I built a cabinet (32" high, 22" wide, 18" deep). On either side, it will have a shelf that flips up. Each shelf is attached to the cabinet via a piano hinge, and is 24" long and 10" wide.
Although quite different from what I built, the following picture will give you an idea of the wing:
Obviously, I will need a support for the shelf. I plan to use a simple "arm" of hardwood (3/4" x 3x4") that will attach to the cabinet via a small section of piano hinge. On the shelf, I will put a bracket that the arm will catch on.
Got all that? Good.
I'm trying to work out the optimal length for the arm. See the image below.
Here, ac is the cabinet, ae is the fold-up shelf, and bd is the arm. Normally, the shelf will hang down. I want the arm to be concealed by the shelf in this position.
The pivot point for the arm is located at b. Since the shelf is 24" long, ab + bc is also 24". The longer arm bd is, the stronger the support will be. But, the longer I make bd, the more obtuse the angle abd must be to compensate (as bd increases, ab must decrease to keep the ab + bc = 24). The more obtuse the angle, the weaker the support. There has to be an optimum.
My gut tells me 45 degrees for abd would be best. Applying basic trigonometry functions means arm bd is a little over 14" (14.06 to be exact). That seems reasonable.
For all you structural engineers out there - is 45 degrees the best option? Should I increase the angle to 60 degrees (effectively moving the pivot point up) and increase the arm length to 16". Better, worse?
Got all that? Good.
