West Penn Hardwoods (Ad 1)
Results 1 to 6 of 6
  1. #1
    User charlessenf's Avatar
    Nickname
    Charles
    Join Date
    Sep 2011
    Location
    Lenoir, NC
    Posts
    130
    Visit Freq
    0.73 visits/week
    Threads
    Classifieds
    Source Needed For 5ft x 10ft; or 5ft x 12ft Oversiz Plywood
    I am in Lenoir, NC and, of course, there are no sources here. Ideally, I'd like AC Sanded, but will be covering with laminate, so not critical. I know that Particle board is available in over size sheets, but moisture will be present . . .
    I've searched 'the net' and found suppliers in the Midwest, Canada, Baltimore, etc. but need two sheets max (one if I can get a five by twelve foot sheet - not a pallet load!
    Thanks for your attention.
  2. #2
    Papa Red Senior User
    DQ
    red's Avatar
    Nickname
    Red
    Join Date
    Nov 2009
    Location
    Denver, NC
    Posts
    2,300
    Visit Freq
    4.15 visits/week
    Threads
    Classifieds
    Re: Source Needed For 5ft x 10ft; or 5ft x 12ft Oversiz Plywood
    Wurth Wood Group in Charlotte may have something in the sizes you're looking for. You can give them a call at 704-394-9479. Good luck.
    Red
    Red
  3. #3
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    7,020
    Visit Freq
    6.92 visits/week
    Threads
    610
    Classifieds
    I'm curious. Why do you need oversize plywood instead of the standard 4' x 8'? Maybe piece together 4 x 8 to make it work?
  4. #4
    DQ
    Nickname
    cheryl
    Join Date
    Feb 2010
    Location
    Gibsonville, NC
    Posts
    179
    Visit Freq
    0.42 visits/week
    Threads
    Classifieds
    The Hardwood Store of NC, Inc. has 1/4" and 3/4" x 5' x 10 Marine Grade Baltic Birch.
    Thanks.
    Cheryl
  5. The following user says Thank You to cheryllewis for this useful post:
  6. #5
    Nickname
    Charles
    Join Date
    Sep 2011
    Location
    Lenoir, NC
    Posts
    130
    Visit Freq
    0.73 visits/week
    Threads
    Classifieds
    The Hardwood Store of NC, Inc. has 1/4" $94.00 and 3/4" x 5' x 10 Marine Grade Baltic Birch. $159/sheet
    https://hardwoodstore.com/hardwood-plywood
    Thanks for the source.
    I appreciate the piece it together suggestion and planned on doing just that - on the first layer. I was, however, hoping I could get both my countertops out of a single sheet of 5 x 12 (each has a ninety degree turn on the short (<60") leg) to get both tops covered by a single sheet of goods to provide the best surface for adhering the laminate. When I finally got the cabinets installed, the ten foot looked a bit shy of the mark because the base corner cabinets sport a diagonal front which increases their effective depth in excess of the 'standard' 24" and I need to sharpen my pencil since I cannot find anything in twelve foot lengths.
    Having had Post Formed Countertops that succumbed to moisture flaking and swelling, I'd hoped to build something out of plywood that would last more than the five years experienced with the top in the home I last purchased. Replacing a countertop too often involves the 're-do' of the entire kitchen and I don't think I'll have it in me to do this (for you) again (dear).
    Any good approaches to 'seamlessly' joining sheets of plywood?
    Thanks for the feedback.
    Last edited by charlessenf; 10-11-2017 at 01:02 AM. Reason: added a URL for source referenced
  7. #6
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,778
    Visit Freq
    4.42 visits/week
    Threads
    Classifieds
    A good friend of mine has a custom countertop fabrication shop up in New York where I used to live. I had helped him make a few as well as my own for my last house. The proper material to use is 3/4 "particle board. The main reason is its nearly dead flat and extremely smooth when you buy it. As for joining it, you simply glue a backer strip at the joints, about 4 " wide and he would fill in any voids with bondo and sand it smooth prior to laminating it. He would also add a similar backer strip around the perimeter edges and anywhere it was to contact the cabinet tops. I just recently made a couple here for a friend and they turned out great this way.
Similar Threads
  1. Hardwood Plywood source.
    By Griffin_NC in forum Where Can I Find, Buy or Sell
    Last Post: 04-05-2016, 06:07 PM
  2. Source Needed for "Pre-Finished (2-sides) Maple Plywood" in Lenoir, NC Area
    By charlessenf in forum Where Can I Find, Buy or Sell
    Last Post: 10-14-2015, 12:22 AM
  3. Plywood source in Durham?
    By dave in forum Wood
    Last Post: 08-14-2012, 09:01 PM
  4. Cedar source needed
    By ss600r in forum Wood
    Last Post: 04-24-2012, 09:37 AM
  5. Plywood source
    By Ray Martin in forum Found for Sale/Hot Deals
    Last Post: 04-09-2010, 12:44 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
