West Penn Hardwoods (Ad 2)
Results 1 to 13 of 13
  1. #1
    Nickname
    Darryl
    Join Date
    May 2016
    Location
    Conway, SC
    Posts
    Visit Freq
    3.12 visits/week
    Threads
    Classifieds
    Formica on Formica?
    My wife and I just purchased a vacation cabin in the NC mountains. The house is in really good shape overall including the kitchen cabinets, but the tops are bright teal in color. We want to change the the formica tops because of the color. Can you over lay formica on the existing formica? Seems to me that would not be a problem, but want some advice from you guys.
  2. #2
    DQ
    dancam's Avatar
    Nickname
    Dan (72)
    Join Date
    Apr 2006
    Location
    Asheville, NC
    Posts
    825
    Visit Freq
    7.00 visits/week
    Threads
    70
    Classifieds
    Re: Formica on Formica?
    Interesting question and I have no clue if possible. I'd suggest you call the Formica folks and ask for some technical advice. Let us know how you make out overall.
    And in the end, it's not the years in your life that count. It's the life in your years.-- Abraham Lincoln
  3. #3
    DQ
    Nickname
    Join Date
    Jan 2017
    Location
    General Electric, NY
    Posts
    525
    Visit Freq
    6.08 visits/week
    Threads
    50
    Classifieds
    You would likely need to key the surface first to ensure the new formica sticks.
    I don't see why that with some contact adhesive wouldn't work.
  4. #4
    DQ
    Skymaster's Avatar
    Nickname
    Jack (77)
    Join Date
    Aug 2009
    Location
    Zebulon, NC
    Posts
    1,734
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    You will need to sand the old mic and with 60 grit and remove ALL SHINY OLD SURFACE. THEN READ LAMINATE
  5. The following 2 users say Thank You to Skymaster :
  6. #5
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    517
    Visit Freq
    5.00 visits/week
    Threads
    Classifieds
    After years of trying to remove spots of contact adhesive from the finished laminated surfaces, I'm not even sure that sanding the slick surface is even necessary. That contact cement is sticky stuff (the flammable kind, anyway).
    On a kitchen countertop, process will be the sticking point. The sink will have to be removed and likely the whole counter top will have to be removed. There's the back splash to be considered also.
    Naturally on a roll-formed top with the integral backsplash, re-laminating will be a bit of a problem even if you can buy post-form thickness laminate. That stuff is glued to the substrate with heat and pressure.
    The shop-made self edged laminated counter top with a removable backsplash should be relatively easy to do.
  7. #6
    Nickname
    Join Date
    Jan 2013
    Location
    Mc Leansville, NC
    Posts
    1,750
    Visit Freq
    4.38 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Darryl View Post
    You may want to try this....https://www.amazon.com/dp/B004LB5EXC...ing=UTF8&psc=1 I have never used it but I heard it works pretty well, especially for a cabin.
  8. #7
    Nickname
    Join Date
    Mar 2015
    Location
    Morehead City, NC
    Posts
    312
    Visit Freq
    4.31 visits/week
    Threads
    41
    Classifieds
    I haven't done it, yet, but am very close. Have the new laminate, cement, and rollers, just need to find the time. It is definitely possible, but as someone else mentioned, if you have the heat-formed/rolled style, I imagine it would be more difficult. Luckily, ours are the simple squared/filed edge style. We opted to re-laminate instead of replacing, mainly due to cost, as I have less than $200 in everything. We plan to turn this house into a rental after the lady finishes nursing school. Because of that, we are trying to limit the amount we put in, while still making it a bit more "modern" for our future tenants.
    Next, after the laminate countertops, I will rip of the carpet and replace with some nicer laminate flooring.
    Edit: This is the product I got, two sheets. https://www.lowes.com/pd/Formica-Bra...eet/1000069847
  9. #8
    Nickname
    DrBob
    Join Date
    May 2014
    Location
    Baldwin, FL
    Posts
    633
    Visit Freq
    3.58 visits/week
    Threads
    Classifieds
    Yes you can.
    You don't need to sand it.
    I recommend using only Weldwood in the red can. Do not use the waterbased stuff.
  10. The following 2 users say Thank You to Rwe2156 :
  11. #9
    Board of Directors
    Webmaster
    DQ
    FlyingRon's Avatar
    Nickname
    Ron
    Join Date
    Dec 2009
    Location
    Catawba, NC
    Posts
    1,131
    Visit Freq
    6.35 visits/week
    Threads
    77
    Classifieds
    I agree with RWE. The contact adhesive usually used (little more than rubber cement in my opinion) doesn't care. It will stick to (unsanded) formica about as well as anything else.
    No job is worth doing unless you can get a new tool out of it.
  12. #10
    User TENdriver's Avatar
    Nickname
    TENdriver
    Join Date
    Nov 2012
    Location
    Wdbg, VA
    Posts
    579
    Visit Freq
    6.73 visits/week
    Threads
    Classifieds
    Will it stick to waxed, greasy or old contaminated surfaces?
  13. #11
    DQ
    FredP's Avatar
    Nickname
    Fred (61)
    Join Date
    Jun 2006
    Location
    franklinton, nc
    Posts
    5,612
    Visit Freq
    6.88 visits/week
    Threads
    205
    Classifieds
    I am the nay sayer here. Having made a lot of laminate tops and relaminating a good many I say rough the surface up. 80 grit on a RO sander then clean thoroughly befor re-laminating. It gives the glue some tooth. counter tops are subject to all kinds of hot and cold things. heat will cause the glue to let go of smooth surfaces on occasion. I assume you only want to do this once?
    fred p If it ain't broke you aint trying hard enough
  14. The following 3 users say Thank You to FredP :
  15. #12
    Board of Directors
    Webmaster
    DQ
    FlyingRon's Avatar
    Nickname
    Ron
    Join Date
    Dec 2009
    Location
    Catawba, NC
    Posts
    1,131
    Visit Freq
    6.35 visits/week
    Threads
    77
    Classifieds
    The contact cements I am familiar with don't need tooth. I've even stuck down sheet steel to substrates with it. What you do need is clean (yes I'd get rid of the grease and wax first, whether you want to do that mechanically or chemically is up to you). Make sure you use enough glue and that you apply sufficient pressure.
  16. #13
    Nickname
    Join Date
    Mar 2008
    Location
    Snow Camp, NC
    Posts
    55
    Visit Freq
    0.69 visits/week
    Threads
    Classifieds
    Sand first, there may be wax on the old formica.
    If these were my formica tops, there would be several coats of wax.
    I wax just about every year.
    As for removing the glue from the exposed surface, I have never seen a glue that lacquer thinner wouldn't remove from formica.
Similar Threads
  1. Piece of Formica ?
    By Bill Clemmons in forum Where Can I Find, Buy or Sell
    Last Post: 12-18-2015, 08:30 AM
  2. Formica help
    By mshel in forum General Woodworking
    Last Post: 01-05-2010, 09:46 AM
  3. Formica
    By Canuck in forum Where Can I Find, Buy or Sell
    Last Post: 03-12-2009, 03:55 PM
  4. Cutting formica
    By gordonmt in forum General Woodworking
    Last Post: 01-11-2008, 05:45 PM
  5. Formica problem help me please
    By Jon in forum General Woodworking
    Last Post: 03-22-2007, 09:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
