Klingspor's Woodworking Shop (Festool) Ad #2
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
  1. #1
    DQ
    JohnW's Avatar
    Nickname
    John (64)
    Join Date
    Feb 2007
    Location
    Charlotte, NC
    Posts
    827
    Visit Freq
    5.65 visits/week
    Threads
    Classifieds
    OWWM Scroll Saw Question
    Acquired a 1950 ish Walker Turner 24" scroll saw about 10 years ago and it has been taking up room ever since. With the exception of a pulley cover, all parts appear to be present and in good working condition. I have never used a scroll saw and would not know the difference between this old unit and a newer model. Is this thing worth fixing up and using as a scroll saw? I remember someone once told me that this type of saw was no good and would not compare to a new lower end Delta let alone a + 1,200.00 German model.
    I've fixed up a 1950 ish Rockwell/Delta bandsaw and Dewalt RAS and they are awesome. So I'm wondering if this OWWM would also be a solid performer if refurbished. I've been told NO...but don't know why. Opinions welcomed.
  2. #2
    Board of Directors
    Secretary
    DQ
    Michael Mathews's Avatar
    Nickname
    Michael (55)
    Join Date
    Mar 2012
    Location
    Chapel Hill, NC
    Posts
    1,404
    Visit Freq
    5.27 visits/week
    Threads
    140
    Classifieds
    Re: OWWM Scroll Saw Question
    Maybe Bill Clemmons will jump in here. I think he has one similar to this. I'm not very familiar with this unit, but I would say the mass that is oscillating up and down might tell you something about how much vibration you might incur with this unit. I have the Dewalt 788 Type1 unit and just the short blade-holding arms at the front oscillate. Therefore, much less mass moving and more solid weight to keep the whole thing steady. Also, you might look and see how difficult and secure the blade holding is. On mine, it's very fast and secure. Setting tension on mine is just the turn of a small lever near the front. I'm not sure how this is done on this unit. I would say it'll probably be a great looking machine all cleaned up and in sound working condition. Someone that collects these old machines just might like to have it in their shop! Good luck!
  3. The following user says Thank You to Michael Mathews for this useful post:
  4. #3
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,125
    Visit Freq
    7.00 visits/week
    Threads
    711
    Classifieds
    I believe that model has a spring in the upper arm and the blade is pulled from below. Very little mass is actually moving. The blade does take some time to change. Probably not the best for lots of short inside cuts but great for puzzles, sign lettering, and larger cutouts.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  5. The following 3 users say Thank You to Mike Davis :
  6. #4
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,591
    Visit Freq
    6.92 visits/week
    Threads
    512
    Classifieds
    One question that comes to mind immediately is does it use straight blades or the kind with pins at each end. The no-pins version is much preferred.
    What Mike and Mike said makes good sense as well.
    Ban shredded cheese, make America grate again.
    "May the grain be with you" - Roy Underhill
  7. The following user says Thank You to KenOfCary for this useful post:
  8. #5
    DQ
    sawman101's Avatar
    Nickname
    Bruce Swanson
    Join Date
    Feb 2009
    Location
    Newton, NC
    Posts
    2,813
    Visit Freq
    6.69 visits/week
    Threads
    173
    Classifieds
    My father had a similar Walker-Turner saw which eventually became mine. The big difference was it had a variable speed set up where you turned a small crank to increase the speed. My dad used it to cut out letters for signs, but that was all it was ever used for. The spring is in the top arm, as Mike said. The top crank is turned to set the tension. the pulley on the side drives a pitman which moves the blade up and down. The top and bottom arms are stationary and although there isn't much mass moving, it produced much vibration which makes it uncomfortable to use. Other than the aesthetic value of using an antique machine, it is impractical for the inside cuts used in most scroll saw patterns. It will work ok for outside cuts.
    Experience is a hard teacher; she gives the test first, and the lesson later.
  9. The following user says Thank You to sawman101 for this useful post:
  10. #6
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    517
    Visit Freq
    5.00 visits/week
    Threads
    Classifieds
    I've run into a few of those over the years. Some were in junk condition, but most ran smoothly. That one looks to be in particularly complete condition. On a worn out machine, the little stud on the upper plunger assembly will wear the slot. That slot looks good. There also looks to be an OEM lamp. That's rare.
    I have a Delta of that same size and rarely do I not use it for some little thing or another during the week. I haven't done a scroll saw project in a couple of decades, but my saw keeps sawdust on it. Actually I'll use the scroll saw more frequently than I will a drill press.
    Saws of that size and capability are best suited for detailing 3/4" thick wood. For pierced work like hand holds, its about the only thing unless you want to use a hand held saber saw.
    The smooth cut works well for profiling jigs for the shaper and router table.
    Of course, there's the issue of safety when cutting small pieces. I often consider my scroll saw to be an 1/8" band saw that I can do pierced work.
    If your intent is to use it on 1/4" plywood cutting out picture profiles with a very fine blade, it might not be as suitable as other scroll saws specifically built for that type of work.
  11. The following 2 users say Thank You to bob vaughan :
  12. #7
    DQ
    JohnW's Avatar
    Nickname
    John (64)
    Join Date
    Feb 2007
    Location
    Charlotte, NC
    Posts
    827
    Visit Freq
    5.65 visits/week
    Threads
    Classifieds
    Thanks guys, great info. The saw runs well and has very little vibration. What vibration it does have looks to be coming from the old drive belt which I'll change.
    Bob, your description of using it as a 1/8" bandsaw was the perfect motivation to go ahead and get it running. I might try scrolling at some point but right now having a tight turn cutting machine without having to change out blades on the other bandsaws makes it worth keeping. I inherited this and a few other OWWM's from my FIL so getting rid of it is not something I want to do. But if they take up space, they must have a purpose.
  13. The following user says Thank You to JohnW for this useful post:
  14. #8
    DQ
    Nickname
    Pete (66)
    Join Date
    Dec 2016
    Location
    Tallahassee, FL
    Posts
    Visit Freq
    3.65 visits/week
    Threads
    Classifieds
    When I was a kid we had a similar one in Dad's shop. It didn't vibrate much at all. It wasn't the greatest for really fine scroll work at least with the blades we had, but it was a work horse that we used a lot. We didn't have a band saw and it was at least a partial substitute for that. I kind of regret not keeping it when we sold the house after mom passed. I didn't have room for it at the time. There were a number of other things that I wish I had kept from Dad's shop, but I did manage to keep some of the smaller tools that I had room for at the time.
  15. The following 2 users say Thank You to PeteStaehling :
  16. #9
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    517
    Visit Freq
    5.00 visits/week
    Threads
    Classifieds
    Here's a muddy video of my scroll saw at work on 1" thick hard maple
    (its photo bucket, so its fussy sometmes)
    http://s142.photobucket.com/user/rmv...tml?sort=3&o=0
    Attached Files Attached Files
  17. The following user says Thank You to bob vaughan for this useful post:
  18. #10
    DQ
    JohnW's Avatar
    Nickname
    John (64)
    Join Date
    Feb 2007
    Location
    Charlotte, NC
    Posts
    827
    Visit Freq
    5.65 visits/week
    Threads
    Classifieds
    This scroll saw has been sitting in my shop for many years and had never been used, or plugged in. Cleaned it up last night and got familiar with how it works, then plugged it in.
    DANG, the light works, the air diaphragm works, everything works. Did the coin test and had no trouble keeping a penny on edge. So much cast iron mass that there is very little vibration. It can use pinned or straight blades but I'll be using straight.
    Only two issues I've found are:
    Pulley shaft connected to the saw drive has 3/16" play in and out. Not sure if it's designed that way to allow for better alignment of the belt when changing speeds, or something needs to be tightened or its worn out.
    Drive looks like it was designed to run in an oil bath and there was no oil in the case. Parts had a film of lubrication on them and no sign of wear. It's been sitting idle for 15 years so it may have leaked out or never was filled. Gasket looked good.
    I will definitely be able to use this saw. Need to fill with oil, replace wiring and add switch on front of machine. The on off switch is on the back side of the arm and that seems like an inconvenient location.
  19. #11
    DQ
    Nickname
    Pete (66)
    Join Date
    Dec 2016
    Location
    Tallahassee, FL
    Posts
    Visit Freq
    3.65 visits/week
    Threads
    Classifieds
    Good luck with it. If you have the space I think you will find it will be worth keeping. For me it could fill the same niche between my 14" band saw and my scroll saw that is now occupied by a 9" bandsaw. That little saw is used for little incidental things many times a day pretty much every day.
    Back in my Dad's shop when I was young, a saw much like it served as the only option for the stuff I now do on the 14" band saw, the 9" band saw, and the scroll saw. We were limited in that we couldn't do some of the things a 14" bandsaw would do, like re-sawing, but some really nice projects came out of that very limited shop.
  20. #12
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    517
    Visit Freq
    5.00 visits/week
    Threads
    Classifieds
    For oil, I'd recommend 10W30 Mobile 1 engine oil. Good stuff.
    That play could be that the wrong step pulley is on there. Below shows me holding a stock step pulley beside an OEM pulley. Note the size difference between the smallest grooves. For general wood cutting, the highest speed is preferable.
    VintageMachinery.org has several manuals on that machine.
    http://<a href="http://vintagemachin...hinery.org</a>
  21. The following user says Thank You to bob vaughan for this useful post:
  22. #13
    DQ
    JohnW's Avatar
    Nickname
    John (64)
    Join Date
    Feb 2007
    Location
    Charlotte, NC
    Posts
    827
    Visit Freq
    5.65 visits/week
    Threads
    Classifieds
    Bob, I have the OEM pulley but do not have the nut at the end of the shaft. So it may just need adjustment and fastened. I downloaded some info from OWWM many years ago and have that in a binder. vintagemachine looks to be a different/new site based on info from the older site?
    Sprayed the innards with silicone lubricant just to keep it oiled while I work on it running at the slowest speed. Thanks for the oil tip. I have that "in stock".
    My first cut on this saw. Made a new insert.
  23. #14
    User Pop Golden's Avatar
    Nickname
    Pop (77)
    Join Date
    Jul 2011
    Location
    Charlotte, NC
    Posts
    805
    Visit Freq
    3.96 visits/week
    Threads
    Classifieds
    196051.jpgI have the Powermatic version of that saw. In spite of the new names on machines that is not a scroll saw, but a jig saw. Blades are a problem. scrollsaw blades are not strong enough for this saw. I make blades using 5 in. bandsaw stock and grinding about 1/4 in. of teeth off both ends. The teeth fight you when trying to chuck up a blade. I use my saw to cut internal stright cuts. I have a fence on it to do that. It is more powerful than most scroll saws and cut much thicker stock. For oil I use 30 weight non-degergent. That's what my air compressor called for. I also have a DeWalt scrollsaw & a Shopsmith 11 in. bandsaw running 1/8 in. blades for detail work. Here's a photo of my saw.
    Pop
    ​With Enough Thrust Pigs Fly Just Fine.
  24. The following user says Thank You to Pop Golden for this useful post:
  25. #15
    Nickname
    Bob Vaughan
    Join Date
    Sep 2009
    Location
    Roanoke, VA
    Posts
    517
    Visit Freq
    5.00 visits/week
    Threads
    Classifieds
    Below is the 1997 price list or the above Powermatic 95 scroll saw. Back in the day, all of the 24" scroll saws were pretty competitive in price. This indicates what that Walker Turner would sell for today if it were available.
  26. The following user says Thank You to bob vaughan for this useful post:
Similar Threads
  1. Scroll saw question
    By Rwe2156 in forum Power Tools and Their Use
    Last Post: 11-02-2014, 09:23 PM
  2. Scroll saw question
    Last Post: 08-14-2014, 08:36 PM
  3. Scroll Saw
    By wooduser in forum Reviews
    Last Post: 12-29-2010, 07:01 AM
  4. Very first cut ever with a scroll saw
    By HERIJOBR in forum Scrollsaw Work
    Last Post: 07-23-2010, 09:19 PM
  5. scroll work question
    By dlrion in forum Scrollsaw Work
    Last Post: 02-12-2010, 06:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
