Rule Joint
JNCarr
I'm about to build a small drop-leaf table and want to use a rule joint. This will be my first rule joint. Am planning on routing both the round over and cove prior to ripping the table to width to cut off any small tear-out. I'll also leave it long so I can cut off the rule in the event it doesnt come out. I'll cut a sample before committing to the good stock. Any other tips/tricks?
Any suggestions on a swing arm vs purchased metal support?
Roy G
Roy
Joe, I made a card table with a rule joint several years ago. I used a swing out support. The supported part of the top was only about 10" wide, so it didn't need much supporting.
Roy G
JNCarr
DrBob - thanks much. I have the FWW print but had not seen the video. Between the two sources, I should be all set.
Joe Scharle
I used a MLCS bit set and the joint came together fine. Spent a lot of time setting the hinges. I made sure I had the setup on scrap first.
JNCarr
Finally got around to cutting the rule joint tonight. Very straight forward.
Here's the unstained (ribbon Sapele) top sitting on the finished Sapele frame.
JNCarr
I'd like the top to be a bit lighter in overall tone than the frame. And of course not obscure the ribboning. So I'm thinking Zinsser sealcoat cut either 1:2 (darker) or 1:1 (lighter) followed by Minwax Early American which has a little red - its what the frame is. I dont want a mahogany red for the room it's going. Will do a few samples and decide.
