For sale - Festool Cordless Angle Grinder - $500
In like new condition and includes everything in the picture. One of the batteries is bluetooth compatible so you can use a bluetooth dust extractor (bluetooth compatible), or with a bluetooth remote control.
Price is cash only, local pickup in Cary, NC. No cash apps please.
Includes:
Guard SH-AGC 18;
Auxiliary handle VIBRASTOP;
Quick-acting clamping nut QNR-AGC 18;
Flange BF-AGC 18;
Key KF-AGC 18;
2 x BP 18 Li 5.2 ASI battery pack;
Rapid charger TCL 6
Sys3 systainer
The powerful AGC 18 cordless angle grinder is highly durable and built for the professional remodeler who needs
reliable, versatile performance. With its enclosed brushless motor, protected electronics, and variable speed, the AGC
18 is built to last and perform in a broad variety of applications. This powerful grinder is extremely simple to use —
with a keyless arbor and guard change, variable speed, and a unique battery position for cut-off operation.
Features:
Work appropriately for the material: Speed can be steplessly adjusted between 4500 and 8500 rpm
Ideal ergonomics for cutting work: Its design means that it fits well in the user's hand, runs smoothly and generates few vibrations
Get results fast: Thanks to the powerful, brushless – and therefore maintenance-free – EC-TEC motor
Safety while working: Soft start-up, electronic overload protection, motor brake and restart protection ensure safe work
Robust and long-lasting: Enclosed motor and cast electronics are safely protected against dust
Systems get it done: Compatible with the battery packs and chargers in the Festool 18 Volt System
Applications:
Cutting the toughest materials (metal, stone and concrete materials)
Easy grinding and roughing work (e.g. deburring metal)
Specifications:
Battery voltage 18 V
Idle engine speed 4 500 - 8 500 RPM
Disc dia. 4-1/2“ (115 mm)
Spindle thread/flange 5/8“
Li-ion battery capacity 5.2 Ah
Weight with Li-ion 5.95 lbs (2.7 kg)
Surface sanding: Total vibration average, Ah 5.00 m/s²
Surface sanding: Uncertainty (noise) K 3.00 dB
Surface sanding: Uncertainty (vibration) K 1.50 m/s²
Surface sanding: A-weighted sound pressure level, LpA 86.00 dB(A)
Surface sanding: A-weighted sound power level, LWA 97.00 dB
Includes:
Guard SH-AGC 18;
Flange BF-AGC 18;
Key KF-AGC 18;
Rapid charger TCL 6
Sys3 systainer
Features:
Applications:
Specifications:
