Moisture meter recommendation
DKA
Kelly
I have not had an overwhelming need for a moisture meter until now.
I will not use it often so I don’t want a top dollar high tech job...just a fairly accurate reading.
Any recommendations ?
I have the Delmhorzt and the General, the General works as well as the more expensive. The Delmhorzt has more features that you probably never use. I have both for work.
KenOfCary
Board of Directors, Secretary
I have the Lignomat pinless. Can be set to read 1/4 or 3/4 into the wood. Very accurate but not cheap. Works great. Easy to take multiple readings on the same piece of wood. You'll find the ends are often drier than the middle.
