Festool (Ad #1)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
  1. #1
    Nickname
    ScottC
    Join Date
    Jan 2010
    Location
    Saluda, NC
    Posts
    Visit Freq
    0.35 visits/week
    Threads
    Classifieds
    Creating complementary curves
    I have a question about a technique for creating complementary curves. This technique seems easier than those. Have read about or videos I've watched on this subject. I'm wondering if anyone has experience with the method I'm considering.
    The ultimate goal is to create a panel consisting of two contrasting types of wood - joined with a perfectly fitting complementary curve. ( think Yin / Yan shape).
    Here's the process I'm considering.
    Mill two panels of contrasting woods ( e.g walnut , maple ) to approx 1/8" thick.
    create template of the curve I want using bandsaw.
    stack both panels on top of each other.
    place template on top of stack.
    use router with 1/8" straight cutting bit and bearing on top.
    cut through both panels at the same time with bearing riding on template.
    In "theory," this should create 4 pieces with perfectly matching curves. Has anyone tried this method?
    Thanks.
    Scott C.
  2. #2
    Administrator Corporate Member
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,882
    Visit Freq
    6.92 visits/week
    Threads
    204
    Classifieds
    Re: Creating complementary curves
    You could also cut out your design using a very thin blade on the scroll saw (just stack the two pieces of wood) and you will automagically have your complementary curves without any fancy templates. Keep in mind that a bandsaw has a much larger kerf than a scroll saw.
    I'm sure some of our dedicated scroll sawyers could offer some expert advice on the subject.
  3. #3
    Board of Directors
    Vice President
    Returning Member CarvedTones's Avatar
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    There is a hole in your theory. I have cut puzzles on the scroll saw lots of times and the tiny kerf creates enough of a gap for the pieces to easily be removed and assembled but even at that size you can tell the arcs are affected. In a curved section, the piece on the inside will have an arc with a radius one kerf width less than the piece outside. In your example, that would be 1/8" and that will be enough so that they don't fit exactly.
  4. #4
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,251
    Visit Freq
    6.92 visits/week
    Threads
    247
    Classifieds
    Scott: My first take is that the two curves will not match entirely perfectrly. Take the limit as you approach small radius curvatures. On the inside piece the radius could be 3/8", and on the outside piece the radius of the same curve would be 1/2". These curves won't fit together, without a 1/8" strip of metarial between them.
    Fine woodWorking had a great video on a technique, but I have long since lost that - access to their archives might reveal it. that convinced me it would work. I believe it involved making a smooth cut with a bandsaw to create two templates, and the using these temples to create complementary pieces. Of course my argument about radii above still holds... but I can't recall what they did to offset that. Smooth large radii curves were needed as I recall.
    Henry
  5. #5
    Board of Directors
    President
    DQ
    Mike Davis's Avatar
    Nickname
    Join Date
    Dec 2005
    Location
    Walnut Cove, NC
    Posts
    12,133
    Visit Freq
    7.00 visits/week
    Threads
    711
    Classifieds
    You should try this with paper first, with some curves when you remove a 1/4 inch strip between the two parts you create a gap that does not reflect the opposite sides. In other words the parts will not fit.
    One machine can do the work of 50 ordinary men. No machine can do the work of one extraordinary man." -Elbert Hubbard
    WWFD
  6. #6
    DQ
    ehpoole's Avatar
    Nickname
    Ethan (46)
    Join Date
    Oct 2009
    Location
    Anderson, SC
    Posts
    5,882
    Visit Freq
    6.92 visits/week
    Threads
    204
    Classifieds
    Quote Originally Posted by CarvedTones View Post
    A scrollsaw blade with a 0.01" kerf will only create a 0.01" kerf (1/8" is closer to a wide bandsaw blade or tablesaw blade). A kerf of a couple hundredths of an inch will close up if a water based glue is used. Perhaps you were using some of the very heavy scrollsaw blades -- although I don't think even they create much more than a 1/32" (~0.03") kerf?
    I know the method I suggested above is used quite a lot in intarsia work.
    I'm not trying to argue, but rather seek clarification because I have seen the method used quite extensively and, even as an occasional scrollsaw user, I have some extremely fine blades that would create a barely visible kerf.
  7. #7
    Board of Directors
    Vice President
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    It's one of those "in theory versus in practice" things. They make a puzzle blade that is really small, but I usually use a #5 or even a #7 if it is a puzzle for kids and a little more gap is a good thing. Anyway, puzzles have some ridiculously tight curves and unless you have some mad skills some of the cuts will be slightly sloppy. By that I mean more than a normal kerf width. Anytime you get a little side pressure on the blade, it increases the kerf width. The teeth do the cutting, but the side can wallow out a little more when it is hitting.
  8. #8
    DQ
    Gotcha6's Avatar
    Nickname
    Join Date
    Jan 2007
    Location
    Ivan's Corner (Monroe), NC
    Posts
    5,621
    Visit Freq
    6.42 visits/week
    Threads
    348
    Classifieds
    Cut 2 templates (yin and yang) and be sure they match each other when one is rotated 180 degrees. Then proceed as mentioned using both templates set on the workpieces with enough clearance for the pattern bit. They should fit.
    WHAT BOX?
  9. #9
    Nickname
    ScottC
    Join Date
    Jan 2010
    Location
    Saluda, NC
    Posts
    Visit Freq
    0.35 visits/week
    Threads
    Classifieds
    All
    Thank you for your prompt replies. You saved me. Indeed - there was / is a hole in my theory. I didn't consider the effect of the change in circumference caused by the waste from the 1/8th bit.
    I watched the FW video mentioned by HenryW. I'm going to use that technique as I've seems to work.
    Thanks again to all.
    ScottC
  10. #10
    Board of Directors
    Vice President
    Nickname
    Andy (59)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,674
    Visit Freq
    0.04 visits/week
    Threads
    329
    Classifieds
    Quote Originally Posted by ehpoole View Post
    BTW, this is a perfect opportunity for my tangential "why haven't we gone metric?" rant? The back and forth between fractions and decimals and approximations. The blades I commonly use are between .3 mm and .5 mm straight line kerfs.
    Also forgot to mention that I have dome some intarsia work and there is some sandpaper involved in a perfect fit.
  11. #11
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,251
    Visit Freq
    6.92 visits/week
    Threads
    247
    Classifieds
    Scott: Do you have a free access link to that technique? I'd like to see it again.
    Henry
  12. #12
    Nickname
    ScottC
    Join Date
    Jan 2010
    Location
    Saluda, NC
    Posts
    Visit Freq
    0.35 visits/week
    Threads
    Classifieds
    Henry:
    Here you go.
    http://www.finewoodworking.com/subsc...e.aspx?id=5312
    I think this requires membership.
    Thanks for your help.
  13. #13
    Returning Member Flootsie's Avatar
    Nickname
    Milissa
    Join Date
    Sep 2010
    Location
    Asheville, NC
    Posts
    537
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Gotcha6 View Post
    I think this method from Dennis would work. When you cut for the clearance, would you need to cut to the same "side" of the clearance gap?
    Milissa Ellison Dewey
    ("Flootsie" of CHESSSPY & FLOOTSIE!)
    http://www.chessspy.com
  14. #14
    DQ
    Nickname
    HenryW
    Join Date
    Aug 2005
    Location
    Raleigh, NC
    Posts
    1,251
    Visit Freq
    6.92 visits/week
    Threads
    247
    Classifieds
    Yes - requires membership....
    THanks Scott
  15. #15
    Nickname
    ScottC
    Join Date
    Jan 2010
    Location
    Saluda, NC
    Posts
    Visit Freq
    0.35 visits/week
    Threads
    Classifieds
    FW also published a companion article "Cut Matching Curves". The author is Carol Koebbeman.
Similar Threads
  1. Best Bandsaw Blade for curves?
    By cpw in forum Power Tools and Their Use
    Last Post: 12-28-2011, 03:47 PM
  2. Outside curves
    By Bigdog72 in forum General Woodworking
    Last Post: 10-21-2010, 11:34 AM
  3. Curves on a Band Saw
    Last Post: 06-28-2010, 12:46 AM
  4. Creating a cut list...
    By Mt. Gomer in forum General Woodworking
    Last Post: 06-10-2010, 06:34 AM
  5. Router curves
    By Dreuxgrad in forum "How To" Forum
    Last Post: 11-21-2006, 12:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
