I never seem to be without some project with having four daughters!
My second oldest will be presenting us with another grandchild in February and just before Thanksgiving she asked me to put together a change table based on a picture/plan that she saw from Ana White....
http://www.ana-white.com/2012/12/plans/changing-table-brookstone
They have quite a country theme going on all through their house, so this is what they wanted to be represented.
This is the finished product ......
Primarily built with poplar and bead board paneling. Most joinery using 3/8 dowels.
The only real challenge was working in two sliding trays on the top ends of the case. I ended up building a web frame for each end and placing it just far enough inside the case to allow clearance for the sliding trays. I did epoxy some 3/4" aluminum angle to the web frame to allow for a smoother travel for the trays.
For a finish, they selected Seagull Gray General Finishes Milk Paint. I gave the whole cabinet 3 coats of the milk paint using brushes and a 4" foam roller and top coated by spraying 4 coats of General Finishes High Performance Satin clear coat. Door hardware was cast iron full wrap hinges and knobs from Amerock.
All done and delivered yesterday.
Thanks for looking.
Thanks for looking.
