West Penn Hardwoods (Ad 2)
Results 1 to 14 of 14
Thread: Masonry bit
  1. #1
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    301
    Visit Freq
    5.19 visits/week
    Threads
    Classifieds
    Masonry bit
    Would I use a regular Masonry Bit for drilling thru brick ?
  2. #2
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    517
    Visit Freq
    5.00 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    short answer: yes.
  3. The following user says Thank You to bob vaughan for this useful post:
  4. #3
    DQ
    Nickname
    Roy
    Join Date
    Apr 2010
    Location
    Apex, NC
    Posts
    839
    Visit Freq
    6.69 visits/week
    Threads
    52
    Classifieds
    Re: Masonry bit
    Its also easier if you have access to a rotary impact drill.
    Roy G
  5. #4
    DQ
    JackLeg's Avatar
    Nickname
    Reggie
    Join Date
    May 2007
    Location
    Albemarle, NC
    Posts
    5,072
    Visit Freq
    2.62 visits/week
    Threads
    403
    Classifieds
    Re: Masonry bit
    Yep, but make it a good bit!
    "The American Republic will endure until politicians realize they can bribe the people with their own money!" Alex de Tocqueville"
  6. #5
    DQ
    Phil S's Avatar
    Nickname
    Phil Soper (67)
    Join Date
    Mar 2008
    Location
    Raleigh, NC
    Posts
    4,278
    Visit Freq
    10.04 visits/week
    Threads
    509
    Classifieds
    Re: Masonry bit
    A rotary hammer drill with a masonry bit will work well. If you are drilling thru it is very common to blow out the back of the brick. Either drill in from both sides or press very lightly as you drill thru or hold a block of wood behind the brick if possible.
  7. The following 2 users say Thank You to Phil S :
  8. #6
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,879
    Visit Freq
    6.92 visits/week
    Threads
    204
    Classifieds
    Re: Masonry bit
    Quote Originally Posted by Ptofimpact View Post
    Only if it is a small diameter hole or you are a masochist. Otherwise you would really want to use a rotary hammer bit, but then you will also need a rotary hammer drill (not a "hammer drill" but a "rotary" hammer drill, very different beasts). That is, assuming, these are the typical very hard bricks (like fired clay) and not especially soft or old and brittle bricks, in which case an ordinary masonry bit and drill would likely do just fine.
    The reason one wants to use a rotary hammer drill and the proper roatary hammer bit when drilling into hard masonry is because a hole of any real diameter can literally take hours to drill even with an above average hammer drill, by which time you will have long since lost all feeling in your hands and arms (such can actually cause nerve damage with extended exposure). By comparison, a rotary hammer drill will easily drill that same hole in mere seconds (if you do not set a depth stop you will be clean through the brick before you even realize it) and the vibration will not harm your hands and arms, nor cause undue fatigue.
    As an example, before I invested in a rotary hammer drill (they are not cheap, though you can rent one) I tried to drill a 3/4" hole in clay brick using the heaviest duty hammer drill (Bosch) and best quality carbide tipped masonry but I could get my hands on. Fifteen minutes later, I had long since lost all feeling in my hands and arms, burned out the drill's speed controller, and barely made a 3/16" divot, if that, in the brick. I then returned the failed hammer drill for a proper SDS-Plus (the smaller sibling) rotary hammer drill and a 1" bit and then successfully drilled that even larger hole through the very same brick in under five seconds from start to finish.
    That said, if this hole is no more than around 1/8", or thereabouts, then you can usually get away with using ordinary carbide tipped masonry bits and a drill coupled with a good deal of elbow grease and patience, but I would not want to have to drill more than a few such holes into hard brick (cement block, by comparison, is no problem as they are much softer). YMMV.
  9. The following 2 users say Thank You to ehpoole :
  10. #7
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    301
    Visit Freq
    5.19 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    Thanks for all the excellent info, and these are the Red Clay fired bricks, so I suspect I should see if a buddy has such a drill, rotary hammer type. Along these lines , assuming I get the hole drilled, would you all know what the standard height would be for a outside electric receptacle?
  11. #8
    DQ
    Nickname
    Dave
    Join Date
    Jul 2005
    Location
    Raleigh, NC
    Posts
    714
    Visit Freq
    0.23 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    If it was me I'd let the construction dictate how high the outlet is. Typucally they are going to be at the height where you can punch the hole into the crawl space wood band joist.
    Too high and you are into an interior wall where you are going to have do more work to do an acceptable patch on the interior wall.
    Too low and you are going to have to punch the hole not only through the brick but also through the cement/cinder block foundation that is behind the brick.
    If it was me I'd probably get one of those cheap Harbor Freight air chisels and chisel out the mortar joints around about half a brick and use the chisel to break enough of the brick out so you could mount the outlet box horizontally and recessed not the brick. I have done a lot of selective brick demolition with an air chisel and it goes pretty quick.
  12. The following user says Thank You to DaveD for this useful post:
  13. #9
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    301
    Visit Freq
    5.19 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    Further to this question, I have a friend with a Hammer drill, so that is good, now to attach the outdoor receptacle to Brick, will those
    Blue Masonry screws work, and do they cut their own Hole? Thanks again.
  14. #10
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,591
    Visit Freq
    6.92 visits/week
    Threads
    512
    Classifieds
    Re: Masonry bit
    The blue tapcon screws have to be predrilled at the correct diameter for the screw to enter the hole but still bite. They usually sell the proper size bit with the screws.
    They will work but you might consider using a piece of conduit and a connector on the end of that to secure the box. Add some silicone caulk around the conduit behind the box and it should be anchored securely. But I'm no electrician so take my advice for what it is, uninformed.
    Ban shredded cheese, make America grate again.
    "May the grain be with you" - Roy Underhill
  15. The following 2 users say Thank You to KenOfCary :
  16. #11
    DQ
    gesiak's Avatar
    Nickname
    Join Date
    Aug 2008
    Location
    Carol Stream, IL
    Posts
    447
    Visit Freq
    6.50 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    The Tapcon package lists the proper drill bit size for the screw. The store should also have the correct bit in the same bay the Tapcons are. Some larger packages include the proper drill bit.
    For the 3/16 screw you would drill a 5/32 pilot hole, 3/16 for a 1/4" screw
    John. “Life's hard. It's even harder when you're stupid.” ― John Wayne”
  17. The following user says Thank You to gesiak for this useful post:
  18. #12
    DQ
    Nickname
    Dave
    Join Date
    Jul 2005
    Location
    Raleigh, NC
    Posts
    714
    Visit Freq
    0.23 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    Rather than drill into the brick just drill into the mortar joints. It will be a lot easier. If the screws go into the mortar join about 1"" that should be sufficient.
  19. The following user says Thank You to DaveD for this useful post:
  20. #13
    Forum Leader User
    DQ
    Glennbear's Avatar
    Nickname
    Glenn (69)
    Join Date
    Jan 2008
    Location
    Baskerville, VA
    Posts
    4,502
    Visit Freq
    0.50 visits/week
    Threads
    279
    Classifieds
    Re: Masonry bit
    Quote Originally Posted by gesiak View Post
    Tapcon screws fall into my "better than sliced bread" tool category, after you drill your holes be sure to either vacuum or blow the dust out of the hole or the screws will bind before being fully seated.
    :new_uklia " I get knocked down but I get up again" - Chumbawamba
  21. The following 2 users say Thank You to Glennbear :
  22. #14
    Nickname
    Pete
    Join Date
    Oct 2012
    Location
    N Topsail Bch, NC
    Posts
    301
    Visit Freq
    5.19 visits/week
    Threads
    Classifieds
    Re: Masonry bit
    Thanks for all the good advice, my buddy used his rotary hammer drill, at masonry joint, less than 3 minutes hole done, then the Tapco screws...all worked well.
  23. The following 2 users say Thank You to Ptofimpact :
Similar Threads
  1. Masonry fireplace fix
    By gordonmt in forum DIY- Home improvement
    Last Post: 01-29-2009, 07:12 PM
  2. Masonry Construction Software
    By brent innc in forum "How To" Forum
    Last Post: 10-07-2006, 08:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
