West Penn Hardwoods (Ad 2)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
  1. #1
    DQ
    LocoWoodWork's Avatar
    Nickname
    Join Date
    Mar 2016
    Location
    Maysville, NC
    Posts
    215
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    Anyone familiar with a "Bucyrus" wood lathe
    I'm looking at an old lathe which is branded Bucyrus. I cannot find any info on the company or quality of their tools. I've attached a few pics. Any guidance will be appreciated.
    Attached Images Attached Images
    ďA society grows great when old men plant trees whose shade they know they shall never sit in".
  2. #2
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,920
    Visit Freq
    6.85 visits/week
    Threads
    176
    Classifieds
    Re: Anyone familiar with a "Bucyrus" wood lathe
    Bucyrus was a mining machinery manufacture that later merged with another company and became Bucyrus-Erie. They made all kinds of machinery, including some really mammoth sized steam shovels etc. Some of those huge machines had a small machine shop to make repair parts. The lathe may be something they made to outfit the tool rooms.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  3. The following user says Thank You to sawman101 for this useful post:
  4. #3
    Nickname
    Join Date
    Nov 2005
    Location
    Apex, NC
    Posts
    5,844
    Visit Freq
    5.92 visits/week
    Threads
    963
    Classifieds
    Quote Originally Posted by sawman101 View Post
    Bucyrus was a mining machinery manufacture The lathe may be something they made to outfit the tool rooms.
    Most likely in the pattern shop for casting models.
  5. #4
    DQ
    Nickname
    Join Date
    Mar 2016
    Location
    Maysville, NC
    Posts
    215
    Visit Freq
    6.15 visits/week
    Threads
    Classifieds
    I have never owned a wood lathe before. I do like old machines and this one appears to be a solid one. I can get the lathe for $250 and add a motor. My issue is not wanting to get something that I can't use. Is a pattern lathe only capable of making certain items or will I be able to turn a variety of projects?
    Thanks
  6. #5
    DQ
    mkepke's Avatar
    Nickname
    Join Date
    Nov 2005
    Location
    Fuquay Varina, NC
    Posts
    1,326
    Visit Freq
    1.65 visits/week
    Threads
    115
    Classifieds
    Unless you have a specific need for that lathe - turning really long things or pattern making - I would suggest passing as a 'first lathe'. Here are the issues as I see them:
    1) from the picture, this is a big old lathe so oddball spindle threading and tapers are likely. If the lathe doesn't have fairly common threads and tapers, you won't be able to use the plethora of common hobby accessories like scroll chucks and drive centers without engaging the services of a machinist to make adapters.
    2) the lathe doesn't appear to pulleys for the spindle. If so, you'll need a step pulley to change speeds, unless you go with a VFD and 3ph motor. Fitting a step pulley to what could be an oddball spindle could be expensive. The VFD - maybe $150. You're looking at $100-200 for a motor either way.
    3) the design of the headstock with the caps on the bearings surfaces and the protrusions in the castings below the spindle makes me suspicious that this lathe has babbit bearings. If true, babbit bearings - while excellent if maintained - do require regular maintenance with oiling, etc. If the bearings have not been maintained, you get to learn how to refurb babbit.
    4) if you're planning conventional woodturning, you'll have to come up with some way of mounting tool rests. The cross-slide arrangement the lathe has now is excellent for precision lathework - does the lathe come with toolholders? - but typical woodturning is not precision woodturning. You'll probably want to buy/find a conventional lathe banjo to fit to the lathe.
    Here's a pretty good video explaining the issues. Pay particular attention for each time the commentator mentions that he had to adapt or change something for conventional woodturning...
    https://www.youtube.com/watch?v=OLJOOuHdge0
    None of these issues can't be overcome, but collectively it represents a lot of time and money for a would-be hobby woodturner before you can make the lathe act like a $250 (with coupon!) Harbor Freight lathe.
    -Mark
  7. #6
    Board of Directors
    Vice President
    DQ
    Michael Mathews's Avatar
    Nickname
    Michael (55)
    Join Date
    Mar 2012
    Location
    Chapel Hill, NC
    Posts
    1,449
    Visit Freq
    5.35 visits/week
    Threads
    144
    Classifieds
    Steve, instead of messing with this thing, you can pickup a new, benchtop lathe for comparable cost! It's a great place to start, plus everything is new and ready to plug in and get spinning!
  8. #7
    User awldune's Avatar
    Nickname
    Sam
    Join Date
    Jul 2012
    Location
    Durham, NC
    Posts
    197
    Visit Freq
    6.00 visits/week
    Threads
    Classifieds
    Kind of like an antique sawmill when what you need is a table saw. Very cool machine though.
    If you want an old lathe that is more useful to you, you might keep an eye out for old Delta Rockwell lathes such as the 1460:
    http://vintagemachinery.org/photoind....aspx?id=14417
    This has modern, standard fittings for accessories. They are not terribly uncommon if you watch for them.
  9. #8
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,683
    Visit Freq
    6.88 visits/week
    Threads
    516
    Classifieds
    Also, that looks to me to be a metal lathe and not a wood lathe. I tend to agree with Mark's assessment that it will have non-standard (for wood turning) fittings and threads and end up being more trouble than its worth. But you makes your choices and takes your chances.
    As Michael mentions, you can pick up a new Rikon benchtop lathe for about the same price with the motor. If you can wait until October for the Klingspor Extravaganza in Hickory then all of that kind of equipment will be on sale there. If not Penn States Industries has some very nice small lathes via mail-order.
    I don't believe in Astrology. I'm a Sagittarius and we're skeptical.
    "May the grain be with you" - Roy Underhill
  10. #9
    Nickname
    Sam
    Join Date
    Jul 2012
    Location
    Durham, NC
    Posts
    197
    Visit Freq
    6.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by KenOfCary View Post
    It is a pattern maker's lathe, for making very precise wooden patterns for metal casting. For example, in the old days you might make a pattern for the body of a fire hydrant on this lathe.
    Also with a longer bed you could make porch columns or bedposts on this lathe. The carriage will make the edges perfectly straight.
  11. The following user says Thank You to awldune for this useful post:
  12. #10
    Nickname
    Join Date
    Oct 2014
    Location
    Raleigh, NC
    Posts
    Visit Freq
    2.31 visits/week
    Threads
    Classifieds
    For what it is worth, It is correct that Bucyrus was a steam shovel manufacturer originally located in Bucyrus, Ohio. They did merge with the Erie Steam Shovel Company to form Bucyrus-Erie. They were both a construction equipment and mining machinery manufacturer and of the early B-E shovels were used to dig the panama canal. The company later moved to South Milwaukee Wisconsin and operated as Bucyrus Erie for a long time. Sometime in the late 1990's I think they shortened the name to Bucyrus. Then in about 2008 Caterpillar bought them and the products and company are now branded CAT.
    It was my first job out of college working for Bucyrus Erie.
    Many of their parts were cast out of iron or steel and then machined for the part. So, although I would not be able to comment on the lathe itself, there is no doubt they had pattern shops making wood parts for cast molding.
    Great memories for me. Glad to see the name again.
  13. #11
    DQ
    JackLeg's Avatar
    Nickname
    Reggie
    Join Date
    May 2007
    Location
    Albemarle, NC
    Posts
    5,073
    Visit Freq
    2.77 visits/week
    Threads
    403
    Classifieds
    Many a Bucyrus 15 and 20B Dragline worked on drainage projects in eastern North Carolina. The 20B was probably the most popular machine in its time.
    "The American Republic will endure until politicians realize they can bribe the people with their own money!" Alex de Tocqueville"
  14. #12
    Nickname
    Join Date
    Nov 2005
    Location
    Apex, NC
    Posts
    5,844
    Visit Freq
    5.92 visits/week
    Threads
    963
    Classifieds
    Quote Originally Posted by JackLeg View Post
    ,T A Loving owned a butt load of them, most bought surplus right after WWII. They came with a Perkins diesel, which ran the same speed, only louder under load. They could be set up as cable operated back hoes, with a 14,000 bucket, drag line with 120" boom, or crane.
  15. #13
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,288
    Visit Freq
    7.00 visits/week
    Threads
    720
    Classifieds
    I would love to have a lathe like that if I had room for it..
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  16. #14
    DQ
    Nickname
    Gene
    Join Date
    Oct 2016
    Location
    Winterville, NC
    Posts
    353
    Visit Freq
    6.77 visits/week
    Threads
    Classifieds
    I'm with Mike on that.
  17. #15
    DQ
    Nickname
    Gene
    Join Date
    Oct 2016
    Location
    Winterville, NC
    Posts
    353
    Visit Freq
    6.77 visits/week
    Threads
    Classifieds
    Quote Originally Posted by awldune View Post
    Put a treadmill motor on my 1640 for VSD.
Similar Threads
  1. Anyone familiar with "WT" brand machinery?
    By Carl Fisher in forum General Woodworking
    Last Post: 06-06-2014, 10:28 PM
  2. "S" Shaped or Curved Bowl Rest for Jet1442 Lathe
    By Flute Maker in forum Woodturning
    Last Post: 03-22-2012, 07:01 AM
  3. 1/2" pin mandrel for wood lathe
    By Truefire in forum Power Tools and Their Use
    Last Post: 08-09-2011, 08:57 PM
  4. Jet 14" x 42" VS PRO Wood Lathe with Legs - $500
    By zapdafish in forum Found for Sale/Hot Deals
    Last Post: 04-28-2011, 07:10 PM
  5. 3/8-1/2" surfaced "white wood" around Raleigh?
    By CarvedTones in forum Wood
    Last Post: 12-07-2008, 11:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
