The Woodworking Source (Banner Ad 2)
Results 1 to 7 of 7
  1. #1
    Corporate Officer Corporate Member
    DQ
    CarvedTones's Avatar
    Nickname
    Andy (54)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,386
    Visit Freq:
    4.42 visits/week
    Threads
    314
    Classifieds
    Finally set up grinding station properly
    A big thank you to Salem (eyekode) who was about to toss out his shop made grinding attachments as he has a "real" Wolverine now. Sorry about the lousy quality phone pic.
    Turning gouge jig on the left, adjustable surface on the right (had to cut it down for my smaller grinder) and behind it is my drill bit sharpener. Everything is bolted down and I drilled a couple of holes and glued in dowels as guides to make sure I keep the gouge jig straight. Already tuned up some turning gouges and did a little turning; they are definitely sharper than I was getting them without the jig. Thanks again, Salem!
  2. #2
    Board of Directors
    Development Director
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    8,467
    Visit Freq:
    6.54 visits/week
    Threads
    742
    Classifieds
    Re: Finally set up grinding station properly
    Looks good Andy. Last year I took a class from Bill Wallace in his shop. Bill is one of the most recognized turners in the area. ALL his jigs were home made. I guess you can't argue with success.
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  3. #3
    DQ
    Sealeveler's Avatar
    Nickname
    Tony (51)
    Join Date
    Oct 2008
    Location
    Sealevel, NC
    Posts
    2,027
    Visit Freq:
    7.00 visits/week
    Threads
    Classifieds
    Good looking setup.Like your jigs.
    Tony
    O The Secret of Joy in work is contained in one word;Excellence.To know how to do something well is to enjoy it.By Pearl Buck
  4. #4
    DQ
    Nickname
    Andy (54)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,386
    Visit Freq:
    4.42 visits/week
    Threads
    314
    Classifieds
    Thanks; I can't take full credit as they weren't made in my home. Salem upgraded and had no more use for them, so...
    as luck would have it, it also happened while I am in a "get serious about the few specific things I am doing" mode. Getting rid of a lot of things I don't really use and taking some time to make sure I am set up to do the things I actually want to do properly. So I had to put it in service or scrap it.
  5. #5
    DQ
    eyekode's Avatar
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    1,711
    Visit Freq:
    6.50 visits/week
    Threads
    159
    Classifieds
    Andy, it looks good!
    Another option for the rest would have been to lift the grinder up. The wolverine instructions have a specific height. I think they do this just so the angles on there jigs are accurate. Specifically their gouge grinding jigs. That doesn't really matter but it could help you make a clone.
    Anyway here are a few links to making a fingernail gouge grinding jig:
    i always meant to make this one but I have no sheet metal experience: http://www.harderwoods.com/gougejig.html
    Here is an adjustable jig made out of wood: http://www.edenvalleywoodturners.co.uk/Projects.php
    When I made mine I used the geometry off of the wolverine instructions and guessed at 45 degrees between the shaft and the block of the wood holding the gouge. I left the leg too long on purpose thinking I would cut it shorter to find the optimal angle. I never shortened it. So either I got lucky or it isnt too very sensitive to angle. I am guessing the latter .
    Salem
  6. #6
    DQ
    eyekode's Avatar
    Nickname
    Salem
    Join Date
    Jan 2009
    Location
    Apex, NC
    Posts
    1,711
    Visit Freq:
    6.50 visits/week
    Threads
    159
    Classifieds
    Here are some pictures of my simple jig:
    The diameter of the hole is a little larger then the gouge. I used an insert so the wood would not strip out when tightening the bolt.
    In the end the result you are aiming for is something like: http://www.woodcentral.com/newforum/grinds.shtml
    Note that different well renowned turners favor different grinds. My humble advice is to try one for a while. I think they all work but it takes time to get used to a new grind.
    I also think this article does an ok job of describing the various aspects of the grind: http://www.genevaconcepts.com/Geneva...th%20Gouge.pdf
    Good luck!
    Salem
  7. #7
    DQ
    Nickname
    Andy (54)
    Join Date
    Mar 2008
    Location
    Cary, NC
    Posts
    4,386
    Visit Freq:
    4.42 visits/week
    Threads
    314
    Classifieds
    My bowl gouge has my freehand attempted fingernail grind, which is not horrible but not as good as a consistent jig ground fingernail. I think I just have to take a reasonable stab at the geometry and see what I get, and if it is pretty good just stick with it. I am primarily a spindle guy anyway; only have the one 3/8" bowl gouge.
Similar Threads
  1. See if page displays properly
    By Kyle in forum Wood
    Last Post: 10-03-2010, 06:44 PM
  2. Grinding PVC
    By CatButler in forum DIY- Home improvement
    Last Post: 02-08-2010, 04:15 PM
  3. how to properly joint two boards with hand planes
    By jonnyfontaine in forum General Woodworking
    Last Post: 04-25-2008, 09:36 PM
  4. how to store wood properly?
    By jonnyfontaine in forum Wood
    Last Post: 04-17-2008, 09:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
