The plank is just over 2" thick so I did a 1 1/4" deep x 7/8" x 2" (approximate) mortise & tenon for each of the legs and then tied them together with the same size piece using M&T. A small piece of African Kiaat, a dark hardwood, was used as a foot on each leg. Sanded to 180 grit, stained it and finished with 4 coats of General Finishes oil based satin urethane.Very nice.
I have 2 live-edge planks (black walnut and osage orange) waiting for me to do something like that with them.
Could you share more about the structure you used for the base and what finish you used?
thanks.
Good so far. It's a very heavy bench and if it does start to move, then I'll do something about it, but I believe it's solid and will stay put.Doug…great job, looks awesome! So you mortised the legs into the slab an 1.25” and glued them in? No movement issues side to side without cross bracing between the legs?
