Klingspor's Woodworking Shop (Locations) Ad #1
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 44
  1. #1
    Nickname
    Nick
    Join Date
    Jan 2016
    Location
    Rock Hill, SC
    Posts
    137
    Visit Freq
    5.35 visits/week
    Threads
    Classifieds
    What is your weakness?
    I have come to the conclusion that finishing is my kryptonite.
    I avoid it and I have zero discipline when it comes time to do all of the finish sanding and application of varnish, shellac, etc. Often times my projects will sit for extended periods as I put off the only part that makes me want to leave my shop early. I've decided I need to do something about it but I'm just not sure what that is yet.
    I made the decision recently to make a serious attempt at elevating all of my skills and truthfully none of that will matter if I am still wretched at varnishing.
    So, what is YOUR weakness? Which step in the process drags you down like varnish drags me down? I'm curious what others find interesting/uninteresting because I think it says something about the person. It's obvious that my hatred for finishing points out my impatience.
  2. The following 2 users say Thank You to NTCook :
  3. #2
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (67)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,148
    Visit Freq
    10.00 visits/week
    Threads
    498
    Classifieds
    Re: What is your weakness?
    My weakness is definitely cleaning the shop and putting tools back where they belong.
    Every once in a while, I will get up real early, like 2 AM, put all the tools away and sweep and dust everything.
    That normally happens when I am about to host a workshop.
    But it never seems to last very long - If I only have an hour or so to work in the shop I would much rather spend the entire time building and I always say I will clean up and get organized tomorrow. Maybe when I retire I will change my habits - right, sure I will
    Nick, I used to hate finishing too as so many do and if I was varnishing I would still hate it. For small project, I pad on shellac typically in the house watching whatever is on TV. For anything large or if I need something done right now, I spray lacquer. I am quite sure I could have a project sealed, sanded, three coated and out the door before I could have brushed on one coat. And that includes cleaning the gun which takes only a couple of minutes. If you have not started spraying yet, try it.
  4. The following 4 users say Thank You to Phil S :
  5. #3
    DQ
    pcooper's Avatar
    Nickname
    Phillip Cooper (56)
    Join Date
    Dec 2006
    Location
    Maiden, NC
    Posts
    643
    Visit Freq
    6.77 visits/week
    Threads
    Classifieds
    Finishing is also my weakness, and I also try to avoid it. I've tried all kinds of methods, including spraying as Phil suggests, and still don't like doing it. My next weakness is cleaning the shop...and for that I try to apply a rule of put away ten things every time you come into the shop. Now if there are ten things to put away...that means I left things out. Maybe it should be put stuff away when done? I'm sure I am no different than others, I'd rather be making something than cleaning or putting stuff away, so I guess that runs as first place with finishing...
    Today a pile of wood, tomorrow a pile of sawdust......
  6. #4
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,645
    Visit Freq
    6.96 visits/week
    Threads
    76
    Classifieds
    I hate finishing too. I really do, I can't tell you how many things I've left unfinished for a week or more because I hate finishing so much. It's not because I can't do it well, it's because sometimes I can't decide on "the how" I'll finish it. I make split second decisions all the time at work, but seem to toil over the most routine task of the woodworking project.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  7. #5
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    5,901
    Visit Freq
    6.96 visits/week
    Threads
    251
    Classifieds
    I'm w/ Phil when it comes to cleaning the shop. Dread it! I'll procrastinate until I start tripping over scraps laying on the floor. In fact, I sometimes think that's the main reason I host the workshops: it forces me to clean up. I'm like Phil in that regard, except for the 2 AM part.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  8. #6
    DQ
    ErnieM's Avatar
    Nickname
    Ernie (73)
    Join Date
    Jun 2008
    Location
    Chocowinity, NC
    Posts
    1,500
    Visit Freq
    6.69 visits/week
    Threads
    195
    Classifieds
    I'm a woodworking slob. Whenever I'm done with a tool, or a brush, or my glasses, or anything else that isn't permanently attached to my body, I drop it onto the nearest horizontal surface. As a result, I'm always saying "where'd I put that thing?" After an hour of working, my shop looks like it was attacked by Irma. Unfortunately for me, I hate working in a messy shop - so I clean up at least three times a day.
    Due to my messy work methods, the activity I hate the most is turning on the lathe. I only use the lathe a couple of times a year when I have to turn harpsichord legs. In fact, I'm writing this post now because I have to turn four legs today and I'm putting it off as long as possible. I hate the mess - shavings all over the place. I cringe when I have to walk over the confetti I've created, so I'm forced to clean up every 1/2 hour or so. That doesn't bother me 'cause if I'm cleaning up, I'm not turning. I suppose it would help if I had some turning skills, but I don't. Some of my instruments have up to 14 legs, and I'm amazed that they end up resembling one another. I'm in awe of master turners like Charlie with his segmented bowls. If I had to spend eight hours a day at the lathe, I would be absolutely suicidal. Did I mention I don't like turning?
    www.ernestmillerharpsichords.com
    "A lot of people are afraid of heights. Not me, I'm afraid of widths."
    -Steven Wright.
  9. #7
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,203
    Visit Freq
    6.92 visits/week
    Threads
    231
    Classifieds
    Quote Originally Posted by Phil S View Post
    ... if I need something done right now, I spray lacquer. I am quite sure I could have a project sealed, sanded, three coated and out the door before I could have brushed on one coat. And that includes cleaning the gun which takes only a couple of minutes. If you have not started spraying yet, try it.
    I too have finishing as my (singular - ha!) weakness. But the good news is that I took Phil's Spray Finishing Workshop in the Spring and built the confidence to make a go of it. He was very convincing. In fact just this weekend I sprayed a shellac seal coat on a project for the first time. I still have much to learn, based on the cloud of finish left in the air upon completion. I have taken the plunge and will not turn back!
    Henry W
    Prolific creator of sawdust, and sometimes shavings - with the occasional completed project.
  10. #8
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    763
    Visit Freq
    6.50 visits/week
    Threads
    Classifieds
    Quote Originally Posted by NTCook View Post
    You should keep an eye on the board and attend one of the finishing classes we give from time to time. With a small investment in a compressor and a spray gun, it will no longer be a challenge.
  11. The following user says Thank You to Willemjm for this useful post:
  12. #9
    DQ
    SteveHall's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Apex, NC
    Posts
    563
    Visit Freq
    6.96 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Willemjm View Post
    What's the general consensus here for minimum compressor size to spray? Or are the all-in-one kits (Fujispray, Titan, Apollo, Wagner, Harbor Freight) now a good alternate?
  13. #10
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,386
    Visit Freq
    6.92 visits/week
    Threads
    574
    Classifieds
    I like the Earlex HVLP systems for a basic introduction to spray finishing. They're not as finicky, high tech, or as pricey as a Fuji system.
    http://www.earlex.com/earlex-hvlp-spraystation-hv5500/
  14. The following user says Thank You to Jeff for this useful post:
  15. #11
    DQ
    Nickname
    Daniel
    Join Date
    Apr 2015
    Location
    Clayton, NC
    Posts
    643
    Visit Freq
    5.73 visits/week
    Threads
    Classifieds
    +1 to finishing. I won an entry level sprayer, but first time I tried to use it I spent an hour trying to thin the paint according to the instruction book, and could never get it to flow the rate it said, so gave up and brush painted.
    On another note, guess I'm a little different, in that I try to keep my shop clean, and put away stuff when I'm done. I have small area to work in, and when I want to do something I don't want to spend an hour cleaning so I try to be good in cleaning when I'm done.
  16. #12
    User Wyatt Co.'s Avatar
    Nickname
    Join Date
    Aug 2017
    Location
    Calypso, NC
    Posts
    406
    Visit Freq
    6.27 visits/week
    Threads
    Classifieds
    #### bent on precision. Coming from a machinist background, it helps and hurts at the same time. Achieving precision isn't the problem. Being precise where it doesn't matter is. I'm afraid that if I let one area go as "close enough", I'll begin to make sacrifices in areas that can't be "close enough". This slows me down and creates efficiency issues.
    In my shop, 1/32 is horrifically off. 1/64 is doable on some things after some deep breaths and putting blinders on.
    My table saw sled is off .003" at 93" using the 5 cut method.
    Happiness is a direction not a destination. ~Athena Orchard
  17. #13
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    763
    Visit Freq
    6.50 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Wyatt Co. View Post
    LOL, I cut my career teeth as an Automotive Engineer with Mercedes Benz, spending months in Stuttgart with a big German fella slapping me around because I was a couple of thousands off with a hand file. Had the same problem as you until I learnt that if I leave the shop door open too long, a piece of accurately milled wood will be +1/16" one day and - 1/8" a few days later without touching it.
  18. The following user says Thank You to Willemjm for this useful post:
  19. #14
    Nickname
    Join Date
    Aug 2017
    Location
    Calypso, NC
    Posts
    406
    Visit Freq
    6.27 visits/week
    Threads
    Classifieds
    I know right! Which brought me to keeping my shop humidity within a specific/desired range.
  20. The following user says Thank You to Wyatt Co. for this useful post:
  21. #15
    User Richo B's Avatar
    Nickname
    Richo
    Join Date
    May 2015
    Location
    New Bern, NC
    Posts
    368
    Visit Freq
    1.92 visits/week
    Threads
    Classifieds
    Finishing and clean-up aren't my problems at all. I have to clean up my shop if I want to get my car back in the garage or keep my wife from having asthma. One of my biggest weaknesses is math. Always has been. Doing measurement calculations is hard for me. Unlike so many on the forum I don't come from an engineering, science or machinist background. Luckily I found an app for fractions that I can use. Makes it go by so much easier. That and checking measurements more than once. I have made so many mistakes with marking something a certain distance shorter than it was supposed to be. I've done this at work for years and do it in my hobby time as well. I'm learning to check and not to waste material.
  22. The following user says Thank You to Richo B for this useful post:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
