
    305
    Classifieds
    Looks good. I am also looking forward to more progress pics.
  7. #6
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,891
    Visit Freq
    7.00 visits/week
    Threads
    82
    Classifieds
    Good progress Willem, thanks for sharing the journey.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  8. #7
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,287
    Visit Freq
    6.92 visits/week
    Threads
    630
    Classifieds
    Copied from Willem's first thread. I was curious to compare Willem's "new & improved" table without gate legs to the old rickety one below. I don't think that there'll be any comparison but it'll be a fun build to follow an excellent craftsman.
    You will have to twist my arm to post pics of the old table, it is not in my shop.
    Here is the info though.
    Made from Rubber Wood ( Asian trees used for making latex, they get taken down at 25 years old and cut into lumber) heavily stained. The leg joints are mortise and tenon, pinned with wood screws and a terrible fit, so all the glue joints failed with the table rocking on it's legs. They used corner legs which swing out to support the leaves and for hinging these they used pieces of copper pipe. The fitting is pretty loose. The top and leaves are ply and also heavily stained. Probably something we can buy at an antique store, for around $50.
  9. #8
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,157
    Visit Freq
    7.00 visits/week
    Threads
    261
    Classifieds
    Like the others, I love following a work-in-progress thread. In the previous thread you were asking about tipping, or stability. What did you finally decide?
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  10. #9
    DQ
    LeftyTom's Avatar
    Nickname
    Tom
    Join Date
    Jun 2006
    Location
    Yadkinville, NC
    Posts
    5,985
    Visit Freq
    3.73 visits/week
    Threads
    275
    Classifieds
    is all I have to say.
    The thing that holds up all my woodworking is simply getting started.
  11. #10
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    879
    Visit Freq
    5.81 visits/week
    Threads
    114
    Classifieds
    Glue dried, first thing to square the sticks on the jointer, two sides.
    Then through the planer to get same thickness and square the other two sides
    Mark out the mortises on each leg
    Cut the mortises
    Leg into lathe
    And the first leg done. Can never figure which is the easiest, the first to get the look or the others to be exactly the same as the first.
  12. The following 2 users say Thank You to Willemjm :
  13. #11
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    879
    Visit Freq
    5.81 visits/week
    Threads
    114
    Classifieds
    A little more shop time.
    Cut the table aprons, true thickness on jointer and planer and cut to rough length. Then to perk up the look a little, a Soft Maple strip is glued to the bottom of the apron. The long sides will not be seen once done, but the short sides will look a little nicer with the Cherry ending in a white Maple bottom edge.
    Trim the Maple strip with a handplane. This is a little Victory vintage I picked up some time ago on Ebay for $15 and restored. One of my favorites, always have to find an excuse to use it.
    Next we go to the shaper to mill a little bead on the Maple edge.
    Time to cut the tenons after cutting the aprons to correct length. There are many different ways to do these, I seem to do them different every time. Using a table saw jig, this took about 20 minutes to do all the tenons.
    The shoulders and cheeks were done on the table saw with a bit of bandsaw cutting included, then the width (bandsaw cut) was trimmed with a hand chisel for an exact fit.
    And we are ready for a dry fit of the table base. Everything nice and snug. More next week.
  14. The following 6 users say Thank You to Willemjm :
  15. #12
    Administrator Corporate Member
    DQ
    Nickname
    Neal (58)
    Join Date
    Apr 2017
    Location
    King, NC
    Posts
    621
    Visit Freq
    9.08 visits/week
    Threads
    Classifieds
    Thanks for the update Willem, it is looking great!
  16. #13
    User Boomer76's Avatar
    Nickname
    Boomer
    Join Date
    May 2017
    Location
    Huntersville, NC
    Posts
    69
    Visit Freq
    1.96 visits/week
    Threads
    Classifieds
    Wow, that's looking amazing. I find it funny how just a little strip of contrasting maple really makes the aprons gorgeous.
  17. #14
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    879
    Visit Freq
    5.81 visits/week
    Threads
    114
    Classifieds
    Next is to start working on the table top and the leaves
    We select the boards for grain matching and width. For the 21" top three boards are needed based on the lumber I have and for the leaves at 17" two boards each.
    Boards are cut to length.
    The boards I have are straight enough, not to bother with face jointing. (Thx Chris, love your Cherry!!) To try and maintain as much of the board thickness available, I thickness plane only the table top faces, not concerned with the bottoms as they will be out of sight. I will do a little finishing on the underneath of the table top and leaves once glued up, but they do not have to be perfect.
    After thickness planing, the glue edges are jointed to be square with the top faces and to be glue line quality.
    The boards are placed dry into pipe clamps and a little wedge was needed to get perfect alignment somewhere in the center. Note, I do not use biscuits, dowels or anything else to align the boards. I can get perfect alignment of the three boards and a straight flat face checked with a straight edge, just using a bit of wiggle in the clamps.
    After making sure everything lines up dry and all the joint lines are nice and tight, the clamps are removed and covered with painters tape, to avoid glue corrosion on the black pipes staining the wood.
    Then one edge of each of the boards on the side is covered with glue, the boards go back into the clamps, aligned, clamped and the glue up is complete. I use moderate pressure, all we need as a snug glue line with no gaps. I use a wet cloth to wipe up the excess glue.
    Once the glue is dry, the same will be done for the leaves, then follows cleaning up the top surfaces and cutting to final length and width square.
    At this time my thickness using 4/4 is pretty much 1". Once finished, if I can get 7/8" I will be happy.
    Then follows a rule joint for the drop leaves. More later.
  18. The following 11 users say Thank You to Willemjm :
  19. #15
    DQ
    Nickname
    Bromley (30)
    Join Date
    Jun 2017
    Location
    Raleigh, NC
    Posts
    192
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Thank you very much for all the explanation and work in process pictures! As much as I enjoy seeing the final pieces, it is very helpful to see how different people approach the build process and the steps that are taken. I will continue checking back for updates, keep up the good work!
Similar Threads
  1. Double leaf table design
    By Willemjm in forum General Woodworking
    Last Post: 10-15-2017, 04:27 PM
  2. Next Project, Draw Leaf Table
    By DSWalker in forum General Woodworking
    Last Post: 09-18-2016, 08:52 AM
  3. drop leaf table to expanding table
    By tryingtokeepmyfingers in forum General Woodworking
    Last Post: 08-08-2011, 11:10 PM
  4. Fly Leaf Table WIP
    By Joe Scharle in forum General Woodworking
    Last Post: 03-05-2008, 03:14 PM
  5. Wide drop leaf table
    By Tom Dunn in forum General Woodworking
    Last Post: 05-12-2006, 11:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
