Just did up these photos so I thought I would share them here. This is a shop-made fence for doing raised panels safely. Edgeband a piece of 3/4 plywood with hard wood like maple. Drill a hole for the spindle. Clamp the plywood. Install the cutter and lower the cutter into the wood to make a matching divot. Do this several times, resetting the plywood each time so the divot will be larger than the cutter. Bandsaw out a front guard and you're good to go. This rig makes it impossible for the edge of the wood to dig in because there's no fence gap to fight.
