West Penn Hardwoods (Ad 1)
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
  1. #16
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,593
    Visit Freq
    6.92 visits/week
    Threads
    512
    Classifieds
    Re: Basement Subfloor Questions
    I can bring some of the samples (leftovers) to the next Board Meeting - we should have one soon, BTW. That picture looks close but as Mike mentioned there are channels to let water flow under the foam in mine. The channels are just a bevel in the foam towards all 4 edges. It is 2'x2' T&G interlocking pieces. It is a floating floor - you leave a 1/4" gap around the edges and use some molding (1/2" quarter round) on top the edges and let it float underneath that.
    The OVRX tolerates slightly uneven floors, but the Dri-Core has to be shimmed level - another advantage.
    Here's the thread from back when I installed mine.
    http://www.ncwoodworker.net/forums/s...ad.php?t=46429
    Ban shredded cheese, make America grate again.
    "May the grain be with you" - Roy Underhill
  2. The following user says Thank You to KenOfCary for this useful post:
  3. #17
    Board of Directors
    Development Director
    DQ
    Jeremy Scuteri's Avatar
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,636
    Visit Freq
    6.42 visits/week
    Threads
    298
    Classifieds
    I contacted Barricade and I got this response from them:
    Good afternoon Jeremy,
    BARRICADE is no longer available in the US. DRIcore is the sister brand of Barricade and is the only brand available in the US.
    DRIcore offers an insulated panel as well as the air gap panel. Please see product summaries below:
    DRIcore R+ (Insulated panel)
    R-Value: 3
    Air Flow: Yes
    Height: 1”
    Top Composition: OSB
    Bottom: Composition XPS Foam
    Weight: 6.5lbs.
    Size: 2’ x 2’ Nominal
    Warranty: 25 Years
    Panels are designed with friction fit tongue and groove.
    Finished Flooring Options: Laminate, Solid / Engineered Hardwood, Carpet, Vinyl, Tile
    DRIcore Subfloor (Standard Panel)
    R-Value: 1.7
    Air Flow: Yes
    Height: 7/8”
    Bottom Composition: Polyethylene
    Weight: 7.5lbs.
    Warranty: 25 Years
    Supports up to 4000lbs/sq.ft.
    Subfloor panels are designed with friction fit tongue and groove, eliminating the need for glues or other coupling attachments.
    DRIcore Subfloor will provide you with 75% more airflow beneath your floor than the R+. R+ will provide you with 50% more R Value than the DRIcore Subfloor.
  4. #18
    Forum Leader Corporate Member
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Jeremy Scuteri View Post
    Ken,
    Just to be 100% clear, this is what you have?
    Jeremy, I had this exact thing on the concrete slab in my basement until this past summer. It worked great, was pleasant to walk on and the floor never felt cold. Ended up having to rip it all though due to a foundation leak that I wasn't aware of. Water was getting in behind a finished wall, hitting the original linoleum on the slab and then just spreading out under the insulated OSB. They were fitted so tightly together that the water had nowhere to go and couldn't evaporate. I didn't discover the problem until I started noticing soft spots developing in the floor. In all I had to rip out about 900 square feet of it.
    If I wasn't face with the prospect of any potential foundation leaks in the future, I would definitely use the stuff again.
  5. The following user says Thank You to LB75 for this useful post:
  6. #19
    Board of Directors
    Treasurer
    DQ
    KenOfCary's Avatar
    Nickname
    Join Date
    Mar 2010
    Location
    Floyd, VA
    Posts
    7,593
    Visit Freq
    6.92 visits/week
    Threads
    512
    Classifieds
    R-Value: 3
    Air Flow: Yes
    Height: 1”
    Weight: 6.5lbs.
    Warranty: 25 Years
    R-Value: 1.7
    Air Flow: Yes
    Height: 7/8”
    Weight: 7.5lbs.
    Warranty: 25 Years
    Wow! That is super disappointing. I looked at Dricore and it is not feet supportive. It is a rigid plastic under-layer that has no give. All that R-value and airflow stuff is irrelevant to me versus the comfort factor. I'm looking to move sometime in the near future and may end up with concrete floors for a future shop - hopefully bigger, but if OVRX is not available, I will have a hard time finding a suitable substitute.
    Que Sara - like a lot of products I love, they go away before I can buy more.
    This sucks - sorry to be so negative. A good product bites the dust.
  7. #20
    Board of Directors
    DQ
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,636
    Visit Freq
    6.42 visits/week
    Threads
    298
    Classifieds
    Quote Originally Posted by KenOfCary View Post
    Ken,
    I believe the DRIcore R+ (insulated panel) is the same as Barricade OVRX. DRIcore Subfloor is the one with the plastic bottom (more air flow).
  8. #21
    Board of Directors
    Secretary
    DQ
    Michael Mathews's Avatar
    Nickname
    Michael (55)
    Join Date
    Mar 2012
    Location
    Chapel Hill, NC
    Posts
    1,407
    Visit Freq
    5.27 visits/week
    Threads
    140
    Classifieds
    If moisture isn't a problem, I'd go with the 4' x 8' sheets of blue foam and T&G on top of that. Surely more cost effective!
  9. The following 3 users say Thank You to Michael Mathews :
  10. #22
    Board of Directors
    DQ
    Nickname
    Jeremy (37)
    Join Date
    Dec 2010
    Location
    Oak Ridge, NC
    Posts
    3,636
    Visit Freq
    6.42 visits/week
    Threads
    298
    Classifieds
    Quote Originally Posted by Michael Mathews View Post
    Definitely leaning that direction. I'll have time to overthink this as I stumble my way through hanging drywall.
  11. #23
    DQ
    LB75's Avatar
    Nickname
    George (44)
    Join Date
    Dec 2012
    Location
    Concord, NC
    Posts
    467
    Visit Freq
    6.04 visits/week
    Threads
    Classifieds
    Yup, and super comfy on the feet, knees, and back.
  12. The following user says Thank You to LB75 for this useful post:
  13. #24
    Nickname
    Join Date
    Jul 2007
    Location
    Chapel Hill, NC
    Posts
    Visit Freq
    4.62 visits/week
    Threads
    Classifieds
    I have first-hand experience: similar square footage, bone-dry walkout basement on slab, new construction, ceiling height no issue. My priority was comfort followed by economy, DIY scope, air circulation to miminize mold problems, and flexible future use. I evaluated Dri-Core and stringers with foam interiors. I chose another option called Delta-FL. (Comes up #1 result if you Google it)
    It comes in large rolls which are pretty quick to put down and I put 3/4 t&g plywood subfloor on top. In an adjacent sewing room I installed Pergo over foam pad, in the shop I coated with clear poly.
    I didn't want to mess with shimming Dri-Core and I wanted plywood rather than flake board as finish. About 1 1/4 inch lost headroom.
    Installed with some tap-con screws to keep edges down. Poly was a bit slick with sawdust so I recoated with second coat with 'Sharkbite' additive. Now no-slip but easy to sweep and clean. Glue drippings just pop off, paint or water beads up for quick cleaning. Leaves plywood color which is easy to spot dropped hardware and good light reflection.
    Very comfortable to stand on. Supposedly can finish floor later if desired. I'm pretty happy with it, you're welcome to stop by some time to check it out yourself.
    Chapel Hill
  14. #25
    User CrealBilly's Avatar
    Nickname
    Join Date
    Feb 2009
    Location
    Creal Springs, IL
    Posts
    10,212
    Visit Freq
    2.46 visits/week
    Threads
    975
    Classifieds
    I can almost smell rotten fish all the way over here. The smell is not just limited to spary foam, it also happens with ridgid foam also
    #ArmOurTeachers
    #SchoolConsealedCarry
  15. #26
    Nickname
    joe
    Join Date
    Dec 2008
    Location
    Wilmington, NC
    Posts
    195
    Visit Freq
    5.15 visits/week
    Threads
    Classifieds
    I used Dri-Core on my walk out basement. I had some old wetness issues, so did not want to do the floors like I did my shop. I like the Dri-Core floors and have had them down for about 3 years now without any issues.
  16. #27
    Nickname
    Join Date
    Feb 2009
    Location
    Creal Springs, IL
    Posts
    10,212
    Visit Freq
    2.46 visits/week
    Threads
    975
    Classifieds
    Quote Originally Posted by joec View Post
    I've never used it but DRIcore seems like a much better solution as it allows for air flow inbetween the slab and the DRIcore insulation. Cement sweats, you cant do anything about that... so moisture is always a issue and you know what happens when moisture is not allowed to eacape, mold growth occurs. When rigid (blue or pink) or closed cell spray foam gets wet and not allowed to breath - it'll give off a rotten fishy smell over time. Ive been there and done that... Just trying to save you the headache i went through.
    #ArmOurTeachers
  17. #28
    Co-director of Outreach Corporate Member
    DQ
    golfdad's Avatar
    Nickname
    Dirk (63)
    Join Date
    Oct 2005
    Location
    Clayton, NC
    Posts
    2,711
    Visit Freq
    6.46 visits/week
    Threads
    137
    Classifieds
    Rigid Insulation can be ordered with grooves in it for airflow which would help if you had any moisture coming thru the slab. Then top with 4x8 T & G plywood
  18. The following user says Thank You to golfdad for this useful post:
Similar Threads
  1. Basement Humidity
    By gfernandez in forum General Woodworking
    Last Post: 05-28-2009, 03:42 PM
  2. Redecorating the Basement
    By LeftyTom in forum Workshop Discussion
    Last Post: 04-12-2009, 08:44 AM
  3. Workshop - Out of the Basement
    By mgoins in forum Workshop Discussion
    Last Post: 11-27-2008, 02:35 PM
  4. Basement find!!!
    By Chipper in forum Power Tools and Their Use
    Last Post: 02-06-2008, 09:53 PM
  5. Soundproofing basement
    By BMT5000 in forum Workshop Discussion
    Last Post: 06-13-2007, 05:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
