My new tool updated cutting pins
erasmussen
RAS
Here it is my ver. of the pantorouter.
Still a few little things I want to change, and add a better router, but it does work.
with a dove tail pattern guide mounted
erasmussen
RAS
Re: My new tool
Nice work there Earl. What tweeks does it need?
I need to move the lower arm on the carriage advance, and need to install an adjustable stop for it.
I really need to get a bearing for the follower, and I am sure I will see more things .
navy1990
Re: My new tool
Darth Earl, you must not stray from the dark side. The force is strong in you. Resist the flat stuff. Flat stock is for the Jedis.
erasmussen
RAS
Re: My new tool updated cutting pins
Cut some pins to show it cutting
think I need to make some knobs for the hold downs.
Joe Scharle
I remember seeing that tool a couple of years ago (video). Forgot about it; so how is it working?
Does it do precision work?
Is it worth the effort?
Thanks, Joe
erasmussen
RAS
Thanks, Joe
It makes a perfect 50% copy of the pattern.
I think it worth it, I made that pattern on the table saw, set the fence with a digital angle finder, then cut spacers with a stop block and used the spacers to cut the pattern. then used the same spacers to cut the guide for the dove tail bit, after i found the correct height for the pattern they fit perfect.
