I read an interesting discussion on the Farmall collector's board... http://www.redpowermagazine.com/for...e-workmanship-on-your-kitchen-cabinets/page-1
The basics of the story is this - a woman went to open her under cabinet microwave door early one morning, and the upper cabinet fell off the wall and landed on her. She had a gash in her head and fractured bones in her neck, but appears to be healing better than expected. The house was a high end home, less than 10 years old, with shoddy construction details. The upper cabinet was attached to the wall with 6 screws, sounded like not all the screws hit a stud if any of them did. The back of the cabinet was attached to the carcass with staples.
Now for the question part - I am planning to build kitchen cabinets. I have a 100 year old house with rough cut 2x4 studs and 3/4 t&g pine walls under the sheet rock, so anchoring shouldn't be a problem. I'll probably put 12 3"screws in a 6' cabinet, maybe more. My plan is to use 1/2" plywood for the cabinet back in a rabbet on the edge of the 3/4" plywood sides. The joint will be glued, and probably reinforced with screws where they won't show and brad nails where I can't use screws.
What is the "right" way, or best way, to build a wall cabinet carcass? Should the back be set in a dado a half inch in from the back edge instead of flush in a rabbet? This would allow me to use a 1/2" thick french cleat rather than screwing through the cabinet back, but my uppers need to go all the way to the ceiling, so dropping them on a french cleat may not work too well.
