Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 11 of 11
  1. #1
    Nickname
    Dustin
    Join Date
    Jun 2011
    Location
    Wilmington, NC
    Posts
    47
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Making electric motor variable speed for bowl lathe
    I'm working on a homemade bowl lathe, and instead of having a 4-pully step for the speed control I was wondering on how to just make the motor variable speed, maybe with a light switch dimmer sort of deal. Any suggestions?
  2. #2
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,842
    Visit Freq
    6.77 visits/week
    Threads
    202
    Classifieds
    Re: Making electric motor variable speed for bowl lathe
    If you are using a single phase induction motor for a motor, then no, you may not use a light dimmer (or any other speed controller really).
    To have electronically variable speed you will either need a universal/dc motor with PWM speed controller or a 3-phase inverter-duty induction motor with a variable-frequency inverter to control its speed.
    Induction motors are phase-locked to their drive frequency (60Hz in the US) and will always try to maintain their targeted RPM (typically 1800 or 3600RPM nominal). Aside from the fact that the inductive nature of such a motor would very likely destroy a light dimmer in short order, all a dimmer would do is increase slip under load which might initially seem like speed control until you realize that increasing slip really means a highly unpredictable RPM since the RPM will vary constantly depending upon the load... and not whatever "speed" setting you may have intended to dial in.
  3. #3
    User eyekode's Avatar
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    2,072
    Visit Freq
    0.65 visits/week
    Threads
    184
    Classifieds
    Sounds like a cool project. Make sure to post pictures .
    Most large variable speed lathes use both pulleys and motor speed control. This is because at low RPM VFD's driving 3 phase motors deliver very little power. They are aproximately constant torque. So if a 1800rpm motor provides 3hp then at 180 rpm you only get .3 hp and the lathe would stall too easily. At low speed you need gear (pully) reduction to let the motor run fast enough to provide sufficient driving power. I suggest googling to see the gear ratios on the powermatic 4224 or 3520b to see what to aim for.
    Good luck!
    Salem
  4. #4
    Administrator User
    DQ
    SubGuy's Avatar
    Nickname
    Zach
    Join Date
    Nov 2009
    Location
    Kingsland, GA
    Posts
    2,779
    Visit Freq
    2.38 visits/week
    Threads
    136
    Classifieds
    Maybe a fully Variable belt design? I've seen designs for a cone-like design on other applications. Definitely pics!
    -Zach
    Reinventing the Wheel....One 800mg Ibuprofen at a time!
  5. #5
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    2,072
    Visit Freq
    0.65 visits/week
    Threads
    184
    Classifieds
    I have a Reeves drive lathe (Jet 1236). I have never seen a wood reeves drive lathe that turns slow enough for bowls.
    I would much prefer stepped pulleys and a VFD / 3 phase motor.
    Salem
  6. #6
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    11,932
    Visit Freq
    7.00 visits/week
    Threads
    693
    Classifieds
    My lathe is set up with stepped pulleys and a VFD/3 ph motor. We have the minimum run set at 30% and the motor is 1750 rpm. So on a 1/1 pulley set the min rpm is 525 and at 3/1 I can get down to 175 RPM which is good for medium bowls. If you are turning very large bowls you may need to go to a 6/1 pulley set to get slow enough, by very large I mean 36 inch diameter bowls.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  7. #7
    Board of Directors
    Vice President
    Returning Member CarvedTones's Avatar
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    Quote Originally Posted by eyekode View Post
    Interesting. Do you know what the torque calculation is like for the smaller DC VS lathes?
  8. #8
    Nickname
    Dustin
    Join Date
    Jun 2011
    Location
    Wilmington, NC
    Posts
    47
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Thanks for all ya'lls help, I will definitely consider all of this. I was cruising around on CL and came up with the idea why couldn't I take a motor off something cheap, like an old treadmill, or something of that nature with a variable speed 1-2 hp motor in it that can handle heavy loads (sometimes VERY heavy). I know this opens up a whole new set of doors... but any suggestions? or is this a huge shot in the dark?
  9. #9
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    11,932
    Visit Freq
    7.00 visits/week
    Threads
    693
    Classifieds
    if you want to turn big bowls - very heavy then i suggest at least a 3 hp motor and 5 hp would be much better.
    WWFD
  10. #10
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,842
    Visit Freq
    6.77 visits/week
    Threads
    202
    Classifieds
    Quote Originally Posted by dustin510 View Post
    My (possibly incorrect) recollection is that most treadmills do use DC motors for their main drive-train. Such a motor would be suitable for a lathe, though I could not begin to say how it would compare with a traditional induction motor of some arbitrary size -- I really have not used lathes so I would be uncomfortable offering advice in that respect.
    If the motor has a built-in tachometer and such is combined with a suitable after market PWM controller that can make use of that tachometer, then it can potentially deliver near full power even at fairly low speeds because the tachometer will provide the controller with absolute feedback on actual drive speed (this is particularly true for tachometers with a fine feedback pitch), which the speed controller can then react to in real time to try and maintain the desired RPM even under widely varying load (literally up to full power -- even at low speed -- if that is what it takes to maintain the desired RPMs). Only when the motor is overloaded at a particular speed would its speed regulation suffer.
    However, to roll your own custom setup with an aftermarket speed controller and make it work with a motor you just happen to have on hand (as opposed to a purpose-chosen motor) will require that you have a good bit of electrical and/or microcontroller or speed-controller configuration experience. You might find a ready made solution, but I would not count on it unless you start out choosing each of your components to match a known workable solution package (you never know what info you may come across on the 'net).
    Whatever adventure you may decide to embark on, we all wish you the best and look forward to hearing back from you with regards to your progress should you choose to pursue such. Just because something may not be easy or trivial does not necessarily mean it is not worth trying if you enjoy the challenge and are not afraid of possible failure -- sometimes knowledge and experience truly are their own reward.
  11. #11
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    2,072
    Visit Freq
    0.65 visits/week
    Threads
    184
    Classifieds
    I wish Jim (froglips) would chime in as I believe he made a lathe with his father. Where is that guy???
    Anyway I have heard of people scavenging treadmill motors and doing cool things with them. But I suspect it will not have the power to make a decent bowl lathe. You can look at the electrical specifications on the treadmill if it is not close to 15A you know it will not even be close to strong enough. Even some 16" lathes (which is not large for a bowl lathe) move up to 220v.
    Salem
Similar Threads
  1. cordless, variable speed, variable torque
    By jhreed in forum Found for Sale/Hot Deals
    Last Post: 05-02-2010, 04:20 PM
  2. Bosch 5-Amp Variable Speed Jig Saw/Lowes
    By FlyBallFly in forum Found for Sale/Hot Deals
    Last Post: 12-17-2008, 08:22 AM
  3. ATTN: Jet mini lathe variable speed owners
    By Truefire in forum Power Tools and Their Use
    Last Post: 05-28-2008, 03:10 AM
  4. Variable Speed???
    By Mike Davis in forum Power Tools and Their Use
    Last Post: 05-14-2008, 06:31 AM
  5. Jet Variable Speed Mini Lathe (Craigslist Raleigh)
    By sapwood in forum Found for Sale/Hot Deals
    Last Post: 11-28-2006, 02:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
