Suggest a box for paddle switch?
eyekode
Salem
I bought a bunch of these to replace some really poor switches on my tools:
http://www.grizzly.com/products/110-220V-Paddle-On-Off-Switch/H8243
The smaller electrical boxes are not deep enough to fit the switch. The larger square-ish ones are just barely big enough. The large PVC ones fit but they will cost 10$ a piece after buying strain relief.
Any recommendations for alternatives?
Thanks!
Salem
Mt. Gomer
Wood is a pretty good insulator. Know anyone who might could whip you up few nice wooden boxes? :wink_smil
eyekode
eyekode
Salem
Actually due to the construction of these I am not sure wood is a good idea. I think the mounting screws should be grounded. But the gauge is sooo small that just wrapping it won't work. They really are not engineered to be ground screws. In a metal box they would normally both be grounded due to connecting to the grounded metal box. I guess I could use one of those small ring connectors...
bobby g
Bob
I think if you take it to an electrical supply house (like Womack or Sheppard) they'll be able to fix you up with a low cost solution.
Regards,
Bob
DaveD
Dave
I've done something similar for 50A welding outlets that needed more room for the big wires.
Buy whatever size steel box you need/want and also get the blank cover for it. Cut out whatever sized hole you need to mount the switch to/in the blank cover.
eyekode
eyekode
Salem
Oh that has some promise for surface mount. If I use a double gang box it should work fine.
eyekode
eyekode
Salem
Thanks again for all the ideas. I wanted to build one into a cabinet and the other surface mount. With your suggestions I think I can finish it :).
Salem
