sewing machine motor for small lathe?
I kinda like the idea of a foot switch.Intriguing idea. I'd guess there's a little figuring to how you'll hook up a substitution for the footswitch control usually used.
Keep us updated. You may be on to something.
They are available up to 800 watts for not much more.my 7"x 16" benchtop metal lathe uses a 500w brushless motor , lots of power , the trick might be in the belt and pully set up to get the speeds you want with the torque needed.. I've seen 750w kits with this type of motor for lathe upgrades.. (cost alot more but they are bolt up with belt brackets and pully included..
You’re not as che...—— frugal as I am.It should work fine. Personally I would go with the 750 watt model for $120
