Knowing I needed some sort of dust collection but not seeing too many other systems around here, I opted to use PVC pipe for my shop lines. I bought a 2hp double bag setup, replaced the bottom bag with a clear plastic bag and made a remote on/off switch that sets above my workbench. After reading a few other threads on other sites about using PVC being a no no becuase of static electricity buildup and discharge, I realized why my eyes would light up on occasion while using mine. Having a limited budget for operations (Which is why I used PVC to begin with), I needed to come up with a solution to eliminate the static charges.
I bought a box of stainless #8 x 5/8 phillips pan head self drilling screws and placed then on all the plastic pipe at 8" intervals. I left enough of the screw above the pipe surface so I could take and wrap general project wire around it before snugging it down. I started at a close receptacle so I could get a good ground point and wrapped the wire around each screw one turn from one end of the piping to the other. Then snugged the screws down against the pipe. The lenght of the screws made it extend into the air flow in the pipe far enough to drain off and static charge before it became dangerous. I figured the stainless would keep it from wearing down too quickly. Well... it worked! I no longer light up the shop while using it to vacuum the floor or bench tops.
