West Penn Hardwoods (Ad 1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
  1. #1
    User Richo B's Avatar
    Nickname
    Richo
    Join Date
    May 2015
    Location
    New Bern, NC
    Posts
    368
    Visit Freq
    1.92 visits/week
    Threads
    Classifieds
    Plywood vs. solid wood
    This is of course is an old question but I'm asking it in reference to a specific project I'm gearing up to start.
    I'm going to make a rolling caddy for helping me both at home and at work.
    The idea behind it is to have something that is only about 28" high to hold tools while I'm either working at my bench at home or working on large pieces of furniture at work such as a sideboard or sofa on sawhorses. My caddy would feature a chisel box in the back in which chisels and other handled tools could fit into slots. This would resolve an issue I discovered at home when I cut my hand reaching under my bench top with a chisel fitted through the dog holes. The chisel box will be self-contained with a top that can be removed in order to clean it out from time to time. Then there is a 2 inch deep tray on top to place tools and a cubby-hole below that. Then there are two drawers for storing additional tools. One thought I had was to use one of the drawer slots to hold the rabbet plane box I've been meaning to make. It actually would become a special plane box that would hold not only the rabbet plane but also the two router planes, shoulder planes and the small trim plane. This is not meant to be a tool box as I already have that. This is something to hold various tools at the level in which I am working so I'm not placing them on the workbench or the floor.
    Originally I had planned to do this with EW Pine but the dimensions of each side of the caddy (15 x 28") require that if using the solid wood that I must join two pieces together for each side, as I tend to use 12" wide boards. So then I was considering doing this with plywood which was what I had considered originally. I should state that this is not a fancy woodworking project. I'm not looking to make something that will win a beauty contest or last for generations. My wife has full permission to "throw" my stuff out in the trash if I die before her. What I am looking to build is something that I can use at home but take to work if I need it there. Eventually I may make something for use at work but time is not something I have a lot of what with covering not only my work schedule but several other positions as well. There just isn't time for pleasure projects there. So the question is would plywood be heavier than EWP solid wood? Secondly can one make the carcass of the plywood and make the shelves and other parts of solid wood? In other words can they be combined and co-mingle?
    Attached Images Attached Images
  2. #2
    DQ
    Graywolf's Avatar
    Nickname
    Richard
    Join Date
    Dec 2010
    Location
    High Point, NC
    Posts
    477
    Visit Freq
    5.15 visits/week
    Threads
    Classifieds
    Re: Plywood vs. solid wood
    Richo, either option are solid. I look at this way, which material do you have that will do the job and that will cost the least amount of money and will deliver the product you want. That's it. They each have their pros and cons so that leaves the ball in your court and I for one want to see pics of the finished product.
    Nothing beats a try but a failure, failure is an opportunity to learn.
    http://graywolfwoodworks.wordpress.com/
  3. The following 2 users say Thank You to Graywolf :
  4. #3
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    5,901
    Visit Freq
    6.96 visits/week
    Threads
    251
    Classifieds
    For a shop project like that I would definitely go w/ plywood. Probably the birch veneer, or Sandply. You won't have to worry about wood movement and it will be very sturdy.
    And yes, plywood and solid wood can certainly be combined. I often cover a plywood edge w/ a strip of solid wood. In this cart you could easily use solid wood for the drawer fronts, or the top.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  5. The following user says Thank You to Bill Clemmons for this useful post:
  6. #4
    DQ
    Raymond's Avatar
    Nickname
    Raymond (64)
    Join Date
    Jul 2012
    Location
    Charlotte, NC
    Posts
    1,757
    Visit Freq
    7.00 visits/week
    Threads
    59
    Classifieds
    A question about the design, Richo. If this rolling caddy is going to be transported between shop and work, I assume you will be rolling this into a van or truck an that it will be secured while being transported. I would still worry about the occasional hard bumps that bounce our vehicles and some of the shorter length chisels could bounce out of the the box. What about a hinged top on the caddy to help hold down the chisels? Just my my $0.02.
    I like making things. I have a wood shop at home. I am a terrible carpenter but I love doing it. Raymond - Charlotte, NC
  7. The following user says Thank You to Raymond for this useful post:
  8. #5
    DQ
    Jim M.'s Avatar
    Nickname
    Woody
    Join Date
    Mar 2007
    Location
    New Church, VA
    Posts
    1,645
    Visit Freq
    6.96 visits/week
    Threads
    76
    Classifieds
    I'd make the cases out of plywood and the shelves, top and drawer faces out of solid wood. I made similar cart for a friend's wife for her sewing machine. I painted the plywood with a thinned down red water-based latex enamel paint, almost like a stain, put a clear Waterlox to seal it and the maple top and shelf and it looked great.
    Measure twice... cut once... SCREAM LOUDLY... get another board
  9. The following user says Thank You to Jim M. for this useful post:
  10. #6
    Nickname
    Richo
    Join Date
    May 2015
    Location
    New Bern, NC
    Posts
    368
    Visit Freq
    1.92 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Raymond View Post
    Remember this isn't a tool box so the chisels won't be in it for storage or transport. They only exist in the caddy while working on something. And it could be screwdrivers or other handled tools as well. As for transport it will be thrown in the back of my Kia Sportage and transported that way.
    I made a stool years ago out of plywood and have taken that to work many times for this sort of use because it has a shelf under the seat. Got plans from Family Handyman. I'm thinking the caddy will be in the same league as that stool was so sounds like plywood can be a winner. This is supposed to be a quick summer project. Its hot out in the garage down here in Coastal Carolina and I don't want to be messing around with dovetails or other fancy joinery. I leave that stuff for the other less hot months.
  11. #7
    DQ
    Willemjm's Avatar
    Nickname
    Willem
    Join Date
    Dec 2011
    Location
    Pinehurst, NC
    Posts
    763
    Visit Freq
    6.46 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Bill Clemmons View Post
    +100
  12. #8
    DQ
    Stuart Kent's Avatar
    Nickname
    Stuart
    Join Date
    Sep 2012
    Location
    Winterville, NC
    Posts
    398
    Visit Freq
    2.54 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Graywolf View Post
    couldn't have said it better
    Stuart Kent
    Founding Director of the North Carolina Furniture School
    Robust, Rikon, Oneida, Harvey, & Easy Wood Tools Dealer
    503 Second St, Ayden, NC 28513
    252-916-8226
    http://ncfurnitureschool.com/
    https://twitter.com/@tweetncfs
    https://www.facebook.com/northcarolinafurnitureschool
  13. The following user says Thank You to Stuart Kent for this useful post:
  14. #9
    Nickname
    Join Date
    Mar 2008
    Location
    Rougemont, NC
    Posts
    6,386
    Visit Freq
    6.92 visits/week
    Threads
    574
    Classifieds
    I'm not disagreeing with all of the recommendations.
    Yes, 3/4" BB ply vs 3/4" EWP is heavier, but 1/2" t BB ply is about the same weight as 3/4" EWP.
    A single 28 x 15 panel side...
    Lbs. 3/4"
    1/2"
    EWC 4.6
    BB 7.2 4.7
    It doesn't have to be built like a tank for your dual use/locations so be kind to your back and make it a lightweight item. Sure, you can mix and match ply with solid wood.
  15. #10
    Nickname
    Richo
    Join Date
    May 2015
    Location
    New Bern, NC
    Posts
    368
    Visit Freq
    1.92 visits/week
    Threads
    Classifieds
    Jeff - that is some very useful information you posted there. I'll have to jot that down. I think what I will do is have the sides and back be plywood and the rest of it will be EWP. There will still be some weight but I don't want to deal with joining sides of EWP and it needs to be somewhat rugged on the outside edges. Also I don't really want to be finishing those large surfaces of the exterior.
    Thanks for all the helpful information.
  16. #11
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    498
    Visit Freq
    4.42 visits/week
    Threads
    Classifieds
    I''ll also pile on to what others have said about plywood being preferred. Assuming solid lumber will be the same moisture content as plywood will be a flawed assumption. Stuff from the big box stores is generally 15%. An 11-1/4" piece of pine will dry down to household 8% and lose maybe a 3/16" of width. On a coset shelf this is no big deal, but when parts are joined at right angles and constrained by other components, there's always going to be a high risk of shrinkage problem with off-the-rack wood. Letting the wood sit in a controlled environment or several months will usually decrease the risk some.
    The advantage of solid lumber is that your joinery doesn't have to be as precise. Misaligned joints can be scrubbed even with a belt sander or hand plane.
  17. #12
    Nickname
    Richo
    Join Date
    May 2015
    Location
    New Bern, NC
    Posts
    368
    Visit Freq
    1.92 visits/week
    Threads
    Classifieds
    I started this project last weekend. I went with almost entirely plywood construction. I was able to get some good 1/2 inch birch plywood for it. The carcass was completed last week and weather permitting (meaning not too sweltering in the garage) I hope to do a lot more work this weekend to complete it. Still haven't decided how to construct the drawers. I don't want them to be too time consuming.
  18. #13
    Board of Directors
    Vice President
    DQ
    Hmerkle's Avatar
    Nickname
    Join Date
    Jul 2013
    Location
    Greer, SC
    Posts
    4,990
    Visit Freq
    3.00 visits/week
    Threads
    270
    Classifieds
    Quote Originally Posted by Richo B View Post
    Don't believe it - didn't happen - no pictures!
    Just kidding, but seriously, many of us want to see (at least) the finished product, if not some WIP! (this being a GREAT idea!)
    People are amazed as a shaving rises from the throat of a plane as if itís a spell plucked from a sorcererís hand Ė Paul Sellers
  19. #14
    Staff Advisor
    DQ
    Joe Scharle's Avatar
    Nickname
    Joe (75)
    Join Date
    Sep 2005
    Location
    New Bern, NC
    Posts
    5,472
    Visit Freq
    5.58 visits/week
    Threads
    684
    Classifieds
    I built one very similar to what you're planning a few years ago. This one is mostly plywood, with trim and web frames from solid scrap. The primary reason for building it anyway, was to to see if I could make a substantial roll-around shop box using only pocket screws. Ten years or more and it's still solid. Even the drawers.
    Always be yourself because the people that matter don't mind, and the ones who mind, don't matter.
  20. #15
    Nickname
    Richo
    Join Date
    May 2015
    Location
    New Bern, NC
    Posts
    368
    Visit Freq
    1.92 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Hmerkle View Post
    No pictures because its not done yet. I'll be at a point to take photos tomorrow. I just wanted to update the thread to keep it going. I got quite a bit done today but need to put it all together tomorrow.
Similar Threads
  1. Flush trim solid edging plywood shelf- how do you do it?
    By redknife in forum General Woodworking
    Last Post: 12-02-2016, 10:03 AM
  2. Solid Wood Panels
    By terry1166 in forum General Woodworking
    Last Post: 02-11-2012, 11:21 AM
  3. Replies: 2
    Last Post: 04-05-2010, 09:44 PM
  4. Solid wood on Plywood
    By DavidF in forum Wood
    Last Post: 09-08-2009, 02:52 PM
  5. Solid wood flooring
    By John Reeves in forum User Announcements
    Last Post: 10-18-2007, 11:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
