I wanted to share a good method I found to build legs that show the face grain on all 4 sides. I used a lock miter bit on the router table which produces a nice fit to glue up. My legs are 2 1/16” wide for a footstool. I searched around online because there was no way I wanted my fingers that close to the bit on such narrow stock. I found a post from a guy that built 2 jigs... one for each of the 2 cuts you need to make with the lock miter and I modified it a little bit and built some. It worked well and I wanted to post some pics in case someone else is interested. Another thing I did was cut a chamfer on the table saw before routing the pieces... that made a big difference and required less “hogging” off material by the router.
