I am a new turner and bought a used Nova 3000 (I think that is the model). The drive pulley assembly is a single piece with several size pulleys. The position of this assembly seems have gradually shifted on the motor shaft, away from the motor. There is a key and keyway on the shaft, with a set screw.
I have loosened the set screw, wanting to shift the pulley assembly in towards the motor. It does not budge. While I could start to use force here, I thought I would ask advice first.
How do I shift the position of this pulley assembly when it seems stuck?
Henry
Henry
