Steel building
Willemjm
Willem
Anyone here put up a steel building for a shop, pros versus cons versus stick. Costs will be much less. Who did you use in NC?
cfield60
jeff
I constructed my building in 1988. It's 30' x 50' with 12' tall side walls and has served me well. I bought the building kit, it's a Mesco brand, for Sam Adams of Ace Construction Co. out of Florence, SC. I realize they are in SC but they do, or did a lot of business in NC and other states. My building is wide open. If I did it again, I think I would have added 25' more to the length. I have been well pleased with my shop.
Willemjm
Willem
Thanks for posting, some questions?
1.) How thick is your slab?
2.) How did you do the insulation and is there a ceiling for hanging ducting etc.?
3.) What labor did you use to put up the kit and did you have to do foundation work as part of the slab?
bowman
Board of Directors, Webmaster
Neal
Willem,
I went through Carport Central to quote my building, which is 22x36. http://www.carportcentral.com/product-category/garage/vertical-roof-style/
The manufacturer that was closest to my location (Carolina Carports, Dobson, NC) did the install after I had my lot graded and concrete poured. The installation was completed in a day and a half.
They went through the different options with me. I did a vertical roof, meaning the ribs run from eave to peak. I also went with a certified building (not required for my city/county codes), designed to withstand higher winds and snow loads, by placing the posts and beams closer to each other and more fasteners into the concrete slab. When I bought mine in late 2016, it was less than $500 to add this to the cost of the building.
I have two 9' rollup doors, one in one end, and the other along the long side wall near the back of the building. I also have 2 walk-in doors on the same side as one of the rollup doors.
After I have the initial electrical panel installed by a licensed contractor (and subsequent inspection), i did the remainder of the wiring myself, using 12/3 armored cable. that was easier than running PVC/EMT conduit, but probably wound up being more expensive.
One thing that I was not prepared for was the amount of rain water that came off of the room, even with a light rain. I constantly had problems with water seeping under the side garage door, no matter how may times i reset the rubber door sill under the door. I eventually put gutters on the side with the doors and that has eliminated 99% of my rain issue. On days where snow stays on the roof, the melted snow will not flow into the gutter, so I usually go out and rake the snow off of the roof.
My building is not insulated, so be prepared for extreme cold and heat. I have a small electric heater to warm the area where I am most often working, but it cannot keep up with the recent cold days we have had lately. In the summer, I open all doors and I have a ceiling fan installed to move the air around, and it can reach in excess of 120 when closed up. When the sun directly hits the building, you will not be able to hold your hand on the metal siding. I am strongly considering the SolarPanel plywood panels to reflect some of this radiant heat. I will admit that it does feel good in the winter time, until the sun starts setting.
I have to use the metal drilling screws to mount anything to the metal posts, and since my posts are not on 4' centers, firing strips will be needed to hang plywood on the walls.
I had to have grading done, as there was a 40" slope across the diagonals of the building. This grading and concrete for me was around $3k, with $7k in the building. I could have gotten a wooden building for the same price, but less than half of the space.
Would I do it again, yes. I wanted to go a little larger, but I had other limitations surrounding me.
Hope this helps. If there are questions that I didn't answer, let me know, I'll answer as best I can.
KenOfCary
No personal experience - yet - but Morton Buildings seem to have very high quality shop and barn metal buildings. Been looking at them for a while for a new barn up here. Haven't decided anything yet, so am also interested in this discussion.
I second Morton Buildings, but why not frame a building, and use trusses for roof system? Sheet it with LP Smart Siding, which comes in 4 X 8 sheets, with a finish ready for paint. Either way, you are going to need to install a concrete slab. Ask Scott Smith how he likes his hydronic heat in the floor. With proper orientation, solar panels could furnish most of the heat, with a gas WH for backup. At the doors, when I built mini storages (9 years,) we depressed and area in the concrete where the door and track support were by about 3/4" to prevent rain from blowing under the door. I have the same on my shop, and never has any water come under the doors.
KenOfCary
That's a good idea - probably never had mice come under the door either.
