I have a design/construction decision to make and would like some input.
On the front lower base of the bedside cabinet I need a sliding DT on the lower shelf/bottom of cab to hold the sides in firmly. For aesthetic reasons I want the DT to show on the front face. Now I have a couple of options. One is a full length sliding DT, going straight front to back and cut a matching tail on the shelf (cherry veneered Ply). Now we all know that getting a long SDT to fit all the way through can be a problem and you end up bashing the **** out of it to get it though, this wouldn't be a problem if the side of the case was perfectly flat, but if the joint is tight it would only take a slight change in thickness or flatness to bind the joint. Now an option is to cut a shallow, 1/8 deep dado in the case side the thickness of the shelf (1/2). Then cut a full length DT on the edge of the shelf, but then cut most of it away leaving a short (1") sliding DT on the front end of the shelf. The shelf is inserted from the front into the dado up until the DT "ear" makes contact with the front and then this is scribed and a DT socket cut into the face of the case side. This gives me the pulling power of the DT but the ease of fit of a dado. Is that clear? Question, should I do this? has anybody else done it? BTW, sides are solid cherry, with 2 joins to make up the width and is 13" wide. The chances of them being perfectly flat are slight. What do you all think - worth the effort of the mixed dado/DT joint?
