I've been slowly completing the installation of the equipment that the NCWoodworkers helped to uncrate and assemble last month.
Last Monday the table saw was assembled and made operational, and I'm pleased with the results.
Today I worked on the G0660X 16" Grizzly combination jointer/planer. I knew that this unit was made in Germany, but tonight I found out that it is a Sheppach IXES machine that was made for Grizzly. There is a lot of confusion regarding the HP; the name plate lists it at 3hp, the Grizzly catalog listed it at 5.5 HP (which had me concerned considering that it's a 16" model), and according to the manual that came with it it's 4.8 HP. I think that the cutterhead is probably 4.8, and the planer feed motor is 3/4 hp, for a total of 5.5. Whatever it is, it's adequate to do the job.
The overall fit and finish is outstanding. The jointer bed adjustment is the parallelogram style, and both the jointer and planer beds have an unusual machining style... with tiny "ribs" machined into them to help keep the boards from twisting when going across the cutter head.
It doesn't take long to switch between jointer and planer; the most time is spent in adjusting the planer bed up and down (it has to be positioned at maximum opening in order to switch between the two functions). It's around 3 - 4 minutes to switch each way.
The machine runs very smoothly (will balance a nickel on its side while running), and leaves a remarkable finish on the boards (I used a 5/4 oak board for my tests). Snipe is NONEXISTANT :icon_thum, and there are no noticeable ripples in the finish. My 14" wide test board measured within .001 from side to side; which is better than my old 20" dedicated planer.
Apparently Grizzly has decided to discontinue the machine, which is a shame considering its quality.
On the downside, the knives for the Leitz cutterhead are expensive, at $150.00 a set! (ouch). At least they can be flipped once... Unfortunately, the first board that I ran though it had a small rock embedded that I missed, so I nicked a blade from the git-go...:BangHead:
Overall a good acquisition and I'd recommend it to anyone.
No pix tonight; I'll try to take some tomorrow and update the thread.
