Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
  1. #1
    Forum Leader Corporate Member
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Mating PVC to Dust Collector Inlet
    I know the topic of dust collection piping has been beaten to death in here, but I haven't been able to find an answer to this question. I'm finishing up running my 6" D-2729 thinwall pipe and am ready to make the connection to the inlet of my collector (2HP Laguna Cyclone), but cannot figure out a good way of mating them. The cyclone inlet port fits easily inside the thinwall pipe, but I can see that causing an issue with dust and chips getting snagged on the way in and causing a blockage since there's about 1/8" difference between the inside diameter of the pipe and the outside diameter of the inlet which results in a 1/16" gap between the two.
    I thought about using a very short piece of flex to mate the two, but that seems to defeat the recommended goal of getting about 3 to 5 feet of straight smooth pipe at the inlet to the collector before the first bend or piece of flex.
    I looked at the Fernco rubber couplers, but since they're made to made to cast iron, they are way too big to work on this one.
    Any ideas or suggestions from you guys?
  2. #2
    DQ
    Charlie's Avatar
    Nickname
    Charlie (72)
    Join Date
    Nov 2008
    Location
    Raleigh, NC
    Posts
    1,716
    Visit Freq
    6.96 visits/week
    Threads
    130
    Classifieds
    Re: Mating PVC to Dust Collector Inlet
    Crimp the end of the 6" so it fits inside the cyclone inlet.
  3. The following user says Thank You to Charlie for this useful post:
  4. #3
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Charlie View Post
    I'm working with PVC pipe Charlie, I'm not aware of any method to crimp it like you suggest.
  5. #4
    DQ
    Nickname
    Join Date
    Dec 2005
    Location
    Winston-Salem, NC
    Posts
    1,522
    Visit Freq
    6.88 visits/week
    Threads
    176
    Classifieds
  6. The following user says Thank You to zapdafish for this useful post:
  7. #5
    DQ
    DanR's Avatar
    Nickname
    Dan
    Join Date
    Mar 2011
    Location
    Hillsborough, NC
    Posts
    273
    Visit Freq
    0.96 visits/week
    Threads
    Classifieds
    I used a rubber coupler, I don't remember for sure, but I think I got it at Lowes and that they have the ones for cast and also for the sewer and drain pipe.
    The sewer and and drain pipe can be resized with a heat gun. If you have a lathe and turn a cylinder with a taper at the first inch you can heat the pipe and pound in the cylinder. I have not done this, but have seen similar on YouTube. If you don't have a heat gun I bet a pot of boiling water would do fine.
    Have a good one,
    Dan
  8. The following user says Thank You to DanR for this useful post:
  9. #6
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,883
    Visit Freq
    6.92 visits/week
    Threads
    204
    Classifieds
    You may wish to just go ahead and try it as is. I would be very surprised if you ever had a clog as a consequence of the 1/8" lip provided you have an appropriate amount of air flowing through your ducting. There are people who use corrugated pipe for their flex hose, a far worse alternative from a flow perspective, and you do not find widespread reports of clogging with such setups.
    But if the lip really bothers you you could always sand, grind, scrape, or router a chamfer into it so that it is beveled and presents a much thinner initial cross section. You will, however, need to use something to make for a tighter fit as a very loose fit is obviously problematic.
  10. The following 2 users say Thank You to ehpoole :
  11. #7
    Newbie
    Nickname
    Join Date
    Mar 2017
    Location
    University of NC, NC
    Posts
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    +1 on heating the PVC. Did it to make my connections. Regarding crimping the PVC, you can cut some slots in it so it can "crimp" inside the inlet either way would work, a little Duct tape does wonders.
    Sent from my XT1585 using Tapatalk
  12. The following 2 users say Thank You to wasmeneh :
  13. #8
    DQ
    Charlie's Avatar
    Nickname
    Charlie (72)
    Join Date
    Nov 2008
    Location
    Raleigh, NC
    Posts
    1,716
    Visit Freq
    6.96 visits/week
    Threads
    130
    Classifieds
    OOOps!
    Yes, heat the PVC and shrink it. Install a band clamp on the PCV, slide the the unit over the cyclone inlet, heat and close the clamp until it's tight on the inlet.
  14. The following 2 users say Thank You to Charlie :
  15. #9
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Thanks everyone! The heating up the pipe and using a band clamp worked like a charm.
  16. #10
    DQ
    allisnut's Avatar
    Nickname
    Adam
    Join Date
    Oct 2011
    Location
    Shelby, NC
    Posts
    792
    Visit Freq
    6.42 visits/week
    Threads
    143
    Classifieds
    On a completely unrelated note, I was a a genius and hero to my 12 year old a few weeks ago. He wanted to make a fender for his BMX bike. I split a piece of 2" pvc length wise, held one end in the wood stove for a couple minutes, molded it around the tire, and repeated with the other end. He was amazed. I was a genius for almost 10 minutes.
    I'm glad you got your probelm resolved, I was going to suggest heating the pvc and shrinking it.
  17. #11
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by allisnut View Post
    If only they would remember that you're a genius for the rest of their lives. Sadly, it fades....
  18. #12
    DQ
    Nickname
    Ray
    Join Date
    May 2007
    Location
    Vass, NC
    Posts
    293
    Visit Freq
    2.77 visits/week
    Threads
    Classifieds
    Got here late and it seems you got your answer ...heating and reshaping the pvc...but could you share where you got your 6 " 2729 thin wall PVC?
    Thanks
  19. #13
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by woodlaker2 View Post
    Thanks
    Ruehlen Plumbing Supply in Concord stocks it.
  20. The following user says Thank You to LB75 for this useful post:
  21. #14
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Thanks
    Looks like Ruehlen also has a location in Albermarle, little bit closer to you.
  22. The following user says Thank You to LB75 for this useful post:
  23. #15
    DQ
    DanR's Avatar
    Nickname
    Dan
    Join Date
    Mar 2011
    Location
    Hillsborough, NC
    Posts
    273
    Visit Freq
    0.96 visits/week
    Threads
    Classifieds
    Quote Originally Posted by LB75 View Post
    George, what was the band clamp for? Did you heat it and then wrap the band clamp around to shrink it?
    Have a good one,
    Dan
Similar Threads
  1. Source for new fine dust bag for Dust Boy dust collector
    By PhilCK in forum Power Tools and Their Use
    Last Post: 05-02-2016, 11:57 AM
  2. Dust Deputy vs. HF Dust Collector
    By Flute Maker in forum Power Tools and Their Use
    Last Post: 07-02-2015, 08:05 AM
  3. Oneida Super Dust Gorilla Cyclone Dust Collector Installation
    By Jeremy Scuteri in forum General Woodworking
    Last Post: 02-28-2015, 02:26 PM
  4. 5" Dust COllector Inlet?
    By buildintechie in forum Workshop Discussion
    Last Post: 01-12-2011, 09:47 AM
  5. Anyone enlarge their inlet port to 6" on HF, 2HP dust collector?
    By kooshball in forum Workshop Discussion
    Last Post: 07-19-2010, 06:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
