So far I've made about a dozen pens. Tried a CA finish on the last five. First I used a Q-Tip and applied the CA while rotating the pens on the lathe by hand. The I read about the method of using a paper towel applicator and letting the lathe run while applying the glue. So I've tried that three times with poor results. My best CA finishes have been done with the Q-tip method.
I made a pad of paper towel and put a liberal puddle of glue on the towel and apply. The blank looks nice when the glue is applied but if I buff the blank with the applicator the glue turns white and the finish is rough. Not sure if the drying glue is picking up debris from the paper towel or its just the glue drying. But it looks horrid. If I remove the applicator before the CA turns white...while the glue is still in its shiny stage...then the glue dries with lines in it from the spinning mandrel. i wonder if its too much glue and drying uneven...
This pen was cocobolo and looked very nice BEFORE the finish. Used micro-mesh all the way to the finest grit. After the finish...it doesn't look so nice anymore. I've already sanded off the first trial and refinished and I'm afraid to sand it any more. I'll probably just leave it and hope the next one is better...not sure if I'm doing something wrong or just need to practice...
OTOH...not sure I'll be able to continue with the CA finishes...I think I'm getting a contact dermatitis on my wrists after applying the CA finish. I may need to explore other options for finishes on my pens...
