West Penn Hardwoods (Ad 2)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
  1. #1
    DQ
    BKind2Anmls's Avatar
    Nickname
    Susan (57)
    Join Date
    Feb 2008
    Location
    Cassatt, SC
    Posts
    980
    Visit Freq
    0.38 visits/week
    Threads
    200
    Classifieds
    How do I drill a hole through cloth?
    I am making a display box to hang on the wall for one of my clients. She wants a black velvet background. She is going to hang four family heirloom badges (like the kind Scottish people wear on their hats, I think) which have a horizontal pin on the back like a modern-day broach. I was going to cover 1/4" plywood with the black velvet. I am heading out to Lowe's to try and find the appropriate hardware on which to hang the badges so they can be removed and worn when desired. I chose the 1/4" to give me good purchase for whatever hardware I choose.
    My problem is that I will have to drill through the black-velvet into the plywood to secure the hanging hardware. A long time ago I tried to drill through cloth and it didn't go well. The cloth twisted up and ruined what I was doing. I'm also afraid the cloth will eventually pull away from the hole and leave some wood exposed, over time, even if it doesn't twist.
    I considered covering the entire board with spray adhesive before I applied the cloth but I'm not sure that it would be strong enough to fight the torque of the drill and would fail over time pulling the fabric away from the hole.
    Anybody have any positive experiences to share?
    If you want to build a ship, don't drum up people to collect wood and don't assign them tasks and work, but rather teach them to long for the endless immensity of the sea. -- Antoine de Saint-Exupery
    “Wild animals never kill for sport. Man is the only one to whom the torture and death of his fellow-creatures is amusing in itself.” - James Anthony Froude
  2. #2
    DQ
    jlayell's Avatar
    Nickname
    Jerry (58)
    Join Date
    Oct 2010
    Location
    Burnsville, NC
    Posts
    61
    Visit Freq
    2.35 visits/week
    Threads
    Classifieds
    Re: How do I drill a hole through cloth?
    If the material is a man made fiber, a soldering iron works well.
  3. #3
    DQ
    Bill Clemmons's Avatar
    Nickname
    Bill (69)
    Join Date
    Mar 2010
    Location
    Liberty, NC
    Posts
    5,997
    Visit Freq
    7.00 visits/week
    Threads
    255
    Classifieds
    Can you put another piece of wood over the cloth? Sorta like a sandwich w/ the cloth in the middle. Then find a way to press down on the top piece of wood so it is tight against the cloth. I use this method when I drill holes in sandpaper disk for the vacuum to work better.
    I'll gladly tell you how I do something. Just please don't confuse that with the right way to do it, and almost certainly not the only way.
  4. #4
    Staff Advisor
    Returning Member
    Trent Mason's Avatar
    Nickname
    Trent Mason
    Join Date
    Feb 2008
    Location
    Cary, NC
    Posts
    5,928
    Visit Freq
    0.00 visits/week
    Threads
    213
    Classifieds
    Quote Originally Posted by jlayell View Post
    Cool idea. Will have to keep that in mind.
    Woodworking will teach you both patience and how to overcome adversity. The more patient you are, the less adversity you will have to overcome.
  5. #5
    Board of Directors
    Vice President
    Returning Member CarvedTones's Avatar
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    I would use a punch to cut the cloth and use a pattern to make sure I spaced the holes the same on the cloth and the wood. Drill the wood without the cloth there, then put the cloth on with its holes punched in the matching locations so the screws can go through. Cloth fibers don't drill well; they need to be sheared.
    EDIT - note that this is explicit to felt and some similar fabrics that don't unravel. If I were using a fabric that did unravel I would put a drop of epoxy on the spot, let it dry and then drill through.
  6. #6
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,621
    Visit Freq
    6.42 visits/week
    Threads
    348
    Classifieds
    +1 on the punch idea. I see hollow punches often at the local flea market, the kind used to punch leather as well as plastic tarps. I'd lay the velvet out & punch it on the plywood backing to give you a reference on where to drill the holes.
    WHAT BOX?
  7. #7
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,133
    Visit Freq
    7.00 visits/week
    Threads
    711
    Classifieds
    Just drill the wood first, the cloth will separate enough to poke the screws through. If your still worried about it poke an ice pick through the cloth right before you insert the screws. If the screws are very small don't even drill the wood, just poke a hole with an ice pick.
    Spray adhesive is a good idea, remember to let it tack up before you adhere the cloth. Fresh spray adhesive will bleed through most cloth unless it is really thick. In that case spray, let it dry then spray again, let it get tacky then spread the cloth. Best to have three or four people if the board is large, some to hold the cloth snug a few inches above the board and one to press down with a wide soft squeegee.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  8. #8
    Board of Directors
    Vice President
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    Quote Originally Posted by Gotcha6 View Post
    I like that additional idea a lot. I will have to remember that - mark the holes by punching right over the backing. I always take transfer over measurement when I have the option. Very clever, Dennis.
  9. #9
    DQ
    walnutjerry's Avatar
    Nickname
    Jerry
    Join Date
    Feb 2006
    Location
    Salisbury, NC
    Posts
    1,596
    Visit Freq
    6.58 visits/week
    Threads
    Classifieds
    +1 Mike--------pending size of the holes, larger holes in the cloth can be cut out with an exacto knife after the backing is bored and cloth adhesive is dry.
    Jerry
    We make a living by what we get...............We make a life by what we give
  10. #10
    Returning Member
    Nickname
    Brian
    Join Date
    Feb 2009
    Location
    Apex, NC
    Posts
    144
    Visit Freq
    0.19 visits/week
    Threads
    Classifieds
    These pins probably don't weigh much. Can you find some hanging hardware that you can attach with tiny brads or tacks through the velvet into the plywood?
    Brian
  11. #11
    DQ
    gator's Avatar
    Nickname
    George (78)
    Join Date
    Jul 2005
    Location
    Oxford, NC
    Posts
    1,846
    Visit Freq
    7.00 visits/week
    Threads
    151
    Classifieds
    Have you considered using flocking instead of velvet. Over time, if not glued to the backer, the velvet will start to sag. Flocking would be permanent and you could drill first and then apply the flocking.
    George
    2B1ASK1
  12. #12
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,115
    Visit Freq
    6.50 visits/week
    Threads
    77
    Classifieds
    Another option would be to use small hooks to hang the badges on (like the little ones used to hang a calendar or small pictures on sheet rock). If they would be too unsightly in the whole, attach them to the backer board before putting on the velvet or fleck, and and make a little slice in the cover to slide over the hook when applying it. Flock could be applied right over them.
    The advantage is that the badges can be easily removed to wear, and easily hung back up when displayed, without disturbing the background covering.
    I would try it first on a scrap piece to see if they would hang like you want.
    jmtcw
    Practicing at practical woodworking
  13. #13
    DQ
    Nickname
    Susan (57)
    Join Date
    Feb 2008
    Location
    Cassatt, SC
    Posts
    980
    Visit Freq
    0.38 visits/week
    Threads
    200
    Classifieds
    Thanks for all the tips.
    I went to Lowe's and picked up some spray adhesive. Thanks for the tip about letting it tack up first.
    I found a type of black clip in the automotive hardware drawers. I bought a few different sizes and am going to try them out. If they work, I'll have to paint the screw heads I use black.
    I suggested flocking to my client when I built my walnut box but found out that "some circles" consider flocking "cheap." Who knew? I hope a sawtooth hanger is acceptable.
    L-brackets would have been my first choice but the threads stop too far away from the bend.
    I am going to try poking a hole with an awl and putting thin CA glue on the threads of the screw to try and glue
    the cloth in the hole. Hopefully, the spray adhesive will help prevent any sagging.
    It's a simple box but all this non-wood stuff is new to me. I also have to cover the mat with a tartan cloth. There are a lot of straight lines so the tiniest bit of stretching will throw it off. Another new thing to figure out how to do. Spray adhesive to the rescue, I hope. I also have to put brown paper across the back to cover everything.
    One thing I forgot about while making the box was the extra bulk the cloth would add. My rabbit wasn't wide enough so I had to cut the mat.
  14. #14
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,133
    Visit Freq
    7.00 visits/week
    Threads
    711
    Classifieds
    When you glue the brown paper dust seal use Elmer's or Titebond yellow glue. Just a thin bead all the way round the frame. Spray the paper lightly with water (A fine mist works best) and glue it to the frame. Wait till it is dry then trim the paper around the edge of the frame. The mist of water makes the paper dry tight as a drum on the frame. If you glue without misting first the paper will be loose and floppy.
    I ran a framing shop for three years so I know how this works. We did thousands of picture frames, shadow boxes and displays. I made one display frame for the Chief of Police with every type of badge the dept had used since 1910 and several patches.
    WWFD
  15. #15
    DQ
    Nickname
    Susan (57)
    Join Date
    Feb 2008
    Location
    Cassatt, SC
    Posts
    980
    Visit Freq
    0.38 visits/week
    Threads
    200
    Classifieds
    Thanks, Mike. I now remember reading that technique years ago but had completely forgotten about it. You've saved me a lot of trouble I believe.
Similar Threads
  1. need to drill a 2" hole 11" from edge - DONE with pictures
    By CarvedTones in forum General Woodworking
    Last Post: 04-28-2010, 02:31 PM
  2. Drill a centered hole...
    By froglips in forum "How To" Forum
    Last Post: 11-08-2008, 05:39 PM
  3. Tac cloth
    By Tom Dunn in forum Finishing
    Last Post: 01-17-2008, 03:37 PM
  4. Drill hole in china plate.....
    By froglips in forum General Woodworking
    Last Post: 06-18-2007, 11:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
