Bosch 12 inch Miter Saw
Canuck
I recently purchased a Makita 10" slider (model LS1019L) with soft start. Is performing very well for me!
Robert166
robert166
Did you get the stand for it as well? I see Home Depot is offering the stand and saw for $599.00.
Canuck
Yes. Got the Makita stand as well.
(I purchased mine from Acme Tool and the stand was part of a Makita promo- same price.)
The chatter from some of the people I know is the Bosch 10" saw is only outdone by the Festool. The 12" does not rise to the same level. My guess it has more to do with a 12" blades and the chatter associated with a blade that size......... just the commentary from the locals.
chris_goris
I have the 12" version, while Ive never used the Festool , this saw is second to none that I can tell.
tvrgeek
Seems a lot of mixed reviews. Some suggest way too much slop and dust collection is terrible. Others love the daylights out of them.
I gave up on thinking any miter saw was a woodworking machine. Carpentry only.
Curious, the reference to the 10 vs 12. Older rear rail Makita was loved. New one much sloppier. I wish I still had my simple original Delta as at least it was not sloppy. Way too short of capacity, but was a reliable tool and was light enough to be actually portable for carpentry jobs.
I kinda agree with you. The miter saws all have a certain amount of inaccuracies to contend with. The thing that helped my Dewalt was getting a better full kerf blade. But, tbh, with fine woodworking most of the cutting is with smaller pieces, so a 7-8" miter saw would be enough.
chris_goris
The key is letting the blade do the cutting, too many people try to horse them down through a cut. Thats where you get deflection and innacuracies.
Rwe2156
DrBob
This is a good point. There's inherently some flex in all the ones I've looked, but some are definitely worse than others. I do believe motion dynamics when pulling back and making the cut are a factor you have to think about not horsing through a cut.
The other factor is the blade. A thin kerf is going to flex and you can get a wavy cut path.
I view my miter saw as a cut off saw, I do the accurate 90's on a table saw sled b/c I can't trust the Bosch to be perfect 90. Kind of disappointing for a $600 saw. Plastic indexing lever (???) Of course, I'm coming from a furniture making mindset, not construction.
chris_goris
I use mine almost daily for dead on 90s with a thin kerf Forrest blade
mpeele
michael
If you are making a through cut on a slider pulling out that's a recipe for poor performance on any slider. You cut through on push stroke.
If you are getting a wavy cut on any blade thickness on any saw your feed rate is too fast for the blade or you blade is dull or damaged.
Robert166
robert166
I got this reply from Bosch.
Thank you for contacting Bosch!
I appreciate your interest with our Bosch Miter Saw.
Our Bosch CM10GD has the soft start feature. You can go to: CM10GD | 10 In. Dual-Bevel Glide Miter Saw | Bosch Power Tools to check on this.
If you need further assistance, please feel free to contact us back. You can respond to this email or call us at 1-877-BOSCH99 (1-877-267-2499) Mon-Fri: 7:00-19:00 CST.
The link states it is a no-load motor, is that the same as a soft start?
DJB
Dan
Brand new member today, I own a Bosch 12" miter saw, GCM12SD, that I have not liked since new. My old Porter Cable non-sliding saw was much more accurate. The blade on this Bosch wobbles to the point that I can't get a clean miter cut when needed. I have replaced the blade several times with no change. I actually took one of the blades to a machine shop and had it straightened and balanced, didn't help. I just purchased all the internal parts that have anything to do with the blade thinking something is bent or machined incorrectly. I have not received the parts yet but at this point, If they don't fix the problem, I will give this one away and look elsewhere for my next purchase. I don't want to sound like a grumbler, most of the tools in my shop do a great job. This saw just hasn't lived up to its reputation.
I did contact Bosch. very courteous but was unable to give any ideas or help.
chris_goris
where did you buy it?
Pop Golden
Pop
I have a Bosch 12" miter saw. It is not a slider. Sliders have play in the sliding mechanism. My saw is dead on with 90 degree or angles. I really don't understand some of the problems. I haven't experienced any of the things listed. I use a thin kerf blade. If I really want to make heavy cuts I have my Delta RAS. Because I'm working with small things every cut is slow an easy.
Pop
DJB
Dan
I bought it from a local wood working retailer. They no longer carry Bosch tools. They are now carrying Festool. I bought this saw before the big box stores started selling them.
A friend of mine just bought the same saw from Menards and says his is very smooth and is happy with it. that gives me hope that the parts I ordered will solve the vibration problem.
