Not a bad deal..........
http://raleigh.craigslist.org/tls/2674063153.html
DeWalt DW788 Variable-Speed Scroll Saw - $250 (Hillsborough NC)
Date: 2011-10-28, 5:55PM EDT
Reply to: sale-xbefc-2674063153@craigslist.org [Errors when replying to ads?]
Excellent condition with little use. Need room in my shop or I would keep it along with other tools I am selling. Cash and carry. Try it before you buy it!! Saw is mounted on a piece of sheet goods for clamping to a bench top .. No Stand! $250
Heavy-Duty 20'' Variable-Speed Scroll Saw
Double parallel-link arm design dramatically reduces vibration and noise, for extremely accurate cuts.
Exclusive tool-free blade holders allow blade changes in seconds.
On-off switch, electronic variable speed, flexible dust blower and blade-tensioning lever are all located on the front upper arm for added convenience.
Arm design moves the tool's pivot points from the back of the saw to the front, shortening the arm movement for smoother, quieter operation.
Arm lifts so blade can be easily threaded through the material for inside cuts.
Unique arm design keeps the blade perpendicular to the work, dramatically reducing over- or under- cutting.
Oversized, cast-iron table provides excellent material support and bevels 45° left and right.
SPECIFICATIONS:
Amp Rating (120V AC) 1.3
Stroke Length 3/4''
Strokes Per Min. 400-1,750 spm
Depth of Cut 2''
Tool Weight 56.0 lbs.
PostingID: 2674063153
SPECIFICATIONS:
Stroke Length 3/4''
Depth of Cut 2''
- it's NOT ok to contact this poster with services or other commercial interests
