Klingspor's Woodworking Shop (Locations) Ad #1
Results 1 to 10 of 10
  1. #1
    Returning Member richlife's Avatar
    Nickname
    Rich (70)
    Join Date
    Jan 2010
    Location
    Pittsboro, NC
    Posts
    448
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Storing Mineral Spirits
    Well, after doing some searching, I think I may need the help of a petroleum chemist or a a chemical engineer!
    We have probably all used mineral spirits at one time or another, but I'm having a (relatively) minor problem with storage. I typically buy a gallon at a time. I've kept a quart size metal container that the MS come in for day-to-day use and refill as needed. What I've found is that in a relatively short time (one to two years?), the container will start collecting rust in the bottom -- something I don't want regardless of what I'm trying to work with.
    I'm pretty positive that a glass container would be fine, but for safety reasons I hate to store anything is glass (so far I have succumbed only to using them for small mixes of shellac) -- especially not a pint or quart at a time.
    What I'm trying to find out is what to use for longer term storage of mineral spirits. Some plastics will work for a while, but my experience and what I've seen reported, is that the MS will begin to breakdown the plastic within a few months. The Material Safety Data Sheet doesn't specify materials for storage.
    Does anyone know a FACTUAL answer on what can be used besides metal or glass? Right now I'm waiting to get a suitable glass container. Something coated in plastic would be great. Meanwhile I have a new gallon of MS...
    Rich
    Rich Beaudry - Wood Carver UNC Tar Heel '69, '75 -- "Being happy doesn't mean everything's perfect. It means you decide to see beyond the imperfections."
  2. #2
    DQ
    bluedawg76's Avatar
    Nickname
    Sam
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    876
    Visit Freq
    0.00 visits/week
    Threads
    Classifieds
    Re: Storing Mineral Spirits
    Obviously your collecting water vapor in the can, which is the cause of the rust. So you don't just want to replace the can periodically?
    In the laboratory setting, we commonly use 2 types of plastics, polypropylene (PP) and polypropylene copolymer (PPCO); however I cannot speak to their resistance to degradation with solvents like mineral spirits, but thought I'd give you a place to start until someone else chimes in.
    Glass is generally the most suitable solvent container.
    You can't milk a cow with your hands in your pants.
  3. #3
    Administrator Corporate Member
    DQ
    ScottM's Avatar
    Nickname
    Join Date
    Jul 2007
    Location
    Littleton, NC
    Posts
    10,716
    Visit Freq
    6.38 visits/week
    Threads
    938
    Classifieds
    My question is do you see rust starting on the out side or inside of the can? I have seen experienced some rust on the outside but never the inside. In my case I started keeping the can on a wire shelf and the air flow seems to slow down/prevent the problem. I have never had a can rust through.
    Maker of fine saw dust
    "Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it."
    - Lou Holtz-
  4. #4
    DQ
    PeteM's Avatar
    Nickname
    Pete
    Join Date
    Jan 2006
    Location
    Pittsboro, NC
    Posts
    1,789
    Visit Freq
    0.12 visits/week
    Threads
    217
    Classifieds
    IMHO - If you have a Gallon of MS sitting around for that long you're just not doing enough woodworking, finishing, painting, cleaning, etc.!!!
    Get out in the shop and get to work and forget about rusty cans! You'll use up that MS before the can even gets dusty!!!!!!!!!!
    pete
    I may not have gone where I intended to go, but I think I have ended up where I needed to be.
  5. #5
    DQ
    Gofor's Avatar
    Nickname
    Join Date
    Mar 2006
    Location
    Goldsboro, NC
    Posts
    3,100
    Visit Freq
    6.50 visits/week
    Threads
    77
    Classifieds
    The "cheaper" brands of "paint thinner" is usually in plastic containers, and the MSDS almost always says it is mineral spirits. I have kept in them for over a year with no leaks, altho the container does seem to be a bit mis-shapen after a summer in the garage heat. However, I have never checked the recycle code to know whether they are polypropylene or polyethylene. (The MS I currently have is in a metal can, and I haven't had a rust problem)
    Practicing at practical woodworking
  6. #6
    DQ
    gazzer's Avatar
    Nickname
    Gazzer
    Join Date
    Aug 2006
    Location
    Durham, NC
    Posts
    223
    Visit Freq
    3.54 visits/week
    Threads
    Classifieds
    We use a lot of Nalgene plastic containers. Here's a link to their plastic resin technical guide: http://www.nalgenunc.com/pdf/Nalgene...hGuide0209.pdf. Near the end, there is a section giving degradation details for various plastic compounds. Page 54 has mineral spirits.
    Also, you could buy a kerosine can at the hardware store, that should be fine for mineral spirits.
    If you are not going through a gallon per year, it may be a better idea to buy smaller containers.
    -G
    Anything you can't have fun with isn't worth taking seriously.
  7. #7
    Nickname
    Rich (70)
    Join Date
    Jan 2010
    Location
    Pittsboro, NC
    Posts
    448
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by ScottM View Post
    I actually see rust flakes in the bottom of the can, Scott. Since I typically go through a gallon every two or three months, I wouldn't expect rust. I haven't seen any rust on the screw top either. But it did just occur to me that I haven't looked closely at the gallon can before I disposed it -- just saw this in the bottom of the smaller can. That might be it, but still seems strange as the larger cans just aren't that old and not often opened.
    Pete, you are BAD! But the advice is good.
    Anyway, I started a new 12 oz. glass jar today, so I'll literally see what happens.
    Rich
  8. #8
    DQ
    Sealeveler's Avatar
    Nickname
    Tony
    Join Date
    Oct 2008
    Location
    Sealevel, NC
    Posts
    2,281
    Visit Freq
    6.96 visits/week
    Threads
    20
    Classifieds
    I live close to a salt water bay and have trouble with rusting containers too.To help with condensation in the metal container I keep them in a plastic bucket with a lid,it seems to help keep the temperature changes less severe so I have not had the inside rust problem lately.I have a dehumidifier in the garage that helps with the other moisture problems at bay.
    Tony
    O The Secret of Joy in work is contained in one word;Excellence.To know how to do something well is to enjoy it.By Pearl Buck
  9. #9
    DQ
    Nickname
    Charley (76)
    Join Date
    May 2008
    Location
    Kannapolis, NC
    Posts
    994
    Visit Freq
    5.88 visits/week
    Threads
    Classifieds
    You would normally use Alcohol with Shellac and alcohol will absorb water, which can cause rust. Are you having problems with mineral spirits or alcohol? Your posting is confusing as you talk about mineral spirits, but then talk about shellac which requires alcohol for a thinner.
    Charley
  10. #10
    Nickname
    Rich (70)
    Join Date
    Jan 2010
    Location
    Pittsboro, NC
    Posts
    448
    Visit Freq
    0.04 visits/week
    Threads
    Classifieds
    Quote Originally Posted by Charles Lent View Post
    Charley
    I've not had any problems at all with the alcohol.
    Sorry about any confusion. I am talking about mineral spirits, but I was discussing the use of glass containers which I don't like to do. However, in the case of shellac, I always use small glass containers. I don't use shellac (or anything else) as much as I use oils and oil mixes.
    Rich
Similar Threads
  1. Replies: 12
    Last Post: 01-24-2012, 05:02 PM
  2. Wax and Mineral oil finish
    By Bugle in forum Finishing
    Last Post: 12-29-2011, 01:22 PM
  3. Dry time for mineral spirits?
    By Matt Schnurbusch in forum Finishing
    Last Post: 11-09-2008, 11:55 AM
  4. Paraffin Wax & Mineral Spirits
    By ptt49er in forum General Woodworking
    Last Post: 10-03-2008, 02:40 PM
  5. Hot Mineral Oil?
    By sapwood in forum Finishing
    Last Post: 04-26-2006, 03:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
