The Woodworking Source (Banner Ad 2)
Results 1 to 10 of 10
  1. #1
    Nickname
    SeanStuart
    Join Date
    Dec 2011
    Location
    Fayetteville, NC
    Posts
    41
    Visit Freq:
    1.31 visits/week
    Threads
    Classifieds
    Proper wood storage
    Hey, I just got some 8/4 rough Mahogany from Steve Wall Lumber, and do not want it to warp. My plan is to store it flat on a 2x4 rack. Do I need to weight it down, or will it be ok just stored flat? Thanks.
  2. #2
    DQ
    scsmith42's Avatar
    Nickname
    Scott Smith
    Join Date
    Mar 2007
    Location
    New Hill, NC
    Posts
    4,017
    Visit Freq:
    5.50 visits/week
    Threads
    184
    Classifieds
    Re: Proper wood storage
    As long as it is dry (and coming from Steve, it should be ) and stored in an environment that is relatively dry (shop or garage), flat storage is just fine. No need to add weight.
  3. The following 4 users say Thank You to scsmith42 :
  4. #3
    Nickname
    SeanStuart
    Join Date
    Dec 2011
    Location
    Fayetteville, NC
    Posts
    41
    Visit Freq:
    1.31 visits/week
    Threads
    Classifieds
    Thanks. It will be in the garage, which is vented, so same temp/humidity as outside. What do you think of storing it on edge so I don't have to restack as much?
  5. #4
    DQ
    scsmith42's Avatar
    Nickname
    Scott Smith
    Join Date
    Mar 2007
    Location
    New Hill, NC
    Posts
    4,017
    Visit Freq:
    5.50 visits/week
    Threads
    184
    Classifieds
    On edge should be fine.
  6. The following user says Thank You to scsmith42 for this useful post:
  7. #5
    DQ
    bluedawg76's Avatar
    Nickname
    Sam
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    500
    Visit Freq:
    7.00 visits/week
    Threads
    33
    Classifieds
    what scott said. fwiw, my lumber is stored vertically along a wall in the garage. easier to sort through that way and takes up less wall space (my ceiling is 9+ft). one thing to consider is that moisture wicks through the concrete floor, so I don't like storing directly on the concrete.
    Sam
    You can't milk a cow with your hands in your pants.
  8. #6
    DQ
    srhardwoods's Avatar
    Nickname
    Join Date
    Dec 2011
    Location
    Suffolk, VA
    Posts
    181
    Visit Freq:
    5.00 visits/week
    Threads
    Classifieds
    another route is wrap in plastic and seal it completely. I have wrapped bundles of lumber when they came out of the kiln. This was for long term storage. Works great. trick is, wrap snug and it must be sealed well. if the wood is equalized, and sealed in the plastic then it should move on you.
  9. The following user says Thank You to srhardwoods for this useful post:
  10. #7
    DQ
    Nickname
    Join Date
    Dec 2011
    Location
    Suffolk, VA
    Posts
    181
    Visit Freq:
    5.00 visits/week
    Threads
    Classifieds
    I had a typo, I meant to say "sealed in plastic then it should NOT move" .....Thanks Scott
  11. #8
    DQ
    Tim Sherwood's Avatar
    Nickname
    Tim
    Join Date
    Apr 2011
    Location
    Greensboro, NC
    Posts
    278
    Visit Freq:
    3.35 visits/week
    Threads
    Classifieds
    Does this mean that if you have kiln dried boards, they do not need to be stickered?
  12. #9
    DQ
    scsmith42's Avatar
    Nickname
    Scott Smith
    Join Date
    Mar 2007
    Location
    New Hill, NC
    Posts
    4,017
    Visit Freq:
    5.50 visits/week
    Threads
    184
    Classifieds
    Quote Originally Posted by Tim Sherwood View Post
    Tim, the deciding factor is not if the lumber has been kiln dried; it is what the current moisture content of the lumber is.
    As long as the lumber is down below 16% or so, you can safely dry stack it. It doesn't matter if it was kiln dried or air dried, as long as the CORE of the lumber is dry, you can dry stack.
    Most hardwood lumber comes out of the kiln between 6% - 8%, and then the moisture level increases as it equalizes with it's environment. If it's stored inside a climate controlled warehouse, then it will stay around 7% - 9%. If it's stored in an uncontrolled workshop, then it will probably increase up to 10% - 12%. Outside it will go up to 12% - 16% in our area.
  13. The following user says Thank You to scsmith42 for this useful post:
  14. #10
    DQ
    Nickname
    Tim
    Join Date
    Apr 2011
    Location
    Greensboro, NC
    Posts
    278
    Visit Freq:
    3.35 visits/week
    Threads
    Classifieds
    Thanks Scott! My shop is in a controlled basement. I'll check my wood when I stack it. But I should be able to get rid of a couple of buckets of sticks.
Similar Threads
  1. Wood Storage
    By Flute Maker in forum Wood
    Last Post: 07-13-2011, 09:27 PM
  2. K.I.S.S. Wood Storage Shelf
    By JOAT in forum General Woodworking
    Last Post: 06-29-2009, 03:14 PM
  3. vertical wood storage
    By Keye in forum General Woodworking
    Last Post: 06-18-2009, 10:46 AM
  4. wall storage for wood
    By Keye in forum Workshops
    Last Post: 09-14-2008, 06:54 PM
  5. Wood,Wood Shorts...Storage question
    By redhawknc1 in forum Wood
    Last Post: 03-06-2008, 07:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
