Wasn’t exactly sure where to post this, so please let me know if this question should be directed elsewhere!
I’ll try and keep this short and sweet and leave it to those of you with a bit more knowledge to ask the pointed questions I don’t know to ask myself.
Spent a lot of time growing up building things with my dad, just now getting to outfit my first garage (have one full side for workshop area). Decided I wanted to start out with a good compromise between full on cabinet saw and older used contractor, so I found an older used Craftsman 22116 in great shape – save for one small issue.
Older gentleman I bought it from disclosed up front that the tilt/bevel adjustment wheel was tight. He attributed it to tightening the trunnion bolts down too much when he had the top off to change arbor bearing. I asked him pointedly if he knew that’s what was wrong and if that was the only issue, and he said he was certain that was the only thing wrong and that I just needed to yank the top off and slightly adjust the bolts.
So I took the saw apart (which I actually enjoyed and found useful – good to know how everything works and is put together) and loosened the trunnion bolts. Loosened them too much though, and the trunnion slipped out of the bracket and gave me a bit of a scare. Managed to get the trunnion seated back in the brackets and the bolts tightened though and we’re all good now.
Anyway, so I’ve been examining the assembly for the tilt/bevel and I think it has something to do with the trunnion arm (not exactly sure what that part is called) not centering on the worm gear? I’ve done a bit of Googling and it seems this may be an issue that’s cropped up on the R4511s, the Ridgid brother to this saw (or so I’ve read).
So I’m not exactly sure where to go from here. Do I loosen bolts and try and maneuver entire assembly until the arm seats centered? I read somewhere about a small nut that may need to be adjusted to move the worm gear under the arm, as opposed to moving trunnion around to get arm centered. Maybe that’s the culprit?
This is my first time getting into the guts of a saw but I’m interested in learning and DIYing this fix if possible. I’ve attached some various pictures – please let me know what other information would be helpful, pictures, etc.
Thanks!
Thanks!
