Need a tree felled and milled in Greensboro
Matt B
I have a tree that I suspect needs to be taken down. I would like to have it milled and stored in my crawl space (which has a dehumidifier). Is there anyone near Greensboro who would be up for coming over to consult, fell, or mill?
Apologies if this is not the correct subforum.
Henry W
Henry
THis is a common query Matt. if you look under the resources tab in header, and find the "Master List..." you can find listing of local resources. Maybe a search of the site looking for "Master List" might find it too.
Here's the link:
https://ncwoodworker.net/forums/ind...wyers-wood-lists-in-google-maps-versions.536/
Check for the Sawyers List there
Mark Fogleman
A more current resource database is here:
These maps detail local hardwood lumber dealers, sawyers, wide board services, kiln operators, and blade sharpeners. Most of these businesses require an appointment. Please message me if you want to be included or have suggestions/problems/edits.​
Save the maps and they will be stored in your "Saved Maps" section in Google Maps. Any time I update them you'll have a current map.
NC Hardwood Lumber Dealers Map
https://tinyurl.com/4shyfrb7
NC Hardwood Plywood Dealers Map
https://tinyurl.com/mpep8cjk
NC Woodworker Sawyers Map
https://tinyurl.com/y5jucayt
NC Wide Board Services Map
https://tinyurl.com/324erbyh
NC Kiln Services Map
https://tinyurl.com/33janfu9
Blade Services
https://tinyurl.com/48m969xa
