I have experienced the same issue on my drum sander (Performax 22-44 w/ infeed and outfeed supports). This is what I think happens.
If your panel is slightly bowed (it's not ideal, but it happens sometimes) then as it goes through the drum sander it can get to a point where there is more pressure on the infeed and outfeed tables than the conveyor belt (the slight bow in the panel prevents there from being adequate pressure against the conveyor belt). When this happens, the stock stops feeding, but the drum keeps spinning and you get a nasty divot.
I just apply hand pressure to the conveyor belt (infeed side in the beginning and outfeed side at the end) to keep the stock feeding. I've just made a habit of it. I generally don't experience this issue all the time, but it seems to happen at the most inopportune times, so I just try to prevent it all the time.
A simple experiment to see if this is your culprit would be to temporarily remove or significantly lower the infeed and outfeed tables and see if this issue goes away. If it does, you have your smoking gun, if it doesn't then it must be something else.
