Raleigh area jig game - picture frame sled
bobby g
Bob
Here is my picture frame sled using the UHMW PE material from EYEKODE for the runners. This is a fixed 45 degree miter jig that will, hopefully, allow me to make perfect 90 degree corners. This was the first time that I used this material but it won't be the last time. I really like the results of the fit in the miter slots. It seemed to be a bit of a challange to trim down to final size at first but, thanks to an idea from Bruce (junqecol), a simple planer jig make short work of it.
I had a similar sled for years but it went away when I bought the Saw Stop and I've been struggling since when doing picture frames or any other "closed" projects. It's great to have this tool done and available. I need to use it to finish up the 3 small tables that I have in the works.
The base was made from some 3/4", very old, dead flat birch veneered plywood. The blocks forming the right angle are red oak.
Thanks again to EYEKODE for making the PE available.
Here it is bottom-side-up.
http://www.ncwoodworker.net/pp/showphoto.php?photo=43092&ppuser=2286
View image in gallery
Here is the "business end" view
http://www.ncwoodworker.net/pp/showphoto.php?photo=43091&ppuser=2286
Here it is from the operator side, Note the stop stick in the left miter slot and the no hands area marked in red.
http://www.ncwoodworker.net/pp/showphoto.php?photo=43090&ppuser=2286
Parked and ready. The stop stick is stored on it (left side).
http://www.ncwoodworker.net/pp/showphoto.php?photo=43089&ppuser=2286
Bob
Trent Mason
Trent Mason
Bob, that's an awesome looking jig. :eusa_clap:eusa_clap:eusa_clap I have to ask though, I don't think I totally understand the purpose of it. :icon_scra Don't worry, this happens a lot. :embaresse
bobby g
Bob
It's a fixed 45 degree miter jig. Built to, hopefully, make perfect 90 degree corners.
Bob
eyekode
Salem
Nice one Bob! I am glad the runners worked for you :).
By the way, how do you keep the scratches off your TS!! Wow that is pretty looking surface!
Salem
bobby g
Bob
By the way, how do you keep the scratches off your tablesaw!! Wow that is pretty looking surface!
Salem
Salem,
Thanks! I have a big enough shop to allow me to only use the machine tops for their intended purposes. I use Dri-Cote regularly to keep the tops dry and slick.
Bob
MrAudio815
Matthew
Bob,
That Sled ROCKS~! It is very nice. Would love to see what you make with it.
I'll have to post the sled I am making with that same stuff I got from Salem.
Question: I know it's for 45's but how do you measure the length of each board to make sure you cut them the same length? Knowing me, I would cut the top one a little shorter than the bottom and the right one a little shorter than the left and it would be all crooked.
bobby g
Bob
Bob,
Thanks Matthew. First let me say that the 90 degree angle is set to be as accurate as possible. Cutting from one side may be yield a little less than 45 and cutting from the other side may yield a little more than 45. So, when using the jig, I cut the left frame piece on the left side of the jig and the right frame piece on the right side. Do this for each corner and they will all be good. As far as lengths are concerned, it's not too difficult. The kerfs in the base and in the blocks are zero clearance. Clamp your frame sides together, mark the lengths on the edge of all pieces using a square, line up a piece on the jig with a mark to the kerf and make your cut.
Hope this helps,
Bob
