One tough bird ( update)
PChristy
Phillip
Got this turkey to do for commission and after looking at it I thought that it would be a fairly easy cut boy was I wrong:swoon: I started in the middle and was working my way out
View image in gallery
Got this far with cutting the veins - found out quick that veins are not easy - came around the head part and things got scary - Had to put some tape on the front and back side to keep the head from chattering up and down -plus sloooowwwer the saw down - breakage fosure:no:
I made it through with the head:icon_thum and I finished cutting the body down to just below the tape - then I started cuttin the tail feather section :swoon:
I stopped and taped down a zero clearance (!/4 plywood) under the cutting to give it even more support and had to get my finger pretty close there - Believe me I was nervous:swoon:
More ppicture to come - I hope that this turkey will be hanging on the wall soon:eusa_danc
steviegwood
Steven
Re: One tough bird
Roast it first. It will be easier to cut. hehe The last turkey clock that I cut only had 270 inside cuts if that helps. Steve
AmishWarlord
Mitch
Re: One tough bird
Looking good so far Phillip. What kind of ply wood are you using? I've got a piece of Birch lite ply that I was thinking about doing a design on to try out my new scroll saw.
wdkits1
Re: One tough bird
Looks good Phillip--Just remember to take your time and stay on the line and that gobbler will soon be cooked.
PChristy
Phillip
Re: One tough bird
Buck up man, it could be worse.
:gar-La; Yea it did sound like I was whinning there a little didn't it - This is a cool pattern - who's design is it? To tell you the truth since I have see this one that you have I think I would rather be doing it - doesn't look like it has any "vein cuts" in it - I am using Birch ply on this one - Got the ply from a good brother - sawduster:icon_thum - let us see the final on this when you get it done
AmishWarlord
Mitch
Re: One tough bird
That one is a little advanced for me. I'm going to start with this easy one. I'll do the wild one after I get some more practice.
The one I posted is called Wild Turkeys. It was in a wood craft magazine I picked up at Lowe's this morning. Creative Woodworks & Crafts Nov 2009. The magazine was $7.49
The pattern is by Mike Williams. He has some really good stuff on his site. http://www.mikesscrollsawpatterns.com/pattern.asp?id=82
PChristy
Phillip
Re: One tough bird
I picked that mag up today - got some good stuff in it - I mght try that other one with the two in it when I don't have anything else to do - I might do that one in Oak ply -
ScottM
Re: One tough bird
Bro, I have seen your work. You will be fine. Just go slow and easy. Change the blade often and take a break whenever you do change the blade.
PChristy
Phillip
Re: One tough bird
Mitch I have been to Mike site http://www.mikesscrollsawpatterns.com/pattern.asp?id=82 awhile back and I have forgotten about him - Thanks for the reminder - I have been wanting to try some of his fantastic patterns - When the next magazine come out with his Turkey pattern in it I am going to give it a try - I know that my wife will want this one
http://www.mikesscrollsawpatterns.com/pattern.asp?id=65
and this one
http://www.mikesscrollsawpatterns.com/pattern.asp?id=115
my sister will want this one
http://www.mikesscrollsawpatterns.com/pattern.asp?id=81
I am WOLF
Hope Mike doesn't mind be doing a little advertizing with his pictures - I will give this a try - because I read something this morning in Phil 4:13 :icon_thum
PChristy
Phillip
Re: One tough bird
Scott, thanks for the word of encouragement :icon_thum Believe me I am going sloooooowwwwww especially around the veining where it is only attached to the body wit 1/8-3/16 piece of ply:swoon: Thanks for the reminder - I need to order some more blades:icon_thum
AmishWarlord
Mitch
Re: One tough bird
Done with mine. This was my first time doing a art piece as opposed to wing ribs. I went off track a few time and I broke out one time. I need a lot of practice! The new Dremel scroll saw worked really well.
PChristy
Phillip
Re: One tough bird
Nice job Mitch:icon_thum Are you going to put a clock in it like the pattern calls for - My wife doesn't like the patterns with clocks - I have got to do a snowman that has a clock in it and she said "no clock":gar-Bi
AmishWarlord
Mitch
Re: One tough bird
LOL no, this one is horrible. I'll be hiding this on in the scrap wood box. I'm just practicing right now. It's a less stressful knowing that your working on a practice piece rather than a display piece.
Anyway this is good practice for when I have to cut the parts for the F9 Panther I'm going to build next year.
PChristy
Phillip
Re: One tough bird
Mitch - Don't throw it away - keep it as a reminder to look back on so that you can see where you have improved in your sawing - I still have one of my first deer that I done - it was not pretty:nah: Looking forward to seeing the F9 when you get it done:icon_thum
AmishWarlord
Mitch
Wow great job Phill. I really like that lay out.
Now if I can improve my sawing as good as you are, and you can improve your macro photography to as good as me well both be set! LOL
TracyP
Tracy
When you told me today it was finished, I could not wait to see it. Awesome as usual:notworthy::notworthy:.
