Compound Mitre Saw
I'm looking at purchasing a new compound mitre saw and was told by a freind I should purchase a belt driven saw.
I know nothing about who manufactures a belt driven mitre saw.
If anyone has experience with abelt driven saw, please help. I'm not sure there is such a tool.
NCPete
Pete Davio
Not sure off the top of my head how many non-sliding compound miter saws have belt drives... That represents a significantly larger investment.
James Anderson Jr
James
I believe the dewalt slider is belt drive. I used one for several years while working for a company doing home remodeling in Charlotte; I loved that saw!
Makinsawdust
Robert
I believe the Hitachi saws are belt driven. Seems like Lowe's carries the 10" or 12" Hitachi slider with the belt.
Charles Lent
Charley
The reason for the belt drive is to get the motor up and out of the way to allow for tilting of the saw to 45 deg in both directions. Tilting a non belted miter saw toward the side with the motor would not allow more than about a 20-30 deg tilt. If you look at the saws that are available you will notice that the ones that can tilt in both directions have the motor mounted above the blade, thus requiring a belt to connect the motor to the blade.
Charley
I've been very happy with my makita, got the best reviews I could find online.
Vetteman9956
Brad
Bosch has a new saw out with knuckle joints instead of rails. you can put it up against a wall instead of having it stick ouit into the shop. Neat idea that you might check out
farmerbw
Brian
Brad, I saw one of these in Payne's the other day. It was really nice and had a real smooth movement. :icon_thum:icon_thum
Granted the $880 price tag was outta my reach for now!!! :swoon: :gar-Cr
Brian
manfre
Manfre
I've been using the Kobalt 10" for over a year with no real complaints.
Edit:
Factor in the depth of your workbench. The rails stick out really far in the back and my saw needs more than 2' to fit properly on a bench. My next saw will most likely be one of the newer ones without rails. E.g Bosch's glider
I got a 12 inch Hitachi dual bevel that is belt driven from reconditionedtoolsales for $150. It has a little wobble in the blade but makes good cuts (you just have to allow for the wobble). It is not a slider, however, so the crosscut is only about 8 inches. OK for most hardwood boards in my experience. They also sell sliders at this source. I don't think you could tell it from a new one when I got it.
