Looking good Reggie!
Jeff, a solar kiln works by trapping the moisture released by the sun heating the chamber, and maintaining a high RH inside the chamber. It's not the sun that causes degrade to the boards, it's the rapid loss of moisture. You can controll this through a combination of RH and temp.
Solar kilns cool down at night, which helps to even out the drying cycle; otherwise the wood would suffer from too much temperature while it had a high MC%.
I thought the idea was to slowly decrease the RH while at the same time increase the temp. Although I understand RH has a lot to do with temp and moisture in the lumber. In the beginning of the kiln cycle it might take some amount of time to be able to control the RH. So in a DH kiln water collects on the coils of the DH unit is chilled and drips into a pan which is piped to the outside. Same basic principle as a dehumidifier, only on a larger scale.
With a solar kiln you'll have variations of the amount of sun, temp and outdoor humidity and at night 100% humidity inside the chamber. How does wood consistently dry under such conditions? how do you control the RH and get rid of the right amount of excess water to maintain proper RH when you have inconsistent temps and RH in the kiln chamber because solar radiation is your primary heat source?
Perfect example is the last few days:
* Friday it was sunny and 80 degrees with low humidity
* Yesterday it was partly sunny and 50 degrees with low humidity
* Today it's overcast raining 40 degrees 87% humidity
Does the wood just not dry any or very little during these conditions? Seems like if it doesn't then it would be an opportune time for the wood to develop internal stress but obviously will increase the length of time to dry the load.
I'm sure Reggie will get the answer when he attends class, I hope he shares it with the rest of us.
These questions, 2 bad experiences with solar kilns and log yard owner saying no - stopped me from building a 4K ~ 5K BF solar kiln.
Thanks
