New Project - Krenov Style Display Case - UPDATED 12/26/2025
JRedding
Thought I'd try a build along, though an abbreviated one, as I've not done that before and have been taking at least a few progress photos. One of our neighbors was a concert violinist before becoming a doctor (talk about an over achiever!) and asked if I'd make him a display case for two of his prized violins. After some back and forth, he really wanted a Krenov style display case. Overall height will be 72", with a 40" tall base and top cabinet at 32". The base will be made of sapele, some of which was sourced from Kluttz and some from our own Mike Davis who had a great largely rift sawn piece for the legs. I was concerned about stability based on design, so did a full mockup out of pine and was pleasantly surprised.
I started by milling 2x2 legs that could then be shaped on the bandsaw.
Because they will curve outward in 2 directions the blue tape helps hold one of the trimmed sides while the other is cut on the bandsaw. Once the are cut, I mark them at the top so I know which is which - you can see it in the pic below (I've messed up the curve before so this avoids that) and then go about final shaping with a combination of handplanes, spokeshave and sandpaper.
At that point, it's time to make the stretchers and get ready for assembly. As you can see from the following, I decided to cheat and use the domino rather than traditional mortise and tenon as I had initially planned (I'm running short on time).
What you can't tell from the picture is that I flipped two legs so that the dominos on 2 legs are to the outside and 2 to the inside - that obviously won't work and after a lot of unkind thoughts (and even a few choice words), I decided on a solution that wouldn't mean starting over on 2 legs.
With a solution in mind, decided to do the glue up and see how it came together.
It looks pretty good so far, though I did have to fix a small length mismatch of about 1/16" so it didn't want to wobble. While you have to look closely, the joinery mistake can be seen in the back left leg facing to the right. The solution . . . corner pieces will be inserted as a "design element" to cover them.
Next up is to route a cove in the top of the base all the way around and then cut some grooves for insets that can be connected to the base and extend inward just enough to allow attachment of the case. After that, it's going to get a finish and on to the cabinet.
For the cabinet, I'm using some very nice tiger maple purchased from one of our sponsors - GPS. I highly recommend GPS as they were very friendly, helpful and incredibly fair in their pricing. And the quality of the maple is really something. The cabinet lumber has been jointed, planed and glued up to oversize, and I hope to be working on that for the next week or so and will post more pics as I go (though probably closer to when the cabinet is together.
More to follow . . .
JRedding
Dan - You’re certainly right and I was going to do so but then decided to take the “quick” way out (which turned out not so quick). Structurally it’s pretty much the same given the size of domino used, but I would have avoided forgetting to think in terms of mirror images.
JRedding
Things are going slowly as I had a small accident resulting in a couple slipped discs that have really slowed me down. That said, have made some progress. To begin, the base is complete and has been finished with a couple coats of satin wipe on poly. I did it with a cloth by hand (rather than a brush or other method) because I like the control in terms of a lighter coat. It was then rubbed out with a brown paper bag.
From there, I started putting in some time on the top cabinet. I decided to use dowel joints for this one, so had to make a jig that was then screwed into each panel sequentially to drill all the holes. There’s a stop at the “back” and I’ve oriented all holes from the back of the case.
Once all the holes were drilled, it was time to insert a few dowels and do a test fit for the case and make sure the dimensions were as intended and correct.
The above is my second picture because when I placed it on the stand the first time, it just didn’t look right - a little too wide and a little too deep. As a result, I cut it down and tried again - thankfully I was able to simply trim and didn’t have to re-drill holes. Then I placed it on the base once again just to see how it looked - looked good.
That’s as far as I’ve gotten. Now that the case dimensions are set, next is to route the inset for the back panel. Initial thoughts are to glue up a 1/2” thick solid tiger maple panel (though I’m also considering a veneered back panel for a bit more stability). Once that’s done, I’ll build the doors and then get the hinges ready to go.
Not sure how long all of this is going to take, but I don’t think I’ll make it before we leave for vacation since I’m not able to spend as much time in the shop while recovering. More to follow.
Rwe2156
DrBob
Just a word of advice: Use mortise and tenon joints with legs that long and you won't have troubles,
100%. Personally I would pin them, especially on something with legs this long.
Traditional joinery is my preference, but there are alternatives and sometimes you do what you have to do. A Domino is ok if the mortise is big enough and deep enough it becomes a floating tenon. Before I sold it, I sometimes used the Domino to make one large slot and either glue in a tenon, or use multiple dominoes. The 500 is limited to some extent.
Not a big fan of dowels, OTOH, they can work, too.
Little curious about the choice of wipe on poly but looks great so far. It’s always fun to build something for someone else.
JRedding
The poly was the neighbor’s choice. I prepared 8 different finishes on sample pieces and that was the look he liked. I was surprised he didn’t select either the oil/varnish or shellac options for the base. He did select the oil/varnish combination for the figured maple case, so that’s what we’ll do and have the two different finishes.
