West Penn Hardwoods (Ad 1)
Results 1 to 15 of 15
  1. #1
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    308
    Visit Freq
    4.92 visits/week
    Threads
    Classifieds
    Sheet rock fasteners
    Need to put up a Small shelf 12" x 6" in closet for an Iron. No studs, small stretch between door frame and corner. Bought those plastic Zip fasteners, you supposedly Screw into sheetrock, then use a number 8 screw into plastic fastener. Any advice, suggestions?
  2. #2
    Nickname
    George
    Join Date
    Dec 2012
    Location
    Piedmont, SC
    Posts
    Visit Freq
    7.00 visits/week
    Threads
    Classifieds
    Re: Sheet rock fasteners
    Glue some wood to the wall. This will give you something solid to attach the shelf to. Much better than drywall fasteners.
    Sent from my iPhone using Tapatalk Pro
  3. The following user says Thank You to Newboy for this useful post:
  4. #3
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    6,074
    Visit Freq
    7.00 visits/week
    Threads
    258
    Classifieds
    I always prefer this type. Its called a toggler. They fold up to go through the hole, then spread when you put the screw in. Seem to give better purchase versus some of the other types.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  5. The following user says Thank You to Bill Clemmons for this useful post:
  6. #4
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,989
    Visit Freq
    6.92 visits/week
    Threads
    607
    Classifieds
    Quote Originally Posted by Ptofimpact View Post
    Are these the type that you bought? The nylon ones have "wings" that expand on the inside of the drywall; these have a 15-20 lb load capacity. The ones Bill uses are rated at 36 lbs.
    http://www.powers.com/pdfs/plastic/02345.pdf
  7. The following user says Thank You to Jeff for this useful post:
  8. #5
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,682
    Visit Freq
    6.92 visits/week
    Threads
    516
    Classifieds
    Phil, who's advice I always trust, advised me to use these "Toggler" toggle bolts to attach some grab bars to a wall with no studs available.
    https://smile.amazon.com/12-TOGGLER-...words=togglers
    They work great. Available in other sizes.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  9. The following 4 users say Thank You to KenOfCary :
  10. #6
    DQ
    Nickname
    Join Date
    Jan 2011
    Location
    Lowesville, NC
    Posts
    141
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    Is it just for the iron? Maybe a pound or two? Any possibility of heavier items in the future? If not, then the plastic fasteners are good, easier to install than the toggle type. And more forgiving if you ever need to take them out.
  11. The following user says Thank You to Brantnative for this useful post:
  12. #7
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    662
    Visit Freq
    3.77 visits/week
    Threads
    59
    Classifieds
    check out "wing-its" at your local Home Depot.
    Bottom line anything can rip out drywall.
    If you want something more permanent span a 2x3 to catch 2 studs and must make the shelf 16" instead of 12".
  13. The following user says Thank You to Rwe2156 for this useful post:
  14. #8
    DQ
    tarheelz's Avatar
    Nickname
    Dave (45)
    Join Date
    Sep 2012
    Location
    Durham, NC
    Posts
    912
    Visit Freq
    5.62 visits/week
    Threads
    61
    Classifieds
    Also from Toggler, I have used these screw-ins with great success for shelves. http://a.co/eyatwmq
    It is a real time (and accuracy) bonus that you don't need to pre-drill.
  15. The following user says Thank You to tarheelz for this useful post:
  16. #9
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (68)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,372
    Visit Freq
    9.81 visits/week
    Threads
    520
    Classifieds
    It appears the term Toggler is widely used for many different wall attachment devices.
    Many of the all plastic devices are probably fine for a lot of light applications.
    For any application that requires a questionable or heavy load I always uses the type of toggle that Hilti first brought to the market
    I have used these to mount literally hundreds of tv mounts and they are virtually the commercial standard now.
    They are available from many manufactures and I have never had a significant problem with any - some of the cheaper ones are not always tapped as well as they should be, so there is some waste with them. If I had a large project, I would get the real ones, Hilti
    Attached Images Attached Images
  17. The following 3 users say Thank You to Phil S :
  18. #10
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,143
    Visit Freq
    6.65 visits/week
    Threads
    78
    Classifieds
    One thing to consider is the thickness of the drywall. The screw in type hold well in 5/8 or 3/4, but not as well in 1/2". As for repairing the hole in the future, should you decide to remove the shelf, the screw in type aren't too much better than a regular toggle bolt. I have used both in places I have lived in and left, requiring repair of the holes.
    Practicing at practical woodworking
  19. The following user says Thank You to Gofor for this useful post:
  20. #11
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,926
    Visit Freq
    6.96 visits/week
    Threads
    205
    Classifieds
    Quote Originally Posted by Phil S View Post
    Toggler is just the brand name, so anything they design and market under that name will carry the Toggler label. But they do produce some very fine hollow wall anchoring solutions and I have used them quite a bit over the years, as well as common alternatives, but theirs often excel where you need to support more substantial loads.
  21. The following user says Thank You to ehpoole for this useful post:
  22. #12
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    308
    Visit Freq
    4.92 visits/week
    Threads
    Classifieds
    Thanks to all the great advice, the shelf is only for an iron, a few pounds, using 1/2 Baltic Birch ply fpr 12 x 6 shelf. Cannot fid any studs, as this is a short stretch of wall...between door frame and corner, just a bit ovr 12" wide.
    Have bought those Zip screw in fasteners.....was wondering about those, can I use a drill on slow to screw in??
  23. #13
    Board of Directors
    Development Director
    DQ
    Jeremy Scuteri's Avatar
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,692
    Visit Freq
    6.65 visits/week
    Threads
    303
    Classifieds
    Yes, you just screw the plastic part into the wall as if it was a self tapping screw.
  24. The following user says Thank You to Jeremy Scuteri for this useful post:
  25. #14
    DQ
    cpw's Avatar
    Nickname
    Charles (53)
    Join Date
    Nov 2007
    Location
    Forest City, NC
    Posts
    945
    Visit Freq
    1.69 visits/week
    Threads
    151
    Classifieds
    "Live like no one else, so later, you can LIVE LIKE NO ONE ELSE!"
    -Dave Ramsey
  26. The following 2 users say Thank You to cpw :
  27. #15
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    308
    Visit Freq
    4.92 visits/week
    Threads
    Classifieds
    Thanks again to all, for this little shelf the Zip fasteners worked fine, again, only holding an Iron, but also learned about other fasteners.
Similar Threads
  1. 25% Off All Fasteners
    By BKind2Anmls in forum Found for Sale/Hot Deals
    Last Post: 04-09-2014, 01:01 PM
  2. Fasteners and screws
    By shortz1lla in forum General Woodworking
    Last Post: 02-14-2013, 07:40 PM
  3. Wood Table Top Fasteners
    By Mt. Gomer in forum "How To" Forum
    Last Post: 11-30-2010, 10:18 AM
  4. MDF Fasteners Question
    By ddrdan in forum General Woodworking
    Last Post: 11-22-2006, 12:01 PM
  5. Grizzly fasteners
    By rherrell in forum Power Tools and Their Use
    Last Post: 07-18-2006, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
