Wire type for 240v extension cord or new, longer plug assembly
kooshball
What wire designation do I need to either make an extension cord for a 240v 20a circuit or make up a new, longer cord?
I will only be extending 12' for a total of 18' of cord so 12ga should be fine but I would rather go to 10ga. Is there a designation to tell me that a certain cable is flexible enough for this task?
Thanks
Dudelive
Dude
Don't cheap out on the plugs for connecting as that will be where the resistance will happen every time.
eyekode
Salem
I have used cord from Lowes (the yellow stuff) and I also bought a roll off of CL. They both work fine but the prices at lowes are a little steep. However if you only need 12 feet it shouldn't be too bad. The connectors are what will be expensive.
At that length I would consider just replacing the tool's cord. Most manufacturers include really crappy cords anyway.
Salem
scsmith42
Scott Smith
Salem
Ditto Salem's advice. Either type SJ or SO would be appropriate. Both are very flexible cords with jackets designed for that purpose.
Howard Acheson
Howard
The determinate of wire size is not the voltage but the amperage. For under 50' there is no reason to go to a larger wire than the wire that is used on the existing tool.
