Here's a few things to consider:
The angular velocity of an 8" grinder is higher than a 6" at a given rpm, so there's really no advantage to an 8" unless you need a wider stone.
Variable speed is a good feature. Both Craftsman and Porter Cable have them.
I got the Craftsman because the light is independent of the switch. The light on the PC only come on when the wheels are spinning. I got the a craftsman on sale for $90 and am very happy with it.
Some kind of aftermarket honing guide is a must because the guides that come with most grinders are pretty useless if you plan on hollow grinding. I like the Veritas guide. Or you can make your own.
You will need to get some better wheels than what come on them. Check out Norton. An 80 grit and a 120 is a good combo.
Be aware that there is often a need to balance the wheel and that can be a "process"
. Also the bushings that come with the stones are too sloppy so you may want to make your own.
Finally, consider getting a dedicated "el cheapo" and putting a wire wheel and felt wheel for rough work and polishing.
Once you really get into it, you will find that hand sharpening is just as efficient and you can get a quality edge in minutes without the need for spending hundreds of dollars on a wet wheel system and all the jigs. But you will need to invest some bucks in some good quality stones.
Typically I can rehone a chisel edge while I literally 2-3 minutes tops.
Sent from my iPad using Tapatalk
